Why do vactrols sound the way they do?
Anything modular synth-related that is not format-specific.
andrewl0
Post by andrewl0 »
I understand that vactrols are optocouplers and their usage in traditional circuit design. What I don't understand is why they generate a "rubbery" sound in audio circuits.
Does anyone have any pointers to articles that explain how putting an optocoupler in an audio circuit generates the timbres that I associate with Make Noise modules?
Many thanks!
bleeps
Post by bleeps »
Vactrols are a pairing of an LED and a photo-sensitive cell. LEDs don't shut off immediately when you cut the power to them. They fade. That trailing, delayed fade is what gives them their character.
Also they have unicorn tears inside.
Mono Recalcitrante
Post by Mono Recalcitrante »
bleeps wrote: Also they have unicorn tears inside.
:yay: :yay: :yay:
Ucture
Post by Ucture »
Vactrols explained by Scott Stites :
http://experimentalistsanonymous.com/bo ... pic=1254.0
andrewl0
Post by andrewl0 »
Thanks folks, now that I know about the unicorn tears everything makes sense!
ultrashock
Post by ultrashock »
the main point that vactrols have non-linear response.
human's perception as well as most physical and chemical processes in human organism are also non-linear. far not. that why vactrol's character fits so 'natural' to what we feel and is considered to sound 'musical' without any tricks just out or the box
Drumdrumdrumdrum
What she said
Post by Drumdrumdrumdrum »
They have unicorns inside! :cgs:
"There are two means of refuge from the miseries of life: music and cats."
- Author, Albert Schweitzer.
"Modular synths can take your ego out of the equation which, in music, is a blessing" - Jeremy Greenspan
http://www.cdbaby.com/cd/glennkingsleymortimer
paults
mice nuts
Post by paults »
Ummmmmm...no. It's the Cadmium-Sulfide photocell that turns off/on slowly. In fact, you can specify just how fast/slow by the part number. Also, by modulating the LED current, you can vary the resistance as well (with the lag factor built-in).
Lord..... :deadbanana:
daverj
Vintage Video Wiggler
Post by daverj »
bleeps wrote:Vactrols are a pairing of an LED and a photo-sensitive cell. LEDs don't shut off immediately when you cut the power to them. They fade. That trailing, delayed fade is what gives them their character.
LEDs don't fade in any noticeable amount. The slowest LEDs can be turned completely on or off in a few hundred nanoseconds, while the fastest ones can do it in a tenth of a nanosecond. Most LEDs can put out a square wave of light (completely on to completely off) at well beyond a Mhz.
It's the photocell that has the long response times and slow rise and fall. It's those delayed reactions to the fast changes of light from the LED that give a Vactrol it's slow "rubbery" behavior. The response times of the type of Vactrols used in synths is measured in milliseconds. That's slow enough that we can hear the difference in rise or fall of a CV compared to one that turns on and off quickly.
Basically it is adding a delay and a non-linear slew to the signal going into it. It's possible to create the exact same effect purely electronically, without Vactrols. But it's typically cheaper to just use a Vactrol. And a lot simpler in some applications. Plus people have romanticized and mysticized this antique technology and feel like it's required to get that sound. (but it's not)
Just me
Has enough VCA's
Post by Just me »
And I always thought there was kitten breath inside.
Tim Stinchcombe
Uncommon Wiggler
Post by Tim Stinchcombe »
daverj wrote:Plus people have romanticized and mysticized this antique technology and feel like it's required to get that sound.
And no one has even mentioned ringing yet...
dkcg
Post by dkcg »
Just me wrote:And I always thought there was kitten breath inside.
I thought it was fairy farts. :(
Ebolatone
Oblique Wiggler
Post by Ebolatone »
Please do!
Shouldn't you be paying more attention to food and water
MR-808
Bored by 4/4
Post by MR-808 »
Hysteresis.
Last module completed: Jürgen Haible Tau Pipe Phaser
Yohda
Post by Yohda »
Are you only talking about the way vactrols react to modulation or about the sound too ?
Ime, vactrols filters have a sound i have never heard reproduced. Very soft and smooth.
Jason Brock
just visiting
Post by Jason Brock »
MR-808 wrote:Hysteresis.
There's a home remedy for that now, in case you didn't know.
I bet it has vactrols in it somewhere.
krz
Post by krz »
2nd level harmonics are pleasing to the human ear. 3rd level harmonics from vactrols/tubes are the next most pleasing harmonics ...iirc.
falafelbiels
still learning to wiggle
Post by falafelbiels »
darenager
Bad Mother Fucker
Post by darenager »
^ He don't look pleased, I suspect a faulty vactrol or counterfeit part.
darenager
Bad Mother Fucker
Post by darenager »
Oh yeah ringing, well vactrols love to be rang, simply look at the part number on the side and call them from your telephone (tip, analog phones work best) they are always really happy to speak, so don't feel shy.
Drumdrumdrumdrum
darenager wrote:simply look at the part number on the side and call them from your telephone
:hihi:
Tim Stinchcombe
Uncommon Wiggler
"I don't hear no goddamn ringing!" :lol:
falafelbiels wrote:Image
daverj
Post by daverj »
Vactrol filters, like Buchla 292 and Makenoise QMMG are very simple 12db/oct Sallen-Key filters that would normally have fixed resistors and capacitors, and be set to a specific single frequency. The Vactrol allows them to be voltage controlled. A dual gang pot would allow them to be manually controlled the same way, without a Vactrol.
Because the resistance of dual Vactrols, like those used in those filters, are not very accurate, instead of getting a true 12db/oct adjustable filter it's more like two 6db/oct filters with the frequency settings not matching or tracking exactly. So the resulting slope is going to be more like 6db/oct for a little range of frequencies, and then 12db/oct above that.
sduck
experimental use of gravity
Post by sduck »
In other words they actually sound like shit. We just like it that way cause we've gotten used to it.
sduck
Post by sduck »
I wonder what ever happened to that guy who was trolling for advice here a while back - he wanted to design his own version of a LPG, but without vactrols because he hated them. He liked everything else about LPG's, except for the fact that they had vactrols in them.
