Let's see your performance case!
Live patching, designs, and techniques that push the performance envelope.
scottmoon
Post by scottmoon »
I cut way back in size for something really portable. It all fits in a lightweight aluminum case for transport. I also use Battery on my laptop for percussion sounds.
"If you think this world is bad, you should see some of the others" - PKD
My band's noise https://soundcloud.com/lunarasylum
stwerewolf
Post by stwerewolf »
wreccage wrote:Couple of pics from our recording session
There's a naked Benjolin in the corner and a soundbox on the BD which was connected to the ride via a DIY spring contact mic.
The drums are used to trigger the modular. We recorded with a cello which sounded great and really worked alongside the synth/drums. When we played a gig last month we found the cello was too quiet even when micd up. Deciding whether to put it through the modular, through a decent bass amp, or both :twisted:.
Is this at Suburban Home?
ginorobair
Post by ginorobair »
Something new for this Saturday's performance in San Francisco during the Outsound Music Summit with the group Tender Buttons. Still sorting things out, but there are 3 voices going on here (one with stereo panning).
Tom Djll will have his Enclave case and Eurorack modules on the other side of the stage. (If you're in the area, it'll be at 8pm, August 1st at the Community Music Center, 544 Capp Street @ 20th in SF.)
Modular user since '81: I have systems in Frac, Eurorack, and banana jack.
maxime.annah
Post by maxime.annah »
Hi! Even if the case has changed, can you explain partially the interaction between the drum and the modular, give an idea of your patch (not ALL the patch!) and the kind of sounds you make with your drumodular?! As a former drumer I'm really curious ... and keep us informed when you'll have sounds from this session !!!
wreccage
Post by wreccage »
:cat:
Yes it is! Have you recorded there? Matt is a top guy and our tracks sounds ace!
maxime.annah wrote:Hi! Even if the case has changed, can you explain partially the interaction between the drum and the modular, give an idea of your patch (not ALL the patch!) and the kind of sounds you make with your drumodular?! As a former drumer I'm really curious ... and keep us informed when you'll have sounds from this session !!!
Hey! We recorded 2 tracks on the day and re-patched adhoc for each session so I can't remember specifically. Looking at the image above I can see the triggers are controlling clocks, resets, uScale pitch shift, and the Basimilus Iteritas. Oh and I used a floor pedal to control Frames. I tend to mult the hits so a trigger will control a number of elements specific to one sound/patch/sequence. Sorry that's probably a bit vague. Next gig/recording session I'll make some decent patch notes to share. Type of music we play is dark ambient, doom jazz, industrial style.
federicochiesa
Post by federicochiesa »
Absolutely love the tweed!
101010oxo
Post by 101010oxo »
That was my setup last night. Played with a bass player (who played through the SDD 3000). Great evening! :sb:
First night out with the Hordijk modular! :tu:
bleeds_on_keys
Location: Anywhere between Worcester MA and Pittsburgh PA
Post by bleeds_on_keys »
My little modular. :)
When I play in bands, I've got it interfaced with and controlled by my Minibrute to make a big lead synth, but when I go solo it functions standalone as a noisemaker until I get the time to build myself a Penrose.
I gotta get out and play some more gigs.
MYSTICISM AND WITCHCRAFT
bleeds_on_keys
This is the full, compact setup: Image
This is the full, less compact but still pretty manageable setup: Image
revoltcrews
Post by revoltcrews »
moved from a 12u 104hp into this bad mammajamma...
9u @ 126hp. easy to move. keeps my patches for the stage.
lightweight.
revoltcrews
switched from those flip out legs to a rugged guitar stand.,
holds my 9u 126hp snug for the stage!
no more hunchback of wigglerDame
MindMachine
weekend warrior
Post by MindMachine »
revoltcrews wrote:no more hunchback of wigglerDame
:hihi:
Nice case too. What is it? Did you have to put rails and power in?
revoltcrews
:hihi:
thanks !
its a Zero Haliburton suitcase.
My friend, a local pdx custom case wizard, Ritzy Sheens, put this together for me.
He had to cut custom 126hp rails/frame for it, and install power.
So, yeah, it was a blank slate.
Absolutely love it..
He's available for all manner of custom jobs :sb:
gein
Post by gein »
my little groovebox
bleeds_on_keys
gein
Loving the open spring reverb tank.
Helmey
Post by Helmey »
Here it is....my live rig.
stwerewolf
Played my first few solo shows ever this week with Blanck Mass, Gabe Gurnsey, Sun Araw and some others, this is the setup I've been using:
Mainly on a drone/kosmische/minimal tip, going for a Harmonia, Cluster, Kraftwerk, Terry Riley kinda thing.
Some of my music here: http://xammusik.bandcamp.com
stwerewolf
wreccage wrote:
:cat:
Yeah I play in a band with him, that's where we practice! I'll have to ask him if I can hear your tracks (if you don't mind)
MindMachine
weekend warrior
stwerewolf - that is a sweet setup and fine Casio.
revolt crews - 'Ritzy Sheens' what can I say. Sounds like the name of a Tubes character.
:hail:
Montgomery Word
Post by Montgomery Word »
revoltcrews wrote:moved from a 12u 104hp into this bad mammajamma...
lightweight.
Wonderful setup! Jeremy's making a 104hp 9U bamboo case for me right now, and your case makes me even more excited!
moogboy
Post by moogboy »
Did an improv set last night with this setup. Make Noise Shared System (plus a few things) for live sampling of the Memotron and a smidge of DPO drone.
carlfunkenn
Post by carlfunkenn »
Fidgit wrote:the sequenced eventide FX rig of electroscape
:eek:
FrankMurder
Post by FrankMurder »
I built two cases 9U104hp each. Building two more in the new year "base" style.
I will put a couple of videos for good measure as the photo is missing some modules:
bentoncbainbridge
Little synth
Post by bentoncbainbridge »
José Vargas made this case for our students at School of Visual Arts MFA Computer Art department. Later we moved the Row 30 to the back (power supply has a compartment to hold it as well). Final configuration of this synth contains MVIP and Maths.
Image[/img]
video synthesis demos playlist: http://shorturl.at/corJV
justintonation
Post by justintonation »
dogoftears wrote:Image
My custom Goikes 6U slanted performance case.
See it in action here:
Cool I am planning a similar wiard malekko orientated rig with pressure points etc.
Return to “Play Out! Performance Modulars”
