Intellijel uScale 2.0
hpsounds
the french icelander
Post by hpsounds »
Just got the answer from Intellijel headquaters:
It was less than a 1ms but it was not as fast as 50uS; somewhere in between.
n0rd
Post by n0rd »
hpsounds wrote:Just got the answer from Intellijel headquaters:
I wonder whether it's "somewhere between 50us and 1ms" because the time varies or because it hasn't been measured accurately? :despair:
:tardis:
intellijel
Post by intellijel »
I measured it with a logic analyzer many many months ago and I simply don't remember what the actual value was. I did play with code at the time to try and get the lowest value I could. Also the latency can vary a bit depending on what processing mode you are in since some of the modulation settings can require more calculations (time).
The trouble for Quantizers is that they are part of an open system being fed potentially noisy signals and they have to do a lot of filtering and oversampling in order to make sure that they record an accurate and stable value.
The more filtering/averaging and oversampling you do the more latency it generates.
oootini
Post by oootini »
...wrong place to add a request to save last prog on power down?
that would be so nice.
BTG
Post by BTG »
Does this mean that the quantization time can vary, introducing jitter (and not just latency) to the timing?
Dcramer
Post by Dcramer »
I've experimented with mine and it's very fast, even audio rate. You can get some very cool stuff by using it to FM filter cutoff at audio rate and of course instant musical phrases when patched in a more conventional way. :tu:
L.C.O.
Post by L.C.O. »
just to make sure that i am not missing something obvious:
is there a way to save a default setting, that the uScale will always start with when turned on?...
... or does it always simply start blank?
Dcramer
Post by Dcramer »
I think it always starts blank, yes you can save user scales but need to get to the from the user bank.
onthelees
Post by onthelees »
:despair: My local Store says these are backordered now - any ETA on when more will be available?
L.C.O.
Post by L.C.O. »
Dcramer wrote:I think it always starts blank, yes you can save user scales but need to get to the from the user bank.
yeah. being able to save scales is great, i was just hoping to be able to save a kind of default setting. Would super nice!
Dcramer
Post by Dcramer »
onthelees wrote::despair: My local Store says these are backordered now - any ETA on when more will be available?
I bet you can order directly from the website, shipping was incredibly fast when I got mine last month! :party:
contrasttx
Post by contrasttx »
Sorry to resurrect this thread that hasn't had any posts for a month or so, but this didn't seem like it was worth starting a new one over.
Is there anything I definitely should or should not be doing to get the shift input to work? I got a used uScale II recently and haven't been able to get it to do a thing. Tried a bunch of sources, combinations of modes, and so on, but definitely haven't eliminated the possibility that I'm overlooking something...
Dcramer
Post by Dcramer »
I think the shift input has a programable target, you have to tell it if you want A, B or both outs to be effected by it.
Could that be it? :hmm:
d.thomas
Post by d.thomas »
Using the uScale II with a Z8000 for sequencing and Ive noticed that some times the uScale wants to select two notes at the same time and glitches out. By glitching out I mean two notes light up and flicker back and forth and send noise out of A and B. This happens more often when shifting is involved. Anyone else experience this? Normal behavior?
exper
Post by exper »
d.thomas wrote:Using the uScale II with a Z8000 for sequencing and Ive noticed that some times the uScale wants to select two notes at the same time and glitches out. By glitching out I mean two notes light up and flicker back and forth and send noise out of A and B. This happens more often when shifting is involved. Anyone else experience this? Normal behavior?
Contact Intellijel. There's a firmware update that fixes this.
d.thomas
Post by d.thomas »
Thanks! Will do.
10 Miles High
Dedicated uScale II manual ?
Post by 10 Miles High »
Will there be a dedicated manual for the uScale II ?
REVIVER
Re: Dedicated uScale II manual ?
Post by REVIVER »
10 Miles High wrote:Will there be a dedicated manual for the uScale II ?
No real need for it....functions are the same....the only differences between the two are listed in the very first post of this thread:
Main changes:
-6HP panel and much bigger graphics (in two colors!)
-Skiff friendly depth
-uni/bipolar cv switch added to the panel
-16bit super low INL error TI DAC which translates to +/-0.0005V accuracy for pitch CV.
-price $230 MSRP (small increase in price to cover more expensive parts)
Footkerchief
Post by Footkerchief »
General uScale question: is there a "manual mode" that ignores the V/oct input and instead uses the pitch of whatever button was last pressed? Seems like it'd be helpful for "testing" a scale.
Footkerchief
^^^ Anyone?
Blender
Post by Blender »
Footkerchief wrote:General uScale question: is there a "manual mode" that ignores the V/oct input and instead uses the pitch of whatever button was last pressed? Seems like it'd be helpful for "testing" a scale.
No, Footkerchief it doesn't have this kind of mode. Agree that it would be fun to have but I think it is easy enough to test a scale with something like a LFO and an attenuator or a sequencer.
Footkerchief
Good to know, thanks!
Epignosis567
Post by Epignosis567 »
Is there a manual for uscale ii? The old manual is all I can find and it references buttons that aren't even on the mkii. Or am I missing something?
L.C.O.
Post by L.C.O. »
Epignosis567 wrote:Is there a manual for uscale ii? The old manual is all I can find and it references buttons that aren't even on the mkii. Or am I missing something?
nope, you are not missing anything. manual for MkII has always been missing. Maybe with a new firmware update (hopefully soon) there will be a revised manual?
f33d
Post by f33d »
bumpidy bump for "we are silently waiting for the new firmware" :-) :deadbanana:
