Blind Monk Modular - Programa
illdream
Post by illdream » Sun Nov 06, 2016 11:53 am
Here is the newest module from Blind Monk Modular. It's called Programa.
Programa is a highly controllable 8-bit modulation source / envelope generator that can generate complex yet synchronized control voltages. Inputs trigger the rise and fall of the voltage, hold the voltage at it's current position, reset it back to zero, and change the rise and fall speed. Constantly changing envelope or modulation shapes can be created by feeding the inputs with gates, triggers, LFOs, or other signals. There is additional control for exponential shape of the slope as well as an external clock input for further customization and longer rise / fall times.
Complex yet synchronized modulation source
From slow rise and fall times of 25 seconds or more to a fraction of a second.
Saw and ramp LFOs can be created by holding the pause input high
More basic envelopes can be created by re-triggering the the up or down inputs simultaneously with the reset input
Create bending and twisting sequences, infinitely long envelopes, accent notes, clock divided envelopes
8hp format, skiff friendly
blindmonkmodular.com
Hopefully available in December for $169
Dcramer
Post by Dcramer » Sun Nov 06, 2016 12:07 pm
Cool! What a great idea, and great price :party:
illdream
Post by illdream » Sun Nov 06, 2016 2:17 pm
thanks Dcramer
etheroar
Post by etheroar » Sun Nov 06, 2016 9:43 pm
This looks amazing, what a unique idea! I have the Harmonic Multiplier and it is a gnarly sounding module with a ton of depth and character, so I have high hopes for Programa.
This will be really fun with Tempi...
Al
Post by Al » Mon Nov 07, 2016 7:17 am
What voltages do the inputs expect? What voltages does it output? What are the power requirements? Looks fun....
Abyssinianloop
Post by Abyssinianloop » Mon Nov 07, 2016 11:33 am
I like it. I can easily imagine using this.
FS: Dinky's Taiko, Polaris, Nano Rand
WTB: TiNRS Tuesday
Modulagrid
illdream
Post by illdream » Mon Nov 07, 2016 11:55 am
Al wrote:What voltages do the inputs expect? What voltages does it output? What are the power requirements? Looks fun....
The up, down, pause, reset, and clock inputs need a minimum of 2.5V to trigger their functions. The speed input goes from 0-5V for the full range of speeds, but that is added to the speed knob, so with the speed knob turned all the way up, the input range is -5 to 0V. The output is 0-5V. All the inputs are protected so sending higher or lower voltages to the inputs works fine, such as an LFO.
The power requirements are +12V 12mA, -12V 23mA, +5V 29mA
EATyourGUITAR
has no life
Post by EATyourGUITAR » Mon Nov 07, 2016 1:12 pm
Need like 60 seconds max ramp time and it would be perfect for what I like.
illdream
Post by illdream » Mon Nov 07, 2016 1:49 pm
EATyourGUITAR wrote:Need like 60 seconds max ramp time and it would be perfect for what I like.
If you use some external modules you can get basically any ramp time you want. Feed an external LFO or VCO to the clock input and you can get very long ramp times. Since it is a digital module, you would probably want to add a slew limiter to the output. Not the ideal module for long ramp times, but it can be done.
Summa
Post by Summa » Mon Nov 07, 2016 1:59 pm
are you really sure it's 6HP looks like 8HP to me?? :despair: :hmm:
Paranormal Patroler
Post by Paranormal Patroler » Mon Nov 07, 2016 3:23 pm
Summa wrote:are you really sure it's 6HP looks like 8HP to me?? :despair: :hmm:
Ha! I was just about to post that :hihi: It says 6HP everywhere but the MG is already at 8HP. Wish it were 6HP indeed as I've been looking for a Chronos to no avail. This would be a good replacement if the size is slim (fits right next to my Stohastic Function Generator)
pieter
Post by pieter » Mon Nov 07, 2016 3:36 pm
Sounds great for some wobbly dubstep (and tons of other stuff).
EATyourGUITAR
has no life
Post by EATyourGUITAR » Mon Nov 07, 2016 3:39 pm
I was shocked to hear that it is digital with only 12 ma. you can definitely do long ramps no slew if you have 16 bits. alternatively you could do it in one bit if you have the right RC low-pass filter.
kavehwahid
Post by kavehwahid » Mon Nov 07, 2016 3:44 pm
Excellent!
Paranormal Patroler
Post by Paranormal Patroler » Mon Nov 07, 2016 5:51 pm
Will this be available in Europe ?
illdream
Post by illdream » Mon Nov 07, 2016 6:11 pm
Yes, it is 8hp. I will fix all the listings as soon as possible. I'm not sure about availability in Europe right now. The current draw is mostly on the 5volt rail and doesn't uses low power chips so that keeps the power consumption down.
ignatius
Post by ignatius » Mon Nov 07, 2016 7:13 pm
nice idea! i like this kind of thing a lot. very cool. so many uses for this.
Futuresound
Post by Futuresound » Mon Nov 07, 2016 7:17 pm
Yep, looks fantastic.
I love the graphic design as well.
Can you describe how this works in a little more detail:
illdream wrote: Saw and ramp LFOs can be created by holding the pause input high
md5-
Post by md5- » Mon Nov 07, 2016 7:53 pm
Looks like a fantastic use for all those BSP triggers!! :D
Paranormal Patroler
Post by Paranormal Patroler » Wed Nov 09, 2016 7:46 am
So this works fine with triggers as well as gates? If it makes it to Europe I'd most probably buy one.
illdream
Post by illdream » Thu Nov 10, 2016 10:23 am
Futuresound wrote:Yep, looks fantastic.
The LFO mode or loop mode works by sending a positive voltage to the pause input and then sending a trigger or gate to the up or down input. For example, if you patch a static 5 volts to the pause input, as soon as you send a signal to the up input a continuous ramp wave lfo is generated at the output, as soon as you trigger the down input a continuous saw lfo wave is generated. You can switch between ramp and saw by sending voltages to either up or down. If the pause input drops below about 2.5V the LFO stops. The pause and up or down inputs can be triggered simultaneously as well.
So, as long as the pause input has a positive voltage of more than 2.5 volts and you trigger up or down input an LFO will be generated. The up or down input must be triggered after or at the same time as pause.
Yes, the inputs work fine with triggers, gates, LFOs, other envelopes, etc.
Paranormal Patroler
Post by Paranormal Patroler » Fri Nov 11, 2016 6:23 am
Ok, so how does the clock input work in conjunction with the other inputs ?
illdream
Post by illdream » Sun Nov 13, 2016 2:26 pm
Paranormal Patroler wrote:Ok, so how does the clock input work in conjunction with the other inputs ?
The clock input overrides the internal clock. The speed knob, exponential knob, and speed input don't do anything with the clock input connected. Rather the output is advanced forward every clock pulse, so the faster the clock speed the faster it goes up or down. The up, down, pause, and reset inputs work the same.
You can use a VCO, LFO, gates, or triggers on the clock input. If you use a VCO or LFO with a frequency or speed input you can create exponential curves or other slope variations. Also, slower up and down times can be achieved with the clock input.
Paranormal Patroler
Post by Paranormal Patroler » Sun Nov 13, 2016 6:13 pm
How many clock pulses does it take to complete the cycle ?
I made space for this in my case. Loved the demo, it sounds great as a sequencer. I'd love to watch more examples while we wait for it to be released.
Please consider making it available for Europe as well. Thanks.
illdream
Post by illdream » Sun Nov 13, 2016 7:34 pm
Paranormal Patroler wrote:How many clock pulses does it take to complete the cycle ?
256 Clock pulses completes one up or down cycle. I am planning on recording some audio demos soon. I do hope to make it available in Europe and will let you know if or when it happens. Thanks.
