And yet another euro player.
Discussion and support for Alyseum products.
Moderators: Kent, AlyseumSupport
mantiwhore
Post by mantiwhore » Fri Jul 29, 2011 1:39 pm
:miley:
Xaoc Devices | Leidforschung Verlag | Instagram | Facebook
WTB/T: Dewanatron Triple Slice, Sefari mk.1
Popski
The Cake is a Pie
Post by Popski » Fri Jul 29, 2011 2:01 pm
how dare they clearly label the power connections!!
goes against tradition
pulplogic
Post by pulplogic » Fri Jul 29, 2011 2:13 pm
This is interesting. Any idea what the CV resolution is?
Popski wrote:how dare they clearly label the power connections!!
You better label it when you put -12V at the top.
asterisk
Post by asterisk » Fri Jul 29, 2011 2:25 pm
interesting.
Junk Rhythm
Big Bottom Shaker
Post by Junk Rhythm » Fri Jul 29, 2011 3:10 pm
The Alyseum MS-812 is an embedded computer Board, using Ethernet network to Convert MIDI or CopperLan messages to CV and digital control voltages as used in modular and analog synthesizers.
This first Alyseum product dedicated to modular synthesizers offers 8 CV outputs and 12 digital outputs.
A SYNC24 interface is included as an alternative function on digital output jacks.
MS-812 are supplied ready to use, the actual linking is managed via the CopperLan Manager software. This freeware tool is also used to monitor the status of all CopperLan computers and equipment. The module can be controlled from any computer anywhere in the network.
The MS-812 is built around a powerful 32-bit processor offering 120 DMIPS.
Features in MIDI mode
•Modular MIDI interface to 8 CV Out and 12 Digital output.
•100% MIDI compatible via CopperLan.
•Free assignment of MIDI channels and controllers.
•Full MIDI range (128 notes= 0 to plus 10 Volts 2/3).
•Multiple simultaneous clock outputs.
•MIDI to SYNC 24 converter.
•100 Base-T Ethernet interface.
•Auto-MDIX allows using straight-trough or cross-over UTP cable.
Features in CopperLan mode
Same as above, plus:
•Full CopperLan pitch range = from minus 10 Volts 2/3 to plus 10 Volts 2/3.
•Octal high-resolution converter - 16 bits (Analog Device).
•Each CV Out can be used as note, setting or modulation.
•Each DIG Out can be assigned as a Gate, Clock, Reset, control, ...
•VoiceID management.
pulplogic wrote:This is interesting. Any idea what the CV resolution is?
Looks to be 16-bits.
jfloftin
Post by jfloftin » Fri Jul 29, 2011 5:04 pm
Interesting device...
stk
Post by stk » Fri Jul 29, 2011 6:20 pm
Very interesting
mamonu
90s ambient miscreant!!
Post by mamonu » Fri Jul 29, 2011 7:01 pm
and whats more....
frac too...
very nice :)
the gods of modular are smiling upon us...
blz
Post by blz » Fri Jul 29, 2011 7:05 pm
desire/lust rising........
barcat.blogspot.com
http://waveformcity.blogspot.com/
I beat my brain tumor that makes me indestructible right???
Junk Rhythm
Big Bottom Shaker
Post by Junk Rhythm » Fri Jul 29, 2011 7:15 pm
Listed for 399.00 € at Schneidersladen
JJ
Post by JJ » Fri Jul 29, 2011 7:22 pm
This video describes copperlan quite nicely:
Yeuky
Post by Yeuky » Fri Jul 29, 2011 7:47 pm
You just totally stole a module I've been working on for 3 months.
Anyhoo, looks great! :yay:
paults
mice nuts
Post by paults » Fri Jul 29, 2011 7:57 pm
I will make a guess the DAC is this part:
http://www.analog.com/static/imported-f ... _5669R.pdf
Which according to specs is ~ 14bit accuracy on average, could be 12-bits if you get a 'bad one'. Should be fine for most folks.
True 16-bit accurate DACs are about $15 each. For 1 output :deadbanana:
You can of course mux that if you also hold the signal path to that accuracy over temp (which is also expensive, requires 0.1% low ppm resistors and low DC drift op amps like a AD822).
Matos
Modular masturbator
Post by Matos » Fri Jul 29, 2011 8:03 pm
:ripbanana:
SMS303
Tha BABELFISH Wiggler...
Post by SMS303 » Fri Jul 29, 2011 8:21 pm
Matos wrote:This is the first I've heard of such a technology. Peter kirn should write up an overview to explain the possibilities.
+1.... and some realtime use vids, please 8_)
Do i understand the possibillities well:
it does work like Doepfer's MCV24 but,
it ain't use MIDI but LAN connection directly from your computer which sent control data from Ableton/Cubase/etc?
there's so many delicious sweetness in the modular candyshop....
can't have them all :deadbanana:
------------> Jaime Murray does Capua...... ------------------------------------------>
ignatius
Post by ignatius » Fri Jul 29, 2011 8:44 pm
what are the digital outputs all about? i'm missing something.
Junk Rhythm
Big Bottom Shaker
Post by Junk Rhythm » Fri Jul 29, 2011 8:55 pm
ignatius wrote:what are the digital outputs all about? i'm missing something.
Most likely gates/triggers/clock.
Yeuky wrote:You just totally stole a module I've been working on for 3 months.
There is always room for more. :guinness:
ignatius
Post by ignatius » Fri Jul 29, 2011 9:03 pm
ok. that makes sense. i got thrown my the labeling i guess.
asterisk
Post by asterisk » Fri Jul 29, 2011 10:11 pm
i wonder if this thing can do more discrete CV steps in copperlan mode than in midi mode?
also, would be interested to see if this module would work with max/msp.
mr chombee
Post by mr chombee » Sat Jul 30, 2011 3:12 am
Great module. I just wish it also had some CV/gate inputs.
JJ
Post by JJ » Sat Jul 30, 2011 3:57 am
There is an very informative discussion about CopperLan on KVR:
http://www.kvraudio.com/forum/viewtopic ... highlight=
Ankh
Post by Ankh » Sat Jul 30, 2011 4:26 am
The product descriptions are bordering on too technical. So can this be used with say Silent Way, or is all it does convert MIDI to CV through some virtual MIDI port? Or is it something else entirely? :despair:
poladark
Post by poladark » Sat Jul 30, 2011 4:43 am
I love the idea...
But... from a purely technical standpoint.... There doesn't seem to be a public document specifying the protocol - yet they claim that the CopperLAN protocol is "open". Not using IP seems like a serious disadvantage. How are you supposed to use this with existing network infrastructure? Can i use my enterprise class Cisco switches and routers with CopperLAN? What if i want to collaborate with a person downstairs or in a different office? The advantage of using Ethernet with CopperLAN is not so obvious if I'd have to design a physically separate network to use it.
If i wanted to invest in CopperLAN audio infrastructure it would need to be a technically sound solution.
JJ
Post by JJ » Sat Jul 30, 2011 8:31 am
Download the copperlan software and try, it's free.
jln
Post by jln » Sun Jul 31, 2011 3:03 am
I must say I am really excited by this product. I saw a demo (including a midi->CV prototype) quite some time ago during a conference at Ircam in Paris and it was veeeery impressive.
asterisk wrote: also, would be interested to see if this module would work with max/msp.
This will work with Max using Midi ports.
Actually, a CopperLan external was even developed within the Plateforme Virage. THIS is the real deal as it not only allows send/receiving values but also building and querying the network of CopperLan devices, etc. The bad news is although the external is still available from here, it is currently broken since some changes in the CopperLan SDK.
I think it is also worth mentioning that there has been some discussion/desire to develop or port such an external as a plugin for the upcoming 0.6 implementation of Jamoma Modular in Max. Just hope some dev will jump in to make it happen soon.
Return to “Alyseum ”
