Piston Honda MKII
Digital Audio Electronics - discussion & support.
bucketbrigade
Re: Ext. In?
Post by bucketbrigade »
governor blacksnake wrote:
hazycomet wrote:Hey, I'm new here! I was wondering if someone could explain the Ext. In section of the PH Mk.II better than the manual. Is the external signal in modulated by the internal osc and then fed back to the ext. Out? Is it applied also to the internal out at all? Any patch examples for this feature? Your help is greatly appreciated, thanks!!
The external signal is attenuated by the "GAIN" control and then fed "through" the piston using the currently selected wavetable as a lookup. So, instead of using the Internal section's ascending sawtooth waveform to address the waveform memory, it uses whatever you put into that jack. Use a sine wave for effects like the Buchla 259e.
Patching this section is straightforward - oscillator into the EXT IN jack, audio coming out of the EXTERNAL output, CV modulating the GAIN parameter. I recommend using any leftover oscillators in your patch with this feature, as it's a convenient way to get an interesting waveform out of something else.
I've been getting excellent results plugging all sorts of things into the external input... never having had my hands on a buchla I was wondering what aspect of a 259e is replicated by feeding it a sine wave? I mean, I'm doing it right now and it sounds all kinds of awesome, I know that much :tu:
governor blacksnake
ant in the afterbirth
Re: Ext. In?
Post by governor blacksnake »
The "gain" knob functions much like the "warp" control on the 259e, and certain waveforms give you similar sonic results if you use a sine wave as input (the synthesis functions being performed are very similar in that case). The red and green waveshaping modes on the Hertz Donut are intentionally reminiscent of my favorite tables from old revisions of the 259e using this same variable-gain waveshaping scheme (red 6 and one of the green ones).
coldvvvave
Post by coldvvvave »
Hello, guys.
My PH mk2 just started behaving weirdly, first it failed to power up even while everything else in my Doepfer LC6 did power without a problem. I did some module moving on this rail right before powering up but didn't touch PH.
After a while it started showing some symbols on the screen. First it was one "F". Then two "8"s. Then just a part of a symbol. I tried powering it up on a Tip Top Uzeus, same result.
Then it started flashing the screen for half a second after powering up and then blacking out.
Anyone else had this problem? It'd be a real shame if it just died like that. :sadbanana:
UPD. I just noticed that it does produce a sound even in this state. Both internal and external outs are the same sawtoothy sound. Ignores all controls. Range button is red.
Then it stopped working again.
governor blacksnake
Never heard of a PH unit just dying like that. Check to see that the voltage regulator (small green board) is consistently putting out 3.3V, that part may need replacement. Reloading the firmware may work as well - contact support@theharvestman.org to arrange service if you're still having trouble.
coldvvvave wrote:Hello, guys.
dysonant
Post by dysonant »
Sinamsis wrote:Bumping this thread. I just bought a PH mk II and I'm considering getting the expander and EEPROMs. How have people filled the 2 missing slots? Has anyone else made EEPROMs for the PH?
Did you ever figure this out? About to buy the expander and some ROMs, but also confused about the 2 extra slots?
If you want to reach me hit me up on the New York Modular Society Discord
Sinamsis
Post by Sinamsis »
Sure didn't. But I snagged a mk I as well that had the expander with EEPROMs (6 of them) so I used it to load up the mk II.
dysonant
Post by dysonant »
I went ahead a bought the expander B. Smith expander rom set and the board. Should be getting them sometime later this week. Does anyone know what to do with the extra slots if one does not have access to extra ROMs?
Voggg
Post by Voggg »
dysonant wrote:I went ahead a bought the expander B. Smith expander rom set and the board. Should be getting them sometime later this week. Does anyone know what to do with the extra slots if one does not have access to extra ROMs?
B. Smith now supplies two more ROMs. I bought the full ROM set directly from him (you can also buy just the extra two). He posted about it somewhere around here.....
dysonant
Post by dysonant »
Super helpful. Thanks!
tommygee
Post by tommygee »
Is the wave shaper in PH mkII identical to the wave shaper in the Hertz Donut mkII ?
robbasvenna
Post by robbasvenna »
I just want to say a great big ol' THANK YOU SO MUCH to everyone who posted demos in this thread - they really made me pull the trigger on the Piston Honda. And now it's sitting in my rack. And I'm completely blown away! :love:
mheumann
Post by mheumann »
tommygee wrote:Is the wave shaper in PH mkII identical to the wave shaper in the Hertz Donut mkII ?
No. The PH is a wavetable oscillator, meaning the wave shaping comes when moving from wave to another, while the HD's waveshaper takes a basic wave (like a sign) and shapes it in different directions.
coolshirtdotjpg
Post by coolshirtdotjpg »
I recently recorded a track focusing on PH MKII and Erbeverb, there's a lot of CV rapidly changing parameters of the PH.
[soundcloud url="https://api.soundcloud.com/tracks/239624590" params="auto_play=false&hide_related=false&show_comments=true&show_user=true&show_reposts=false&visual=true" width="100%" height="450" iframe="true" /]
Last edited by coolshirtdotjpg on Wed Dec 30, 2015 10:51 pm, edited 1 time in total.
New video on Prophet 12 Drone Patches:
mt3
Post by mt3 »
:fap:
:nana:
coolshirtdotjpg
Thanks! Seriously wish I could remember how I did that!
Infinity Curve
Post by Infinity Curve »
Anybody have a link to the wave256 software? All the links I can find for it to the Wiard site are dead
s_d
Post by s_d »
here you go:
wave256.zip
(432.06 KiB) Downloaded 12 times
s_d
Post by s_d »
did this a while ago, using Timothy Leary's sample as a PH wavetable:
http://soundcloud.com/scannerdarkly/rom ... -wavetable
edit: here is the direct link as SC link doesn't seem to be working:
Infinity Curve
Thanks for the link!!
Cool track
Infinity Curve
So Ive got myself a pickit2, but I am having issues doing the firmware update.
I've tried this on 2 different PC's, both running windows 7, dont have anything else to run it on.
First I downloaded the new version of MPLAB(3.20) and on both machines it does not see the pickit2 connected at all.
Saw that the pickit2 originally came with v8.70 so I downloaded that and now it seems to see the pickit2, but I am getting the following:
First I get a pop up with:
PKWarn0003: Unexpected Device ID: Please verify that a PIC18F452 is correctly installed in the application (Expected ID =0x420, ID Read = 0x0)
Then this in the PiCkit 2 box:
Initializing PiCkit 2 version 0.0.3.63
Found PiCkit 2 - Operating System Version 2.32.0
Target Power not detected - Powering from PiCkit 2 (5.00V)
PiCkit 2 Ready
Now if I import the firmware hexfile, it shows up in the BUILD header, but if I hit the Program Target Device button I get the following:
Then:
Programming Target(time and date info)
Erasing Target
Programming Program Memory (0x0 - 0x1FF)
Programming Program Memory (0x208 - 0x5E6F)
Verifying Program Memory (0x0 - 0x1FF)
PK2Error0027 - Failed Verify(Address=0x0 - Expected Value 0x200 - Value Read 0x0)
PiCkit 2 Ready
Problem is, none of the instructions on the harvestman site match what I am seeing in either the newer software or the older one, the buttons and functions he notes are not there, and I cannot tell if the firmware has been transferred or not? My unit always booted to x and y lit, but I know I got it long before the newest firmware was released, so that isn't telling me anything either.
Can anybody tell me what is going on based on above? Did it transfer? Am I doing something wrong? I've looked around in the interface and I see nothing related to any settings for the PKWarn0003: Unexpected Device ID: Please verify that a PIC18F452 is correctly installed in the application (Expected ID =0x420, ID Read = 0x0) I keep getting either
Would really appreciate some help to get this sorted
mt3
Post by mt3 »
s_d wrote:did this a while ago, using Timothy Leary's sample as a PH wavetable:
:party:
old gregg
Post by old gregg »
found it, I guess...
but does anyone knows about to grab (simply) the numerical data (numeric tab) from the wave256 software ?
or does the source code exist somewhere ?
it's a nice tool for creating waveforms.
mt3
Post by mt3 »
Infinity Curve wrote:So Ive got myself a pickit2, but I am having issues doing the firmware update.
Not sure if this helps, but this is PIC info for another module:
http://delptronics.com/documents/Trigge ... Update.pdf
They mention some troubleshooting issues.
ianross
Post by ianross »
Can you guys confirm that you have similar behavior. Figured I could get a quick answer here.
Some combinations of banks don't have a new waveform which seems strange. For example try this:
set X Y Z to 0 0 0
Now move Y or Z from 0 to 1 (but not both)
The wave is the exact same on mine. Is this the same for everyone?
Ras Thavas
Post by Ras Thavas »
I've noticed that before, but I believe it's tied to the interpolation. I remember noticing no changes in sounds at the extreme ends with interpolation on, but when turned off I could hear that last (or first) waveform clearly.
I usually leave interpolation on for X and Y, and off for Z, that seems to be the best middle ground.
ianross wrote:Can you guys confirm that you have similar behavior. Figured I could get a quick answer here.
set X Y Z to 0 0 0
Return to “The Harvestman”
