make noise - brains!
so, when no info is being sent to brains, does pp act like it normally would without the brians connection or does the addition/connection of brains forever change the behavior of pp?amphonic wrote:Brains is great. I have been using it with 2 pressure points for a week or so. Very useful 8 step sequencer. If you have a PP, buy it.![]()
damnit i was affffraid you would say that. tony is a fucking badass. now i am obsessively trying to figure out how i can afford and fit this inamphonic wrote:PP works normally when Brains is not in use.dude wrote:so, when no info is being sent to brains, does pp act like it normally would without the brians connection or does the addition/connection of brains forever change the behavior of pp?
- justin3am
- Let's go do some crimes
Wait, I'm confused about this. How many expander cables do I need if I plan on using two Pressure Points with my Brains? Is there more than one way to setup this configuration? Can you, for instance, choose between 2 individual PPs+brains and 2 chained PPs+brains?bsmith wrote:You'll need one - says the manual - if you plan on using 8 stages.
You just need one chain cable to connect the 2 pressure points modules. Each module has 4 stages. Each module has it's own 'EXPND' cable to connect to the Brains. I'm assuming the Brains module will come with 2 of these. If not it looks like they're 10 pin IDC connector ribbons.justin3am wrote:Wait, I'm confused about this. How many expander cables do I need if I plan on using two Pressure Points with my Brains? Is there more than one way to setup this configuration? Can you, for instance, choose between 2 individual PPs+brains and 2 chained PPs+brains?bsmith wrote:You'll need one - says the manual - if you plan on using 8 stages.
Seems like if you're using the brain you pretty much want to have them set up as only 2 chained together - may be wrong. Check out the connection setup in the manual http://www.makenoisemusic.com/BRAINSManual.pdf
OMG it just so happens that I have 4 hp open next to my PP!! gotta get this. I'm looking at a row of a 154/155 combo, a PP and now this!
hmmm since I'm planning 2 155 sequencers, I could move the 154 up a row and fit another PP in there... but can you do less than max steps easily with this? I'm not familiar with the PP yet but I assume there will be a(n easy) way
BRAINS ships with ALL necessary cables for expansion to either 1 or 2 Pressure Points.dude wrote:i think you need five for it to work correctlyMontag wrote:Looks fantastic, but will this not work with my 4 Pressure Points? The manual and description seems to indicate that it's only for 1 or 2 PP's...
The CHAIN cable is only needed for CHAINing 2 or more Pressure Points WITHOUT a BRAINS.
Cheers,
Tony
So just to be clear, with the chain cable and a Brains, it's possible to use 4 PP's with Brainsmakenoise wrote:BRAINS ships with ALL necessary cables for expansion to either 1 or 2 Pressure Points.dude wrote:i think you need five for it to work correctlyMontag wrote:Looks fantastic, but will this not work with my 4 Pressure Points The manual and description seems to indicate that it's only for 1 or 2 PP's...
Cheers,
Tony
No, the CHAIN cable as a Pressure Points accessory has nothing to do with BRAINS. The CHAIN connector (on backside of the Pressure Points PCB) IS used for expansion with BRAINS when 2 Pressure Points are CHAINED to create an 8 stage sequencer, but the cable needed do that is included with BRAINS.Montag wrote:So just to be clear, with the chain cable and a Brains, it's possible to use 4 PP's with Brainsmakenoise wrote:BRAINS ships with ALL necessary cables for expansion to either 1 or 2 Pressure Points.dude wrote:i think you need five for it to work correctlyMontag wrote:Looks fantastic, but will this not work with my 4 Pressure Points The manual and description seems to indicate that it's only for 1 or 2 PP's...
Cheers,
Tony
If you want to make a 16 key controller out of 4 Pressure Points, grab a CHAIN cable. If you want to expand the capabilities of one or two Pressure Points to include sequencing, get a BRAINS.
Maximum number Pressure Points that may be expanded with BRAINS is 2, minimum number is 1.
You will be surprised how useful the 4 stage sequencer is... I know I was.
T
