Download the latest version of the editor from here:
https://patchstorage.com/author/hal9000mg/
The template is totally free but if you want to support the project make a donation via Paypal!
Thanks and have fun!
Impossible! The editor I tested it too many times! You should show me an image with the messages you send!
Ok! I don't know how I can help you... Let's see if anyone has the same problem!ThenCameNow wrote: ↑Tue Feb 21, 2023 3:39 pm I'm trying to understand. I restart TouchOSC and sometimes it works, other times it doesn't. Sometimes it won't change algorithms although if I'm in the same algo then it works. This is all intermittent.
I'll get back with more later.
I believe that's a setting in the Disting... Try to contact os!ThenCameNow wrote: ↑Tue Feb 21, 2023 3:52 pm I've reset the Disting. Now there are some things I'd like to know. In Augustus, The feedback is 100% at mid fader. Is this a setting in the Disting ? How can this be scaled to use the full fader?
i got it working.. it was the jumpers on the backs of the modules. i had them both set to CV rather than Select Bus, from previous attempts at getting it to work prior to this new template coming out..
This is what I get with the fader... A little out of the ordinary but it's fine for me!ThenCameNow wrote: ↑Tue Feb 21, 2023 4:04 pm Is that the case in your setup ? Or do you have full fader for feedback in Augustus ?
I look forward to it! Unfortunately just when you released the new Editor, I won’t have access to my Disting EX for the next week. Irony!hal9000.mg wrote: ↑Tue Feb 21, 2023 12:55 pm Anyway I uploaded the patch, try it and let me know if you like it!
