Grayscale Permutation: expanded Turing Machine + Voltages: back in stock
- MossGarden
- Ultra Wiggler
Vanderfuzz
- Learning to Wiggle
Happiness Forever
- Veteran Wiggler
dubstephead
- didahdrieghe
same here on the 18hp
if DIY and low cost like the original turing machine i'll take one
UI/UX/Sound designer
eurorack + TenoriOn + Omnichord + giant church organ + old rusty piano
current
https://www.modulargrid.net/e/racks/view/361810
selling / trading
https://www.modulargrid.net/e/racks/view/389166
current
selling / trading
- Eric the Red
- Ultra Wiggler
boundsound
- sempervirent
Thanks everyone, this project has been a long time in the making and it's great to see so many supportive comments.
I'm a little surprised that the 18hp version seems to be the "winner" thus far, my intuition was that the smaller one would be more popular. However I prefer the larger one as well, being able to shift the start point of a sequence back in forth in relation to the master clock is really useful. Might have to do both versions after all.
Gotta run for now, will respond in detail to individual questions later.
This looks exciting!
I like both, but I don't think the extra pulse outputs of the larger version quite justify the extra HPs.
I'd rather see an 18HP version, with a 8 pulse outputs, and some extra functions packed into the extra space.
Suggested extra features for the bigger version:
a|x
- Different shift modes, ie forward/backwards/random
Ability to reset pattern
Option to have sequence evolve (as it existing Turing Machine), or randomise first bit of pattern every step, without feeding back randomised bits, so you can have random variations on a looping pattern, without losing the pattern
Memories to store and switch between stored bit sequences
a|x
spudboyblues
- Veteran Wiggler
My vote goes to the 12hp. I've got a small system and love the Turing Machine, really excited about this idea. If the 18hp ends up as the production choice so be it I might still use the expander to replace the Voltages expander. For the footprint I think the 12hp gives a great amount of functionality, great design too (though I will miss combined gates like some of the triggers on Pulses give you)
bandcamp ∆
- sempervirent
OK, Q&A time:
Allele will probably be a full kit with bare PCBs, the BOM is much more simple and there's room to use larger components.
Thanks again for all the feedback. Based on comments here and elsewhere, I think doing both versions is the way to go.
EDIT: this feature has been added for the final release.Abyssinianloop wrote:Can they recall saved sequences after power cycle?
The DIY version will be similar to the Algorhythm DIY kit which includes a pre-assembled/pre-tested main PCB with all the surface-mount components along with a bare front PCB and the front panel components. The main board for this one is very dense and use 0402 size SMD components, not the easiest DIY build.basicbasic wrote:Will there be a DIY version or just pre-built?
The main module has one Gates expander output, Allele has one expander input. This matches the original TM. The second expander header on the TM was for Pulses, which isn't needed since Pulses is effectively built into the main module.tarmoog wrote:One "gates" expander input only or more?
Yeah, a quantizer is pretty useful with this one. All the short clips in the "supercut" video in the first post used Braids as an oscillator, which has a quantizer built in, so that's a good pairing.jwm wrote:i suppose all this will depend on pricing, but for me, i think i'd prefer the 12hp one, since invariably i would have to pair it with a quantizer.
Considered doing that but the main board is pretty packed and the 12hp board will be even more dense. Having the "grid" of pulses work one way with the expander, and another way without, was also a bit tricky. Having an expander would also increase the overall cost compared to just doing an 18hp version.windspirit wrote:Could you maybeale the 12 hp version and ass the extra features to another 4hp expander? I know that would make a second expansion port but this way everyone gets what they want.
Yes, the PCB files will also be released as open source, that's part of the Creative Commons license. Not planning to sell bare PCBs or panels however.didahdrieghe wrote:Is this being released as open source as well? Sold as pcb/panels?
Not sure what the maximum frequency would be but it's all analog just like the TM. In those faster clips from the video it's getting clocked by the Dixie II in oscillator mode (at which point it becomes a noisy oscillator itself).tbecker wrote:From the videos it seems you can clock this pretty fast, how high have you gone?
Not doing a dual footprint, but you can always make a custom power cable. Some people have done 5U builds of the TM, I believe that it works on +/-15V out of the box, but please verify.Eric the Red wrote:If DIY, would you be able to include MOTM power footprint and have it work on +- 15...
Yeah, that sounds like a much different module than this one! Also I don't think you could fit the UI for controlling presets and all those features into just 4hp. Good ideas though.toneburst wrote:These features would probably only be possible if you used a MCU, instead of replicating the existing TM analogue circuitry.
That's the plan, although if someone wanted a gray panel with red LEDs or black panel with white LEDs we could work it out.ludu357 wrote:is the black panel version come with red LED?
Yes, I realize that some will miss the OR functions but providing more of the individual bit outputs gives you more options than the fixed choice of 1/2/4/7 on the original.khyber wrote:I will miss combined gates like some of the triggers on Pulses give you
ohhh hm i didn't even think about this...one of my fav thing to do with the pulses mk2 is to ping the smr and sometimes have a couple bands strike at once...sempervirent wrote:Yes, I realize that some will miss the OR functions but providing more of the individual bit outputs gives you more options than the fixed choice of 1/2/4/7 on the original.khyber wrote:I will miss combined gates like some of the triggers on Pulses give you
staaaay-shhnn
- c0nsumer
Should be plenty easy to do this with an external logic module for the times when you want it. I personally use an A-166 specifically for this kind of thing. Way more flexible than what's built into Pulses, too.jwm wrote:ohhh hm i didn't even think about this...one of my fav thing to do with the pulses mk2 is to ping the smr and sometimes have a couple bands strike at once...sempervirent wrote:Yes, I realize that some will miss the OR functions but providing more of the individual bit outputs gives you more options than the fixed choice of 1/2/4/7 on the original.khyber wrote:I will miss combined gates like some of the triggers on Pulses give you
