Is that all being powered by the 4 tiptop uzues in the centre of the rack???FSK1138 wrote:
this will be live@
MODULAR NIGHTS
Casa del Popolo
JAN 16 2014
4873 St Laurent Blvd,
Montreal, QC H2T 1R5
Let's see your performance case!
- hollowman
- blind rhinoceros
Beautiful broken machine.
hawklord2112 wrote:
then again my first two modules were a vca and PLL, wth do i know?
- sean process
- sean process
Setup for jazz band
the most important track you'll ever make is the next
https://soundcloud.com/doom_asylum
https://soundcloud.com/wade_blazer
- transistor logic
- Veteran Wiggler
Really nice! Something like this is exactly what I'm looking for, would it be possible to get some info on the case?[/quote]
Thanks, it's an old toolbox I had. It's very shallow , especially the lid, so it's hard to squeeze all the modules in. But it's the smallest 9u+1u I've ever seen.
If you want I can measure the interior dimensions, so you can build one yourself or let casebuilder build one for you.
Here's my little euro rig controlled via silent way and lemur:
It's part of a larger ableton setup that looks like this:
The ipad does a row of cvs that i can scale and quantize and three rows of gates. I also play cv and gate from the push. I generally use that to control the braids and the Ipad does everything else. It's a lot of fun.
- myecholalia
muffin this looks very similar to what I have in mind for a live setup (modular, ableton, silent way, iPad), but I'll use a monome and arc instead of a push. Can you comment on the Allen & Heath dj controllers you are using? I assume you don't use their sound card but only the controller part, right? For my setup I would probably need a few physical faders and buttons for ableton control as the monome is used for instruments and step sequencers. So, I'd love to hear your comments on what you use the A&H for and what you think about hardware and driver quality. Thanks!
- falafelbiels
- still learning to wiggle
The A+H is pretty good. Id like more knobs, but its the only thing out now that is like this. hardware quality is fine. its a little plasticy but seems sturdy enough so far. i like the zip up case it comes with. no drivers needed, plugs right in and works. well at least on mac. don't bother with layers, they are not well implemented. Also there is no editor software to change message types or numbers.myecholalia wrote:muffin this looks very similar to what I have in mind for a live setup (modular, ableton, silent way, iPad), but I'll use a monome and arc instead of a push. Can you comment on the Allen & Heath dj controllers you are using? I assume you don't use their sound card but only the controller part, right? For my setup I would probably need a few physical faders and buttons for ableton control as the monome is used for instruments and step sequencers. So, I'd love to hear your comments on what you use the A&H for and what you think about hardware and driver quality. Thanks!
I use it as a dub mixer kind of set up. first 6 channels are for track control, volume, hp, lp, aux send, encoder for repeat/loop. channels 7 + 8 control effects. the buttons beneath each fader i use to turn effects on/off per channel. Basically my first four channels are audio from live, the 5th is a drum rack of plugin synths that i control from push, and 6th is audio from the mini modular/ipad setup.
- revoltcrews
John Noble
- Pining for the fjords
This is pretty full-up, I don't usually have the little Mackie on the same stand:
Go make some music.
http://prettyhowtown.net
solaris
- Location: ̋͋̋̋̋̋̋̋̋̋̋̋̋̋̋̋̋̋̋̋̋̋̋̋̋̋̏̏ ̏ ˳̊̊̊̊̊ ˳̥̥̥̥̥̊̊̊̊̊̊̊˳̥˯Ξ̿̿̿̿̿̿̿̿̿̿▂ ̋̋̋̋̋̋̋̋̋̋
DIY portable case attempt, a little work in progress (not as nice as a lot
of stuff seen here but I have two left hands):
Cheap suitcase from local hardware store
No drill in this house. Ripped off the original fixed hinges and puched
some new holes.
Separable hinges work rather good, despite really approximative measurements...
Nice 6U frame from clicks&clocks.
wtf?! I finally opted to waive the nut, the frame fits tight anyway.
Used shorter screws and some washers on the outside, seems enough.
That's it for now. I don't even have a PSU transformer to power it up
(neither I have a VCO yet, ahem.)
some new holes.
▂̵̶̵̥̤̳̤̇̈̄̅̈□ □ □ □ □ □ □ □ □ t r a n s f e k t i o n ▔▔▔▔╲▂▂▁▂▂̵̶̵̥̤̳̤̇̈̄̅̈▂▁▁
▂̵̶̵̥̤̳̤̇̈̄̅̈□ □ ▂̵̶̵̥̤̳̤̇̈̄̅̈▂̵̶̵̥̤̳̤̇̈̄̅̈▂̵̶̵̥̤̳̤̇̈̄̅̈□ ▂̵̶̵̥̤̳̤̇̈̄̅̈▔╲▂̥̥̊̊̊̊▂ ::.:::.h++p://z.x-xx---x.info □ □ □ □ □ □ □ □ □
From a gig two weeks ago
And here is the recording, hope you enjoy it!
http://soundcloud.com/contracommunemopi ... nft-zurich
Not able to embed it
nrvana8775
[/img]
[/img]
