moogerfooger MF-103 knobs
bdhm
Post by bdhm » Sun Sep 06, 2009 5:30 am
hi°
does anyone know how I can get off the knobs off my moogerfooger MF-103 ?
I can not see any screw. and they don't move when I pull them.
do I have to destroy the silver top part of the knobs?
:help:
thanks,
bd
Cybananna
Funniest Guy
Post by Cybananna » Sun Sep 06, 2009 6:47 am
no, you don't have to remove the silver part. If they don't have a set screw, they're probably just pressed on really tight. I've removed knobs like that by using a small flat screwdriver to CAREFULLY pry the knob off, using the nut to rest the screwdriver on if it will fit. You'll want to pry different "sides" of the not so it pulls off more evenly and doesn't bind. It works, but you risk marking both the knob and the mooger if it's reall stubborn. Others may have a better way of getting it off. :despair:
bdhm
Post by bdhm » Mon Sep 07, 2009 6:29 am
hi Cybananna,
I will try this method.
thanks!
bd
Kent
Curator/Janitor/Zookeeper
Post by Kent » Mon Sep 07, 2009 7:31 am
I have 3 types of knobs on my two Moogers. One of the smaller types has a 'set' screw that needs an allen key.
bdhm
Post by bdhm » Mon Sep 07, 2009 7:54 am
hello °°
I got them off : one was with screw the rest was just very stubborn!
:party:
thanks.
now I will build a smaller case for the mooger.
bd
