wiard miniwave
Discussion and support for Wiard Products
Moderators: Kent, grantrichter, carygrace
Pascal
wiard miniwave
Post by Pascal » Sat Jan 28, 2012 4:19 am
is the wiard miniwave the same as the waveform city in terms of wavetables?
MN3005
Post by MN3005 » Sat Jan 28, 2012 5:02 am
no
Pascal
Post by Pascal » Sat Jan 28, 2012 5:14 am
nothing more to add?
Babaluma
Post by Babaluma » Sat Jan 28, 2012 8:17 am
in terms of wavetables it's exactly the same (if you have the same eproms fitted), but the wiard waveform city also contains a very nice analogue vco (plus some other bits), to drive the wavetable part. with the blacet miniwave you need an external oscillator.
Pascal
Post by Pascal » Sat Jan 28, 2012 8:21 am
how many different eproms are out there?
where can they be purchased?
sorry for asking too much
Babaluma
Post by Babaluma » Sat Jan 28, 2012 8:40 am
what format are you wanting? in wiard there's the 300 series waveform city, in frac there's the miniwave (also in Modcan i believe), but if you have a Euro system you might want to wait for the new Wiard/Malekko Megawave, which will include just about all the EPROMs that have ever been made, plus many other stunning new features!
www.muffwiggler.com/forum/viewtopic.php?t=50754
there's a lot more info about the available EPROMs and their authors in that thread. i used to have the regular one, the socket rocket, the scale quantiser and the morphine ones, and they were all good.
fac
wig MUffler
Post by fac » Sat Jan 28, 2012 1:08 pm
Could we say that Unkle Osc + Megawave is more or less a Waveform City?
Norman_Phay
Post by Norman_Phay » Sat Jan 28, 2012 1:35 pm
Unkle osc + Mini/mega wave + AR envelope generator + VCA + multiple = more or less a waveform city.
Pascal
Post by Pascal » Mon Jan 30, 2012 1:03 am
thank you all
chamomileshark
Post by chamomileshark » Mon Jan 30, 2012 5:21 pm
Actually the standard EPROMs for the miniwave and most Waveform City's are slightly different.
The Waveform City has several wavetables based on analogue waveform morphs. I think about 3 or 4 wavetables are different.
Key Gear: Wiard 300 Series, EMS VCS3, Frac Modular (Blacet, Wiard, Bananalogue & Synthesis Technology).
Pastoral Music: Mark Ellery Griffiths
Music: https://markgriffiths.bandcamp.com/
Experimental: Mark Dalton Griffiths
Music https://markdaltongriffiths.bandcamp.com/
Roycie Roller
Death Row Wiggler
Post by Roycie Roller » Mon Jan 30, 2012 8:47 pm
Pascal wrote:how many different eproms are out there?
There's at least 10-12 designed specifically for the W City & Miniwave, but some early digital synths also used eproms for wavetable storage & as far as i know, they are for the most part interchangeable pin-for-pin, eg. Ensoniq ESQ-1 & SQ-80, whose wavetables can be downloaded here (a file only- you'll have to burn your own eprom, or find someone to do it)-
http://www.buchty.net/ensoniq/
Ready-to-go eproms are sold on ebay for use in the Ensoniq's, and i think there's a place that sells them along with OS updates.
David Hylander sells quite a few eproms & an expander pcb to house them-
http://www.hylander.com/miniwave.html
Muff forum member Bricks programs & sells some as well, but on smaller 8-pin chips (used in the Piston Honda), though he may be able to do the larger Wiard size to order. I think he also custom burns eproms, eg. he might be able to burn copies of the wavetables in the Harvestman Piston Honda (but i'm not sure).
http://www.paperkettle.com/home/m%c2%b5town/
I've seen at least one other person here offering to burn wavetables onto eproms for a small fee.
Also, you can DIY and buy an eprom burner & make your own wavetables using Wiard's wave256 software (.zip file at the bottom of the article). The possibilities are endless if you DIY- you could experiment with scales, audio-rate chord & tone generators, octavers, noise, etc, etc :)
http://www.sonicspot.com/wave256/wave256.html
And Blacet also sell a couple (blacet.com)...
[url=http://]frankdeath93.tumblr.com[/url]
[url=http://]www.youtube.com/user/isledemort[/url]
oozitron
solder fume huffer
Post by oozitron » Mon Jan 30, 2012 9:01 pm
There's also the thing that Cary Roberts made... a custom SMD chip that has a larger wavetable in it (32x32 I think). It has the entire PPG wavetable on it. Of course the LED indicators don't show you exactly what table/wave you're on, but it sounds excellent so who cares!
With the larger number of waveforms, it can change pretty smoothly from one to the next. It required adding a few wired connections, but nothing difficult. I don't know how many Cary made, but mine's not going anywhere ;-)
Drew
Pascal
Post by Pascal » Wed Feb 01, 2012 12:23 am
thank you
a scanner darkly
Post by a scanner darkly » Wed Feb 01, 2012 2:27 pm
You could also get some Miniwave ROMs for Piston Honda from Hylander. It's $170 for 5 ROMs so might be better to save money for Megawave but if you're just after one particular ROM and want to use it with your PH you might want to give it a try (disclaimer - I don't have these so can't vouch for it, saw it in the PH ROM thread in the Harvestman forum):
http://www.hylander.com/mdroms.html
EDIT: was just re-reading that page and looks like those are not actually Miniwave tables but rather Matthew Davidson's ROMs for Miniwave which you could also get for PH.
Pascal
Post by Pascal » Sat Feb 04, 2012 1:36 am
thanks
Return to “Wiard”
