Rene vs Metropolis
Alexander Kuznetsov
- futuredaze
- Learning to Wiggle
have the rene...my approach lately has been turn the machines on and let them run, let them go crazy and see what happens and rene is perfect for that. also as a more visual person i like the 4x4 arrangement of rene, getting to see the strange shapes and patterns created by the infinite variety of sequencing options. very stimulating/ can influence how you make your patch in unusual ways
- Montgomery Word
- Veteran Wiggler
Just sold my rene to fund a metropolis.
I loved rene but it was almost impossible to reproduce sequences.
Since I play guitar while the modular is running, metropolis gives me a quicker overview of what is going on.
With rene lots of the time I lost track of what was going on, it just sounded great.
Hope to get another one someday.
But for now metropolis seems to more productive choice.
JozeyWhales
I have Rene and It's been an absolute improvisational blast. One of my favorite features of the sequencer is snake mode. It's always a ton of fun for me to build a sequence and then change the way that the sequencer will iterate coordinates. I've found a bunch of great riffs using this method that I probably never would have found without it. Hope this helps!
Have both... while Rene would be my desert island sequencer, the very different Metropolis has plenty to contribute and they work well together. Probably like the Met best for rhythmic pattern generation, and Rene for sequencing pitches & generating unexpected riffs and melodies.
And with either, it's a huge help to have a comparator around.
"If fame is a penthouse in Manhattan, you're living in a yurt in Mongolia" - C. Berton Irwin
NEWEST RELEASE: https://fastus.bandcamp.com
www.soundcloud.com/fastus
www.soundcloud.com/problivion
Have the metropolis here and i think its a great sequencer, it's just simple and complex enough to have great fun and experiment with. I did't like it so much at first but i got used to my favorite modules being a let down at the beginning. I am having a good time with it and don't feel the need for rene right now, though i never had one. i will probably add another sequencer in the future. my only other one is yarns but would like to try touch sequencer or er101. i wouldn't let metropolis go.
Could you explain what you do with a comparator and your sequencer? I'm not familiar with that approach.Fastus wrote:Have both... while Rene would be my desert island sequencer, the very different Metropolis has plenty to contribute and they work well together. Probably like the Met best for rhythmic pattern generation, and Rene for sequencing pitches & generating unexpected riffs and melodies.
Educational sidebar ... how do you use a comparator with these? To generate varying gates from the pitch/cv output instead of the gate outputs? Edit: or to generate clocks to input?Fastus wrote:And with either, it's a huge help to have a comparator around.
Edit #2: a little late to submit button. Two great minds ... but inquiring minds!! Help us out!! Now I'm studying comparator and logic modules! :-)
- pinkflag16
I'm also looking into getting a sequencer/alternative performance module to get away from the usual keyboard or step sequencer (selling my Mother 32). The Rene looks interesting. Am I correct that it can be "played" like Pressure Points, but with built-in quantization?
I hadn't really looked at the Metropolis until now, but it looks nice and straightforward. Different animal, really.
- pinkflag16
Comparator adds an extra dimension to sequencing. With Rene you can run a pitch sequence to the VCO from QCV using one of the four memory slots - this frees the panel pots for purely CV duties. Turn all the pots full counterclockwise . Now turn the first pot (at 0,0) to full clockwise & connect the Rene CVout to your comparator and set your threshold ( about 12 to 1 oclock on my Animodule ) so that everytime the sequence loops around, 0,0 will generate a gate, signposting the first beat of your sequence. You can use this gate to trigger a supporting kik drum for example, or to provide accents (e.g. routing to a Boogie keyIn ) or to sync another sequence etc.Farfield wrote:Could you explain what you do with a comparator and your sequencer? I'm not familiar with that approach.Fastus wrote:Have both... while Rene would be my desert island sequencer, the very different Metropolis has plenty to contribute and they work well together. Probably like the Met best for rhythmic pattern generation, and Rene for sequencing pitches & generating unexpected riffs and melodies.
You can do the same with the Met if you're using it only as a rhythm generator, hike the pitch CV up to mark your accents and send the pitchCV to the comparator. This works great for exotic odd meters: running a 5/4 pattern and accenting the 1st and 3rd beats for example.
- pinkflag16
Certainly you can use the 'A' / Access program page to add & subtract notes live as the Rene is clocked, and certainly you could start from scratch & activate each new notes live, one by one. But it doesn't act like a looper i.e. recording a phrase of multiple notes just as they were played.pinkflag16 wrote:Can the Rene record a sequence in real time? For example, can I set the quantize to a major scale, play a melody on the touch pads like on a regular keyboard, and then have it loop? Or must I always program each step explicitly?
- pinkflag16
Thank you. I suspected this was the case, but wanted to be sure.Fastus wrote:Certainly you can use the 'A' / Access program page to add & subtract notes live as the Rene is clocked, and certainly you could start from scratch & activate each new notes live, one by one. But it doesn't act like a looper i.e. recording a phrase of multiple notes just as they were played.pinkflag16 wrote:Can the Rene record a sequence in real time? For example, can I set the quantize to a major scale, play a melody on the touch pads like on a regular keyboard, and then have it loop? Or must I always program each step explicitly?
- othermonkey
some fun things you can do with René
sync on a number of steps, then shift and you access to other steps
Label : https://underwater-computing.bandcamp.com/
Tracks : http://dreytnien.bandcamp.com/
"Demos" : https://www.youtube.com/user/heodesalciphron
DIY and more : http://www.infinitesimal.eu
