Glad you found the error and got it working.tsanderakis wrote: ↑Mon Oct 18, 2021 9:26 am It`s working. Found the problem.The ground from the output was connected to a wrong place at R45. So everything ok now here.
Thomas Henry MPS - 12volt based on Haraldswerk
Re: Thomas Henry MPS - 12volt based on Haraldswerk
Hi there!
First of al thanks to everyone involved in this project, outstanding work!!
I have a question tho : can anyone point me out what wima caps are used for c1 and c4 on control board?
I have a bunch of mks2 (mks2-2.2/63/10a) but they dont fit (13mm height)
Smaller caps i could find are 10mm, which seems to be the same as the space available with the pots.. thanks for confirming its enough!
Also, if anyone is interested, i have 3sets of pcbs+aluminium panels to let go
Cheers
Cheers
- Haralds:Werk
- Ultra Wiggler
Look for the 50V onesf.aiseur wrote: ↑Mon May 29, 2023 9:00 am Hi there!
Cheers
www.haraldswerk.de
Home of Next Generation Formant
- Haralds:Werk
- Ultra Wiggler
www.haraldswerk.de
Thank you mister
Those red capacitors, are they Wimas, and where are you getting them from?I'm in the US and I haven't been able to find any of that value. The 2u2s are what I mean and I need some 6u8s also.
- Haralds:Werk
- Ultra Wiggler
Yes, those are Wimas. You are not bound to a brand as long as the values and the measures are the same. Anybody to jump in where to buy them in US?
www.haraldswerk.de
harpooneer
Tayda has good prices on many WIMA values, Mouser has the rest. They can be tricky to substitute sometimes - most other brands are bulkier!Haralds:Werk wrote: ↑Fri Nov 24, 2023 2:38 am Yes, those are Wimas. You are not bound to a brand as long as the values and the measures are the same. Anybody to jump in where to buy them in US?
