Passive voltage divider standards
xtinct
Post by xtinct »
I am curious to know if it is possible to use a passive voltage divider as a crude clock divider, and if so, what would be the standard resistor values to obtain the musical divisions.
EATyourGUITAR
has no life
Post by EATyourGUITAR »
EATyourGUITAR
has no life
the serious answer is build this
http://www.eatyourguitar.com/4024breakout.pdf
xtinct
Post by xtinct »
Thanks for the reply, but this is an active circuit and quite complicated.
mush
Post by mush »
xtinct wrote:Thanks for the reply, but this is an active circuit and quite complicated.
I'd say it is the simplest way to make a multiple output clock divider. On your original question, the answer is no. You divide voltage with a voltage divider not time domain triggers...
basicbasic
Post by basicbasic »
Think of a voltage divider like a volume knob. It just takes an input and reduces it down to via the pot or via resistors tied to ground or 0v.
A clock divider usually requires some kind of CMOS chip like Eatyrguitar's design, or maybe some transistors to make a flipflop, or even some kind of microcontroller.
These can't be passive and will require power.
xtinct
Post by xtinct »
thank you fella for clearing this up for me. much appreciated
EATyourGUITAR
has no life
I had another try at the design. maybe this is better for a beginner project.
