USB Power Supply?
JeebsFat
USB Power Supply?
Unread post by JeebsFat »
Does anyone know of a small USB Power Supply for powering a couple modules? Preferably a DIY kit. Pretty much like this: https://www.synthrotek.com/products/mod ... usb-power/
Just wondering if any other manufacturers have something similar. Looking elsewhere because of... reasons.
Neolithic
Will Flintknap for Bananas
Re: USB Power Supply?
Unread post by Neolithic »
If the reasons are what I think they are, they're damn good reasons.
I don't know of any that are usb and that small. If you can go bigger or are willing to cut them down these might work.
I've built both and can confirm they work well and aren't especially noisy. Prefer the MMI one over the other but if space is a concern, then it might be too big.
https://modularaddict.com/mmi-usbpower-pcb
https://modularaddict.com/timo-usbpowerthingy-pcb
Formerly NeolithicElectrophones
JeebsFat
Those are great! Thanks! Noob question: Anything I need to know about cutting those? Can I just dodge the vias and cut with a clean blade on a chop saw?
Neolithic
Yeah, it'll be fine. I did that on a pedal version of rings and I haven't run into any issues. Just make sure the cut is clean and the traces aren't shorted. If it's being put in a conductive enclosure you might wan't to cap the cut end with non-conductive tape or liquid electrical tape to make sure it doesn't short. I'm sure you know to wear a mask and all that when cutting fr4, but figured better safe to mention than sorry.
FWIW both of those designers are class acts business wise and great people all around.
jamos
Unread post by jamos »
Synthrotek has one, I use it as a bench supply.
Nord Modular G2 & G2X, Emulator X, MPC Live, and a growing Euro system.
modeleus
Unread post by modeleus »
Check out Polyend - Anywhere: https://polyend.com/anywhere/
helix
Unread post by helix »
Polyend anywhere is what i'm after for a DIY portable setup. Can't wait to get it going!
JeebsFat
Polyend Anywhere looks awesome. At first I thought it was kind of pricey, but it says it's 20kmAh! Shame it's tied to a 4hp panel. Is prefer to case mount it.
kinkycables
Unread post by kinkycables »
I think this is the same thing as the MMI? - tinyurl.com/4xb8jf5k
And found this the other daya - https://www.rakits.co.uk/product/go/
noises
Unread post by noises »
I am also looking to see what is out there for powering a single module. I think the power needs are a bit high for the Synthrotek version, and would like USB-C for the higher power spec.
60hz
Uncommon Wiggler
Unread post by 60hz »
burdickjp
Unread post by burdickjp »
