Animal Factory Amplification
DigiKey Caps
oozitron
solder fume huffer
DigiKey Caps
Post by oozitron »
Building my ADR30, and there was one mistake (not my mistake!) in my parts order:
Oops...
I have a couple 50volt 47p NPO Xicon Ceramic Disc caps in my old parts stash. Would these be OK to use in the ADR30 (for C54 & C57) ?
Or do I really need to get the C0G caps? (hopefully they would send them to me for free)
Andrew
Re: DigiKey Caps
Post by Synthbuilder »
oozitron wrote: Sat Feb 06, 2021 10:39 pmI have a couple 50volt 47p NPO Xicon Ceramic Disc caps in my old parts stash. Would these be OK to use in the ADR30 (for C54 & C57) ?
Yes. NP0 is the same as C0G. Just different codes for the same product. You'll see on the Digikey label that the caps are described as C0G/NP0.
Your biggest challenge will be find a project for those 6 way surface mount switches. ;)
Tony
oozitron
solder fume huffer
Re: DigiKey Caps
Post by oozitron »
Synthbuilder wrote: Sun Feb 07, 2021 4:44 am Your biggest challenge will be find a project for those 6 way surface mount switches. ;)
Sounds like a challenge for the Oakley Creative Design Team :sb:
Maybe some kind of tiny keyboard controller for slow-moving ambient melodies?
thanks again,
Andrew
