Created for performance setups with drum modules etc. but there is no reason not to mute the gate of a synth voice for instance.
Toggle multiple channels at the same time (mute on or off) either on the release of the "Group" button or when in "sync mode" at fixed point of the beat.
The sync moment can be chosen while holding the sync button.
The sync selection is:
- quarter note (a.k.a. always start with the kick after the break)
half note (a.k.a. never start with clap on 2)
bar (a.k.a. get the rest in line too)
2 bars
4 bars (a.k.a. free both hands to modulate something else in the break)
For the prototype the sync information is derived from the MIDI input. The final version might receive a selectable Clock&Run sync input. (Jumper selection)
The MIDI input is 3.5mm stereo TRS, with our own invented auto-crossover (directly connect either Korg-like OR Arturia-like devices with a cheap standard cable).
Internal MIDI-Trigger Converter - if you do not pug anything into the input jacks you can use Midi-Notes for the trigger outs.
Please feel free to contact us with input, questions and feature requests.
Target release: November 2017
PT1 .. others down in the thread.
The prototype is a bit wide (12HP) by purpose. As you might think, this is a performance module: I didn't wanted it to be too fiddly.
I am open for discussion there. One suggestion was to move connectors to the bottom and buttons to the top @8HP, but for my drum rack it makes more sense like it is. I also like the space left of the buttons for marking the channel names.
