5u -> 3u
- Christopher W.
- Lord of Tweed Manor
1/4->1/8 cables or adapters will work, but you should probably consider connecting the 3U and 5U PSU grounds.Christopher Winkels wrote:You should be good to go with just the cable.
I made this for all of my format conversion needs. It has 6 groups of multiples, 2 each of bannana jacks, 1/8" and 1/4". The lines between lead to switching jacks that connect those multiples when a cable is inserted. The whole thing can be connected with 2 patch cables!
drewtoothpaste
- Christopher W.
I have a wiard noise ring in my eurorack. I cut an adapter plate for it, so as the frac module mounts to the adapter, and then the adapter mounts to the euro subrack.
I considered making some of these for 5u systems, but i think someone allreddy does?
I figured somthing like a 5u by, say, 3u panel, cut for mounting a selection of euro modules in the front, and some 3.5mmm to 1/4 inch 'multiples' in the spare space along the bottom. And a power pcb to regulate the 15v down to 12v.
Either that, or, of course, euro pcbs could be properly converted to 5u, with the same knob spacing, etc. (basically keeping the pcb alone, and replacing the front panel, and all front panel components)
_________
I make parts for synthesisers!
Instagram - https://www.instagram.com/thebeast.co.uk/
Website - https://www.thebeast.co.uk
_________
- kindredlost
- 5U skiff friendly
its one of the black fronted ones... theyre not as pretty as the blue ones anyhow : )
_________
_________
blasphemyjulian wrote:its one of the black fronted ones... theyre not as pretty as the blue ones anyhow : )
That's a great looking piece of kit - best looking multiples I've ever seen!Bryan B wrote:I made this for all of my format conversion needs. It has 6 groups of multiples, 2 each of bannana jacks, 1/8" and 1/4". The lines between lead to switching jacks that connect those multiples when a cable is inserted. The whole thing can be connected with 2 patch cables!
- dslocum
- darwin's nemesis
Late with a snide reply, but - WHAT A WHORE!megaohm wrote:drewtoothpaste wrote:Sell your 3U and buy more 5U![]()
So... what about those modules that have no equivalent in 5U?
REFITS!!!!
Custom Work !!!!
Feel free to PM me.
Doug Slocum
Synthetic Sound Labs
www.steamsynth.com
www.steamsynth.com
Thanks! I only made 2, kept this one and sold the other to the ToneWrecker. He also later had me modify it to have more bannana to 1/8" conversion so it now looks like the mult of Frankenstein.werock wrote: That's a great looking piece of kit - best looking multiples I've ever seen!
