Grayscale Permutation: expanded Turing Machine + Voltages: back in stock
true, true - looking into this right now actually..though case space is a bit of a problem with the 18hp one. packed to the gills over here!c0nsumer wrote:Should be plenty easy to do this with an external logic module for the times when you want it. I personally use an A-166 specifically for this kind of thing. Way more flexible than what's built into Pulses, too.jwm wrote:ohhh hm i didn't even think about this...one of my fav thing to do with the pulses mk2 is to ping the smr and sometimes have a couple bands strike at once...sempervirent wrote:Yes, I realize that some will miss the OR functions but providing more of the individual bit outputs gives you more options than the fixed choice of 1/2/4/7 on the original.khyber wrote:I will miss combined gates like some of the triggers on Pulses give you
staaaay-shhnn
Definitely in favor of the 12HP. I've grown very space concious and I also know tons of people in the same situation that continously sell off bigger modules to be able to add two smaller ones (even if they like them a bit less).
Also, to be fair, I think 16 gates might be ever so slightly overkill. But that's probably just me
- c0nsumer
I personally don't understand having a 16-step mode but only 8 LEDs and outs, but maybe I'm missing something. I never understood pulses having only 1-7 outputs as well... I felt like something was missing with there not being 1-8.anosou wrote:Also, to be fair, I think 16 gates might be ever so slightly overkill. But that's probably just me
Thus, the 12hp version seems just about right to me.
- windspirit
All of the steps are just shifted version of eachother.c0nsumer wrote:I personally don't understand having a 16-step mode but only 8 LEDs and outs, but maybe I'm missing something. I never understood pulses having only 1-7 outputs as well... I felt like something was missing with there not being 1-8.anosou wrote:Also, to be fair, I think 16 gates might be ever so slightly overkill. But that's probably just me
- sempervirent
Not just yet, will know within the next week or two.c0nsumer wrote:Any idea on pricing?
I agree, this and other small quirks of the TM are what got me thinking about doing an updated version.c0nsumer wrote:I never understood pulses having only 1-7 outputs as well... I felt like something was missing with there not being 1-8.
Right, each output corresponds to one of the bits in the shift register.windspirit wrote:All of the steps are just shifted version of eachother.
And to elaborate on that for anosou and c0nsumer (just in case it was unclear), the pattern is the same on all outputs but it's shifted to the right with each clock pulse. If you want the gate pattern to start on a specific step, you need an output for each of the 16 bits.
If you just want random gate patterns then it's all good. 8 outputs will give you 8 shifted versions of the pattern as it's "read" by the first 8 bits. But having 16 outputs lets you be a bit more intentional with the clear/write switches in terms of programming a specific gate sequence into the module.
Having the clear/write CV inputs also allows you record a gate pattern from another sequencer (like the Algorhythm) and "store" it in the shift register's memory (assuming that the Shift knob is mostly clockwise and the sequence is locked after the pattern is recorded). Then you get 16 time-shifted copies of that pattern, like singing in rounds for lack of a better analogy. With the TM you can only program a pattern using the toggle switch.
Thanks for the explanation! I was aware of that but I still think 8 outputs is more than enough for most systems. Chances are you have more gates than you know what to do with and the cases where you desperately need gate 13 are few and far between, not enough to warrant 4HP. But that's just my opinionsempervirent wrote:Not just yet, will know within the next week or two.c0nsumer wrote:Any idea on pricing?
- fosferus
agree with this. gates aren't difficult to come by, space is. 12hp would be my purchase.anosou wrote:Thanks for the explanation! I was aware of that but I still think 8 outputs is more than enough for most systems. Chances are you have more gates than you know what to do with and the cases where you desperately need gate 13 are few and far between, not enough to warrant 4HP. But that's just my opinionsempervirent wrote:Not just yet, will know within the next week or two.c0nsumer wrote:Any idea on pricing?
That sounds awesome in terms of speed! Of course a natural use of such high rates would be to feed this audio into filters and slew the response which I love to do on my SSF URA!sempervirent wrote:OK, Q&A time:
Not sure what the maximum frequency would be but it's all analog just like the TM. In those faster clips from the video it's getting clocked by the Dixie II in oscillator mode (at which point it becomes a noisy oscillator itself).tbecker wrote:From the videos it seems you can clock this pretty fast, how high have you gone?
Thanks again for all the feedback. Based on comments here and elsewhere, I think doing both versions is the way to go.
- robotsounds
- xonetacular
- sempervirent
When: probably sometime in September, if beta testing goes well. 18hp first, followed by the 12hp version and expander.robotsounds wrote:Sorry if I missed it but when and where will these be available?
Where: direct from the Grayscale site or from the modular shops that we work with.
Here's a cool photo from beta tester Quasi (@paulnormandlebel on Instagram). So far, so good. Also I should mention that the LED brightness has been toned down quite a bit since the demo clips in the first post of the thread, those are mostly from earlier prototypes.
just a quick question:
so the gates outputs are all the same but shifted of one "step" right?
not like Pulses is the TM?
and what the Noise output does?
UI/UX/Sound designer
eurorack + TenoriOn + Omnichord + giant church organ + old rusty piano
current
https://www.modulargrid.net/e/racks/view/361810
selling / trading
https://www.modulargrid.net/e/racks/view/389166
current
selling / trading
- sempervirent
The gate outputs reflect whether or not a bit is "on" for that particular step. So if the sequence is locked, yes, it's effectively the same pattern being shifted to the right with each clock pulse. If the sequence is unlocked you get totally random gates or slowly changing patterns depending on the position of the Shift knob.
So it's basically the same as the Pulses expander, but with outputs for 8 bits (12hp version) or 16 bits (18hp version) instead of four.
Also the pulse width is gated by the pulse width of the clock source. So if you want short triggers on the outputs, change the clock source to a trigger.
The Noise output is just like the Turing Machine, it's the white noise of the internal transistor.
- sempervirent
Hey, thanks. We're one step closer, the 18hp prototype has left the Mystic Circuits synth cave and is headed to Seattle for one more round of beta testing before calling it "done"ol'nasty wrote:I stumbled across these, looking for Turing Machines on Modular Grid. I gotta say these look great! Lots of great features for the hp. Can't wait for them to be released!
Also the Mystic Circuits Switches expander for the Turing Machine was tested for compatibility with Permutation and worked without any issues.
Quick demo by windspirit here:
Will post more details about price and availability soon but it looks like we're still on track for shipping the 18hp version in September, with the 12hp version and expander coming in October.
- xenosapien
- Ultra Wiggler
awesome, I was just yesterday looking at your Algorithm module and thought to myself "if only I could justify having that, it looks beautiful"... and here you go making a module I actually NEED (= a second, slightly different/expanded TM) that has that same sweet style
may you live in interesting times.
- sempervirent
- sempervirent
