Both the Rubicon and the Teezer are among the nicest sounding modules in my kit; but there are some clear differences, especially at low fm-index and linear tz-fm amounts. And I don't have anything patched into the sync inputs of either VCO (so things get a bit more KLANG-orous towards the middle of the track than they need to be in a non-demo composition).
the audio is very raw - sine wave outputs from each module (normal sinusoid for the Rubicon), with both VCOs tuned with Initial Frequency all the way to the left, and FM dialed down to zero, then brought to a stop by rotating the Init Freq control towards the center until o-tool scope trace shows the flat-lines... in this particular recording (the one i liked the best out of a few that were made), one of the VCOs isn't quite at center. So that may be giving it a more tonal output at low index / fm-amount. But they sound rather close at higher index / fm-amount (see 1:40 - 2:10 or so).
For the melody I patched Maths-slewed Brains/Amem-pitch-sequenced Intellijel Dr Octature sinewaves into the TZFM inputs of the VCOs (aka, linear FM with AC coupling selected for the Teezer) and gradually turned up the linear FM control pots to create the melody. the VCOs (and Maths rise and fall parameters) were also being sequenced by the Brains.
...anyways i figured this should go here, since the Rubicon is Eurorack format, while the Teezer is 5U MOTM-format. Thus this seemed like the most logical place.
cheers
