roman 245/246 happiness
levelhead3
Post by levelhead3 » Fri Aug 23, 2019 1:03 am
So there have been numerous threads here and on emcloned discussing the two main problems with the roman 245 and 246 - first that there is a "null" zone on the CV pots' travel from about 3:00 on, where the output voltage maxes out at around 9.4v and after that no additional voltage gain occurs, and second that adjacent stage outputs "blend" together and do not independently trigger a 281r.
I'm happy to say the Dave Brown has come to the rescue and successfully addressed both issues. The CV null zone required the replacement of the CV banks' summing opamps, and a reduction in the the sustained voltage level on the stage pulse output waveforms allowed the 281r to "see" the independent pulses.
He also looked into the pulser & reference waveforms and the clock. These modules are now 100% operational as far as I can test.
As usual complete details of these mods are posted on his website, and I just want to repeat the sentiment of an earlier thread and express my gratitude for his continued support of our community.
Thanks Dave!
Peake
Post by Peake » Fri Aug 23, 2019 3:47 am
:sb: :sb: :sb:
diophantine
Post by diophantine » Fri Aug 23, 2019 12:40 pm
Nice!
Do you know if this was this a problem with the first 245 PCBs that were made available on emcloned? (Not made by Roman, but another user.) I have two, but haven't built them yet...
davebr
Post by davebr » Fri Aug 23, 2019 1:54 pm
diophantine wrote:Nice!
I am aware of another 245 PCB but I don't know if it what you are referring to. Is there any nomenclature on PCB2? You can either post or send a photo to me of PCB2 component side, and a BOM would help.
If it doesn't use 24V or have a DC-DC converter to generate 24V there should be a dead zone, but with the right resistor values, can be pretty minimal. That was my "better" solution on my website.
Dave
diophantine
Post by diophantine » Fri Aug 23, 2019 7:59 pm
davebr wrote:I am aware of another 245 PCB but I don't know if it what you are referring to. Is there any nomenclature on PCB2? You can either post or send a photo to me of PCB2 component side, and a BOM would help.
Thanks Dave - it has cj3000 written on it. I only see a +5V regulator, with a jumper for internal/external +5V. The BOM is around here somewhere...
Will try to take a look at your mod notes this weekend!
davebr
Post by davebr » Fri Aug 23, 2019 10:41 pm
I am familiar with that and can post the reference numbers on my website. You'll have to double check them as I have no way of doing that. Some of the mods are already done. The stage CV outputs are dual op-amps so I'll have to find an affordable rail to rail dual. There aren't many available in DIP.
davebr
Post by davebr » Fri Aug 23, 2019 10:49 pm
diophantine wrote:It has cj3000 written on it. I only see a +5V regulator, with a jumper for internal/external +5V. The BOM is around here somewhere...
I do not have a BOM nor reference diagram for this PCB. If you find the BOM please send it to me. I would also appreciate you scanning your unpopulated PCBs, both sides, and send them to me so I have traces and can make reference diagrams. Scanning works better than photos as the distortion is minimized.
Dave
kashmir
Post by kashmir » Fri Aug 30, 2019 1:27 am
I have the same set of PCBs, there are still unpopulated so I can scan them if yours are already built. I also have BOM and schematics in case you didn't find them yet.
davebr
Post by davebr » Fri Aug 30, 2019 4:10 pm
kashmir wrote:I have the same set of PCBs, there are still unpopulated so I can scan them if yours are already built. I also have BOM and schematics in case you didn't find them yet.
Please do. PM sent.
Dave
