Yusynth VC Quadrature LFO demo
- kindredlost
- 5U skiff friendly
Not as complete of a demo as I think should be done to reveal the full extent of the module, but because I finally got this thing to work I decided to video the results of a standard patch. It's a variation of the "Barber Pole" or "Shepard Tone". It sounded like circle track racing or maybe planes dive bombing so I decided to call it...
I used four oscillators and amplifiers and sent each quadrant into a separate oscillator & amplifier pair. The same voltage was split with a "Y" cable and sent to adjacent amplifiers. For instance, if the voltage from zero degree output was sent to oscillator one then the same voltage was sent to amplifier two which had the 90 degree oscillator running through it. The voltage from 90 degrees was sent to oscillator two and the same voltage was sent to amplifier three, etc..
This made the quadrature become the delay envelope to the rising/falling portion of the next quadrant pitch only. When the "direction" switch was thrown, the pitch changed direction from rising to descending.
In this demo the voltage control (FM INPUT) was not used. This is a powerful feature which Yves built into the design.
A demo of using the FM INPUT is in order. I did make a short audio piece using the LFO in that manner, but it is not very clear exactly what is the LFO portion.
Introducing "Nauseated Banjos"...
http://soundcloud.com/david-ryle/nauseated-banjos
The VCQLFO has it's LFO rate modified by a Q119 sequencer which is randomly stepped. The "zero quad" out is sent to an oscillator for pitch. The "180 quad" out is sent to transpose the oscillator further. Both voltages from the LFO are sent through a quantizer first. I used a signal processor on each voltage out to dial in what scale and range I needed.
- emdot_ambient
- bwhittington
- Terrifying Brain Secret
- kindredlost
- 5U skiff friendly
- The Hamburglar
- spinach_pizza
- knobs . . . knobs . . . KNOBS!
- The Hamburglar
- diophantine
- kindredlost
- 5U skiff friendly
@ach_gott : if there is a free download, go for it. If not, let me know how I can get you a copy. PM me. I'm not a big fan of copyright stuff, but I do respect those that make their living that way. Mine is all for fun, not profit.
@spinach_pizza : I've been thinking about it. That first one was a minor blip on the radar, but that wasn't the reason for a release anyway. I have a few good pieces I could cut & paste in to one I suppose. It's just a lot of work it seems.
@diophantine : I etched the PCB. It really isn't hard (or I'd never have done it). I used Radio Shack copper clad boards and ferric chloride. The Iron-on toner transfer method is very easy and works pretty good. The front panel is always the hard part. That was the first legible silkscreen panel I've ever done. Most of the others were abject failures.
Thanks for all the kind comments. I really surprised myself with the "Fireflies" video. That was fun and made me smile.
