https://www.thingiverse.com/thing:957376
I've been using 5x7cm strip boards as various utility modules. Like one has 6 pots, 2 mono jacks, dip switch cluster, 2 push buttons. Another has 6 audio mono audio jacks with eurorack power input. It takes a lot of time to solder the traces on some of these.. like hours it seems.
I put SIP sockets on the boards for easy jumpering with 22 awg solid core -- standard breadboard wire.
Anyways I am going to start making lots of various 5x7cm PCB's via JLCPCB, which I call "BLOCKS" -- as in building blocks.
My first couple will be a breadboard and a stripboard -- these strip boards should be much stronger than the cheap warped strip boards I've been using.
Each PCB from JLCPCB this size is around a dollar or so including the cheapest shipping.
They'll all be 5x7cm so they'll fit nicely with the rest. I will also have a shorter version at 2.5cm tall with same 5cm width. On each side of the breadboard holder I can hold either 2 x 5x7cm or 2 x 5x7cm + a single 5x2.5cm. I have an arduino nano on a single 5x2.5cm as an example use.
Here is an image of what I am talking about:
I guess the reason I went with the 5x7cm is that is the size board which I had on hand and is the perfect width really for PCB's hanging off the side of this.
What's really nice about this breadboard holder, in addition to holding 6 PCB's, is that it all stays together.. you can hold it in one hand and turn it any direction including upside down and the entire things stays put.
I'll share all the gerbers and Kicad files here once I verify they function like I want
Anyways here's a little 10 second youtube video of my first PCB I've designed and am going to order.. actually already placed the order with JLCPCB. It was $6 including shipping for 5 of these:
I decided I am going to go with white for all these just because I think it looks nice.
Three examples:
