I've just received some panels from a UK panel supplier that I've only recently become aware of. The supplier is www.meface.co.uk and their prices are very reasonable and the quality is excellent. They accept .FPD files as well as other formats so ideal if you're looking to get some Oakley panels made. There are some small differences from panels made by Schaeffer, text can only be printed rather than engraved and infilled and is Silver not White in colour. I don't find this a problem and the Oakley .FPD files don't require any modification. They also supply Euro rack panels and are definitely worth a look if you are in the UK.
Above you can see two 3mm thick 3U wide 5U panels these are the full size panels for two of the Oakley filters, below are a couple of 1.5mm panel overlays for the DCR320, below that is a 3mm thick 1U 19" rack panel that I laid out in Front Panel Designer.
Animal Factory Amplification
New UK Panel Supplier
