Source for MOTM Frac DIY
phasebash
Post by phasebash »
With the recent movement of all MOTM DIY (5U) parts to Bridechamber, where does one obtain DIY panels and PCBs for Frac / 3U MOTM modules?
e-grad
Post by e-grad »
I doubt that there were any Frac panels for MOTM modules available ever. At least not by Paul/Synthtech. Definately never any pcbs for Frac.
However, I've built some MOTM pcbs for my Frac systems and could even maintain the pcb-mounted pots. MOTM485 and MOTM190 fit nicely behind my Frac panels. I designed them myself and had them manufactured by Schaeffer.
The same goes for some Oakley boards.
Avatar: A lusona by the Chokwe people.
elektrograd
BananaPlug
Post by BananaPlug »
You can just barely fit a MOTM440 behind a frac panel.
That was one of my earlier bananafication projects. Blacet sells blank panels with pilot holes pre-drilled in his 2x6 pattern. This is a butchered one of those with a thin plastic overlay for legends. Not the best way.
phasebash
Post by phasebash »
e-grad wrote:I doubt that there were any Frac panels for MOTM modules available ever. At least not by Paul/Synthtech. Definately never any pcbs for Frac.
Just making sure I'm understanding this correctly, these MOTM 5U PCBs fit behind a 3U Frac panel?
e-grad
Post by e-grad »
Some of them, yes! Chances are that any 5U-project that has 3 pots only in a vertical row will fit behind a Frac panel.
Just have alook at a pic of my Oakley Noise (first version):
A pic of my MOTM190 and MOTM485 would look similiar.
However, those projects with 4 pots in a row (300VCO; 510Wavewarp.) won't fit.
elektrograd
phasebash
Post by phasebash »
NICE! This looks totally doable! That settles it dude, I'm going to Frac-ify the Oakley/MOTM modules I desire. Don't expect any pictures soon, but when I do get to it I will post photos. Begin emoticon abuse: :sb: :sb: :sb: :sb: :sb: :goo: :goo: :sb: :goo: :mrgreen: :love: :razz: :oops:
phasebash
Post by phasebash »
For anything larger than the Blacet 3" panel sizes the Paia blank panels look promising too.
Norman_Phay
Post by Norman_Phay »
I repaneled my MOTM440 and my MOTM300s behind frac panels that I designed using front panel designer. They are tight, but will fit, and I intend to repanel all of my other MOTM modules. Making sure the PCB is perfectly centered vertically is crucial as there is like 1mm of clearance on either side. Somewhere on Blacet's site is a diagram showing the height measurements for their knobs, and if you follow this, it's possible to reduce any MOTM panel to frac size without losing any fuctionality. You have to use smaller knobs!
fluxmonkey
Post by fluxmonkey »
i usually abandon the panel-mount pots when doing frac builds of 5u pcbs... the spacing is too wide in the smaller format, and it limits design options. instead, i mount the board on brackets and run flying wires to the pots.
www.fluxmonkey.com
phasebash
Post by phasebash »
Where could I find these brackets you speak of?
fluxmonkey
phasebash wrote:Where could I find these brackets you speak of?
in the sheet metal section of a good hardware store; some assemble required. i use aluminum, drill first and then bend them in a vice.
www.fluxmonkey.com
