How many of you have 100% DIY modular (or close)?
- Rod Serling Fan Club
- aquatic hitchhiker
Just a silly topic out of curiosity. I suspect I will always have a bit of euro to cover some aspect not readily available in DIY but I could see selling off most of it once I cover a lot of my bases with DIY. I’m curious what others are doing.
Outside of my MOTM-650 for MIDI to CV I'm 100% DIY.
For Sale - Gen 3 LZX Sysyem
drewtoothpaste wrote: ↑Sat Sep 12, 2009 11:43 am I do 100 reps on the cutoff knobs of each of my filters when I wake up in the morning.
luketeaford wrote: ↑Sat Aug 12, 2023 5:47 pm Please also advise where to buy the most historically accurate weasel sweatpants.
- infradead
- leader of the secret trombones
please please please post a picactive wrote:all diy. it is super small but i figured this was the best way to get started! the only thing that isn't "diy" is the f(h) plague bearer and soon the f(h) choices. but my case is in an old stand up arcade!!!
Tacoma Noise Rodeo
Tacoma Noise Rodeo
it's not done yet!infradead wrote:please please please post a picactive wrote:all diy. it is super small but i figured this was the best way to get started! the only thing that isn't "diy" is the f(h) plague bearer and soon the f(h) choices. but my case is in an old stand up arcade!!!
edited: http://cargocollective.com/active
@wmonk - where did you get wood for your faceplates? i need some thin stuff and can't seem to find any.
- falafelbiels
- still learning to wiggle
Maybe I didn't articulate the question very well. All I meant by DIY was not "off the shelf" complete modules from a manufacturer, not the level of DIY involved.
I'm not asking what percentage of your DIY is DIY. I'm asking what percentage of your moduler synth gear is DIY (ie. did you sell off most of your non-diy euro, 5U, etc. once you got to a certain point with your DIY?)
@widdly re: "What modules can't you diy?"
Digital modules don’t seem to be very well represented in DIY land. I will probably be keeping a couple digital VCOs(Hertz Donut, E340/E350, Piston Honda, etc.). I haven’t found a DIY serge SSG, which makes me think I might keep the Sport Modulator around. I will probably keep the pressure points modules as I’ve not seen a good DIY equivalent.
- Ebolatone
- Oblique Wiggler
"I suppose the ultimate synth-DIY is when it turns into a real product,BugBrand wrote:I'd almost class my work as DIY but I'm sure others would disagree!
like the Wiard One system available from Wiard.com"
http://www.musicsynthesizer.com/DIY/Gra ... nthdiy.htm
Shouldn't you be paying more attention to food and water
- fluxmonkey
Mine is 100% DIY - never purchased a module.
bruce
bruce
www.sdiy.org/rfeng
"This is the amplifier, which amplifies the sound. And this is the preamplifier, which, of course, amplifies the pree."
-Bullwinkle
-Bullwinkle
- SMS303
- Tha BABELFISH Wiggler...
rest all factory manufactered or build by others ......
I've got some pcb's in backlog and many unfinished projects on the shelf...
edit...
oopszz.. Falafelbiels is right but the dual vca pcb was factory assembled ....
------------> Jaime Murray does Capua...... ------------------------------------------>
- falafelbiels
- satindas
- Veteran Wiggler
100% including Oak case. Just started a 110% model (etching my own boards)
These are bizarre manifestations of untamed high-frequency parasitic oscillations...
www.psycox.co.uk
www.psycox.co.uk
