More music with the Grove Audio PMR and the Q150
- spinach_pizza
- knobs . . . knobs . . . KNOBS!
Here is another piece exclusively using the Grove Audio PM Resonator and the Dotcom Q150. I really like using these two filters in tandem.
http://soundcloud.com/spinach-pizza/alm ... er-orlande
- bwhittington
- Terrifying Brain Secret
- doctorvague
- ole fuckity fuck
- spinach_pizza
Thanks, guys, for listening!
John, no I don't have the dotcom reverb. I use plugins for reverb, ever since my MX400 died (and I've never bothered to get it fixed). I use the plugins that came with Sonar, plus I really like Reaktor Spacemaster!
Doctorvague, the piece was written for 8 separate vocal parts, and how many times each was overdubbed varied depending on the particular phrase and my "orchestration" of that phrase. Each "voice" is variously represented at any given time from one recording to three sometimes four recordings. Each recording captured two or three oscillators in tandem.
- kindredlost
- 5U skiff friendly
- spinach_pizza
Hi David, thank you.kindredlost wrote:I can't imagine the work this took. Truly skilled sound design Richard. I'm amazed at the blend considering the amount of voices.
How do you decide the shape of the PMR filter for each timbre? Is it predetermined or do you just tweak until it shapes what you're after?
I don't predetermine much with the PMR, I decide by ear when I tweak. Actually for this piece, I pretty much ignored the lowest band, and I'd say that at least 80% of my adjustments were frequency and gain for the two higher bands. I used it in bandpass, both normal and extended ranges.
- Jason Brock
- just visiting
- Christopher W.
- Lord of Tweed Manor
- Bob Borries
- Ultra Wiggler
Carlos Quality
WOW this is Carlos Quality, what a ringing endorsement for the PMR. Still patiently waiting for mine.
- spinach_pizza
Re: Carlos Quality
Thanks!Bob Borries wrote:. . . the PMR. Still patiently waiting for mine.
Still patiently waiting for John Burdick to return my emails.
- spinach_pizza
Re: Carlos Quality
John Burdick is a great guy to deal with, and I feel bad that I complained here when he is swamped with stuff to deal with.spinach_pizza wrote:Thanks!Bob Borries wrote:. . . the PMR. Still patiently waiting for mine.
Grove Audio modules are top notch in build quality and in function!
When you say each voice is 1-4 overdubs, is because each was played with a different timbre/patch to build up the end sound? Meaning if you had 4x the modules, you could have played the voice in one pass?spinach_pizza wrote:Each "voice" is variously represented at any given time from one recording to three sometimes four recordings. Each recording captured two or three oscillators in tandem.
Or was it more simply to get a thicker or chorus-y effect due to micro timing variations?
I hope I made that clear enough, I realize it's sort of a subtle distinction...
- spinach_pizza
Hi, I think I understand your question. One of my goals with my recordings to sound like an ensemble of a bunch of instruments or sounds all being played together. This is true for each track I've put on Soundcloud, whether "synth" sounding or not.relaxing wrote:When you say each voice is 1-4 overdubs, is because each was played with a different timbre/patch to build up the end sound? Meaning if you had 4x the modules, you could have played the voice in one pass?spinach_pizza wrote:Each "voice" is variously represented at any given time from one recording to three sometimes four recordings. Each recording captured two or three oscillators in tandem.
So to achieve that feel, I prefer to record each overdub separately, with differences (often subtle) in timing and other settings as well. For a given part of the music, the patches are usually the same or very similar, but with the parameters altered slightly or manipulated a little bit differently each time it's played. If I did have 4x the number of modules I wouldn't want to record them all in one pass, because I don't think that I would be able to adequately control the expression of each individual voice.
It's very time consuming, but I think it's worth it.
Got itspinach_pizza wrote:Hi, I think I understand your question. One of my goals with my recordings to sound like an ensemble of a bunch of instruments or sounds all being played together. This is true for each track I've put on Soundcloud, whether "synth" sounding or not.relaxing wrote:When you say each voice is 1-4 overdubs, is because each was played with a different timbre/patch to build up the end sound? Meaning if you had 4x the modules, you could have played the voice in one pass?spinach_pizza wrote:Each "voice" is variously represented at any given time from one recording to three sometimes four recordings. Each recording captured two or three oscillators in tandem.
