Make Noise Dual Prismatic Oscillator.
Two Audio demos.. now time for sleep......
http://soundcloud.com/raglani/make-noise-dual-prismatic
http://soundcloud.com/raglani/make-nois ... rismatic-1
Ooh. Wow, its so bouncy/rubbery sounding. Thanks for the audio only demos. Definitely gives a better impression of the sound. Hmm. I realy wish I could test this along with my CB and HD. I fear I'd want to keep all three though. The HD (temporarily) has to go!
What else is going on here? Rene sequencing? What other modules are in play?
- Count Edlington
mb123music
- Votek_Mendo
@ Qu.One
Having an HD, 2x Antis, 2 CBs, and a MBDO... I'm kind of with you.
OTOH, none of those sound like this:
I know the DPO is it's own thing. But IF the bass/fm has a similar
quality, I could make a spot for it. So far, from the online DPO
demos I've heard, I'm not hearing whatever is catching my ear
on that 259 video. Could be the way Dan/Rewire is patching it.
5,159 custom drum samples for electronic music
made from 4 modular systems, drum modules, and some nice analog outboard processing
202 Instruments for Ableton Live/Push (128s), NI Kontakt, and Logic EXS24
41 Kits for NI Maschine, FXPansion Geist, Ableton Drum Racks, and Octatrack Sample Chains
http://www.drivenmachinedrums.com
- vanderLooy
- amnesia
Thanks for your demos Raglini!
With this and Kents euro dual VCO life is going to be phun!
Cray discography https://www.discogs.com/artist/11643-Cray
VICmod Records http://www.vicmod.net/catalog.html
You Tube https://www.youtube.com/user/cray56
I love the AO, but I can understand what raglani is saying about it getting muddy with tons of modulation. I really think that's one of it's unique attributes, when I was comparing modulation (including the same wavefolder) between two dixies and two AOs the other day for a patch I found the AO was much "softer" and smeared sounding. It's very musical for a lot of situations, but it's not as defined.
It sounds like the vactrols in the DPO are causing that same lag/slew when changing FM parameters quickly and it most likely has a cleaner sound because of the ability to have sine folded on the output instead of triangle. Triangle can sound killer being folded but it tends to have a more nasally quality to it than sine sometimes.
The AO is one of my fav oscillators of all time, no doubt about it... but I do wish it at least had a sine output and/or symmetry control for the folder. You also can't really sync it and here you have two options for sync.
What does the X-LOCK jack do on this?
Well I love the limitations, i've never used a wavefolder with symmetry but I almost always manage to get nice things from the AO.
It definitely doesn't take as much FM as others without getting messy, but like mentioned it always does nice things for me within the limitations of it.
It can certainly be complimented by other oscillators and doesn't do everything that I want.
I also find that some complex filtering from multiple filters/LPG with some tuned resonance helps me to manage the treasure seeking.
PS the AO has some lag when changing strong FM and it has no vactrols.
- ultrashock
- Veteran Wiggler
ok  that was awesome. thanks for sharing!Entrainer wrote:@ Qu.One
this might sound sacrilege to some, but i'd love to hear it with non-makenoise stuff as well.
Qu.One Instagram
Qu.One Bandcamp
Qu.One on YouTube Music
https://instagram.com/sixteensteps.sounds/
https://sixteensteps.bandcamp.com/
Qu.One Instagram
Qu.One Bandcamp
- elektrokick
Getting wiggly with it.
- mayanspring
jnlkrt
