relaxing wrote:Just buy a QPS2 and you don't need anything else!
That is a good choice if you want to stop at eight modules. Otherwise, it isn't cost-effective in the long run.
The one other thing you will need with the Dotcom power supply is a handful of .156 MTA connectors to make the cables compatible with MOTM, Modcan, etc.
[EDIT: Updated for closed end part numbers.]
For most MOTM, you need this (4-pin):
http://www.mouser.com/ProductDetail/Tyc ... uvEz0RI%3d
For the couple of MOTM modules that use 5v, you need this (6-pin):
http://www.mouser.com/ProductDetail/Tyc ... 2bC6vPk%3d
And for Modcan, you need this (3-pin):
http://www.mouser.com/ProductDetail/Tyc ... VVedv9U%3d
To keep it simple, I just bought the 6-pin version and let the unused portion hang off the header. The power connections are usually on the edge of the boards, and I haven't run into a module yet that has caused a problem. You can decide that for yourself.
In summary, what you need to power multi-formats are:
-Dotcom power components (QPS1, Q137, and cable harness
or QPS2 if you prefer. This part is dead easy to hook up.
-24 awg MTA connectors for each module you want to add from a different format. To change out the connectors, you just pull the old one off and crimp the four wires into the correct position (this info is in one of the power stickies).
Optional: There is a hand tool to aid in crimping the wires. a tiny screwdriver will work as well, but if you are going to be doing a bunch of them, it may be worth the investment:
http://www.alliedelec.com/search/produc ... KU=5270170
Each of these pages includes the manufacturer's part number. You'd probably do better cost-wise by checking a parts retailer on your side of the pond.
Cheers,
Brian
