As far as music I like and sounds I hope to make... ambient, the more electronic side of Post Rock (think: port-royal, Lights Out Asia, and a little bit of drone.With the modular, I hope to form complex, evolving pads, make weird old school computer-like sounds, and do a little bit of external signal processing.
So with that in mind, here is my rough plan:
Code: Select all
|01)|02) |03) |04)|05)|06)|07)|08)|
| M | M | M |S | M | M | M | M |
| O | O | i |+ R| O | O | O | O |
| T | T | n |H a| T | T | T | T |
| M | M | i | n| M | M | M | M |
| | | w |& d| | | | |
| 3 | 3 | a | o| 8 | 8 | 3 | 3 |
| 1 | 0 | v | m| 0 | 0 | 9 | 8 |
| 0 | 0 | e | | 0 | 0 | 0 | 0 |
|09) |10)|11) |12)|13) |
| | ? | A C | D | U |
| Double | | n o | u | E |
| Deka | | a m | n | G |
| | | l p | s | |
| | | o u | e | |
| | | g t | l | |
| | | e | | |
| | | r | | |
|a) Control-3 / Mults / Little Lag(?) |
|14) |15)|16) |17) |18)|19)|20)|
| T | C | ? | M | M | M | M |
| h | r | | O | u | O | O |
| r | o | | T | l | T | T |
| e | g | | M | t | M | M |
| e | l | | | i | | |
| l | i | | 1 | M | 1 | 1 |
| e | n | | 2 | i | 9 | 9 |
| r | | | 0 | x | 0 | 0 |
|21) |22)|23) |24) |25) |
| m | E | D | F | |
| i | F | e | r S | Neural |
| d | G | l | e h | Agonizer |
| i | | a | q i | |
| D | | y | u f | |
| A | | | e t | |
| C | | | . e | |
| | | | r | |
|b) Power Switch / Mults / FourMix(?) |
1x MOTM-300 UltraVCO
1x DoubleDeka
1x Miniwave
1x YuSynth S+H & Random
1x 2 MOTM-800 Envelope Generator
1x MOTM-390 uLFO
1x MOTM-380 Quad LFO
1x CGS Analog Computer
1x Tellun Dunsel
1x Universal Event Generator
1x Threeler
1x Oakley Croglin
1x MOTM-120 Suboctave Multiplexer
1x Oakley Multimix
2x MOTM-190 uVCA
1x Oakley midiDAC
1x EFG
1x Some sort of delay module
1x Some sort of frequency shifter
1x Neural Agonizer
1x Oakley Control-3
That leaves me with 3u empty. I'm considering either a second MOTM-310 or a CGS Digital Noise and another filter for the other 2u. Any recommendations? Some people have recommended a LPG; would that be useful for the sort of sounds I want to make? I've also been considering a MOTM-410 or a CGS Serge VCF along with a second Oakley filter. Or is there something completely different out there that I should think about?
As far as power distribution goes, I plan to have a single large power supply in the bottom case and use a set-up similar to the set-up used for two dotcom portable cabinets. However, I've read that the ASR in the Analog Computer requires a very clean power supply; would this set-up be a problem?
~Chappie
