Distortion module
HelloMellow
Distortion module
Post by HelloMellow »
Can some of you give me some advice for distortion modules in the 5U format? I'd really like some warm analogue distortion to my setup.
Keep it mellow and drink more tea :)
7thDanSound
Off patching
Post by 7thDanSound »
Not exactly distortion per se but the STG WaveFolder is nice. Jumpering the .com Q107 for hard clipping is nice too.
BugBrand
Knowledge of Bugs
Post by BugBrand »
Possibly Oakley?
http://www.oakleysound.com/overdrv.htm
(I don't know why I'm answering this - I have zero to do with 5U!)
Just me
Has enough VCA's
Post by Just me »
Trouby makes one, also.
Bryan B
Post by Bryan B »
I am in the middle of a repanel project for converting my Turbo Rat pedal into a module. It has been a lot of fun and I learned a bunch about distortion types. I have the Wavefolder and the clipper rectifier from Dotcom and never use them for distortion.
Spiked Lunch
Massive Synth Wanker
Post by Spiked Lunch »
The Dotcom clipper/rectifier is not great as a distortion module as it pulls down the signal strength during the process.
The Rat is the most dynamic and versatile distortion unit ever! Everything sounds good though it!
http://soundcloud.com/mikelynch/fuzz-machine
Double tracked Vermona DRM II
HelloMellow
I've actually found out that I wanna get one of these or both:
Malekko Barker Assmaster
Dr.Scientist Frazz Drazzler
They sound amazing :)
Bryan: Maybe I'll do something similar! Could you please post some DIY or pics from your project? :D
fac
wig MUffler
Post by fac »
Synthesizers.com Q118 Instrument Interface does a decent job.
Megaohm filters also distort nicely.
wyrtti
Muffdiver's Helmet
Post by wyrtti »
I really like the Oakley Overdrive module. It has two different settings, overdrive and distortion. The overdrive part can be really subtle and the distortion get raunchier. I like the overdrive to add a little grit and warmth.
Also works great with a bass guitar, gives it some more balls.
Eschew obfuscation!
HelloMellow
I'll be sure to check out the modules you are mentioning :D Thanks for the tips!
Bryan B
Post by Bryan B »
I will post pics as soon as I can. It is a blank panel with a bunch of switches, jacks and pots in it so far.
It will have a center off switch to allow germanium or Silicon diodes as well as another center off switch to allow red or white LED's. My favorite mod so far is also putting diodes into the distortion drive circuit, which as I read it makes it more like a Tube Screamer. I like the sounds I am getting when I test it out.
I agree with the above, the MegaOhm Delta filter can do some great distortion as well as other things. That filter is worth checking out for sure!
Tronman
Post by Tronman »
I just ordered a STG Signal Amp because it has a really nice, natural overdrive and will allow me to replace 2 Q108's.
SepticUnderground
Zombi Wiggler
Post by SepticUnderground »
I really like my dual 5U plague bearer for distortion!
Ive got the oakley too, but thats way more subtle than the PB
BTW the journeyman VCFs have also a nice drive sound :)
http://soundcloud.com/septicstudio
FREE ALBUMS! http://www.jamendo.com/en/artist/Septic_Underground
Stopped with becoming the biggest 5U slut in the world
sduck
experimental use of gravity
Post by sduck »
:agree: This one:
Dual Plague Bearer front by sduck409, on Flickr
There's also the MOTM 510 -
And this one can add all sorts of distortion:
Toppobrillo Triple Wavefolder front by sduck409, on Flickr
Return to “5U Format Modules”
