Oakley phaser
OurDarkness
Oakley phaser
Post by OurDarkness »
Hey guys,
I have been listening to the Roland PH-830 phaser and really liked the way it sounds. I was wondering if we might get to see a recreation from Oakley? Would you guys be interested?
In what ethereal dances, by what eternal streams
Re: Oakley phaser
Post by Synthbuilder »
OurDarkness wrote: Sat Nov 13, 2021 11:34 amI have been listening to the Roland PH-830 phaser and really liked the way it sounds. I was wondering if we might get to see a recreation from Oakley?
I've been wanting to do a rack phaser for years. The problem with trying to recreate the PH-830 is the behaviour of the Japanese 'vactrols' it uses as the voltage controlled elements. And they don't make them like they used to. I may knock up a 1:1 clone at some point, as I have a few NOS Vactrols hanging around, and then I'll try to get the more modern devices to replicate the sound properly.
That said I had a SPF-323, which is similar to one channel of the PH-830, and I wasn't that impressed. Indeed, I preferred the sound of the much cheaper and simpler RPH-10, but then I have always liked OTA based phasers.
I'm having a bit of a break from electronic design at the moment. Partly because of the current parts shortages, but also because I have a bunch of home improvement tasks to complete. Hopefully, I'll get on with some new design work later next year.
In the meantime you may want to check out the Doepfer A-101-3. That's supposed to sound a bit like the Roland opto phasers although I've not tried one myself.
