Announce Thread: Magpie Modular - uBraids - Braids in 8 HP.
ZZ Ardoz
Post by ZZ Ardoz »
Southfork wrote:
ArguZ wrote:Yes, you need to click on Upload via Programmer
Yes not working for me with upload via programmer, I'll post the error message tomorrow see if anyone can decode it for me.
What system are you using, etc?
ArguZ
Post by ArguZ »
Here are my Fuses...does that look ok ?
Southfork
Post by Southfork »
windows 7. arduino ide. AVR pocket programmer.
Its seems to be failing to compile the code with this error message.
stray \302 in program
<title>microBraids/mbraidsv3.ino at master · MagpieModular/microBraids · GitHub</title>
Southfork
Post by Southfork »
Ok got to the bottom of it, was the way I was pulling the sketch from GitHub, simple copy n paste fixed it. All flashed now. One character line seems out of place on 1st letter but completwly useable, seems a few of us are getting this. Won't bother re-flowing pads, mucho happy :yay:
ZZ Ardoz
Post by ZZ Ardoz »
Southfork wrote:Ok got to the bottom of it, was the way I was pulling the sketch from GitHub, simple copy n paste fixed it. All flashed now. One character line seems out of place on 1st letter but completwly useable, seems a few of us are getting this. Won't bother re-flowing pads, mucho happy :yay:
Nice one - Would love to know if there is a solution to the line issue, as it has been repeated. Not urgent, but more curious to learn what would make it happen, and if it is hardware or software related
pld
Post by pld »
ArguZ wrote:Here are my Fuses...does that look ok ?
Int. RC Osc. 8MHz doesn't seem right. According to fusecalc you probably want something that contains Ext. Crystal Osc.;.... Googling "atmega328p arduino fuses" turns up low_fuses=0xff, high_fuses=0xde, extended_fuses=0x05 which looks better. But I haven't used an AVR in eons or ever flashed one with Arduino, so it's probably just be a matter of picking the right board in the IDE?
Just don't try random fuse combinations, that's a recipe for disaster :deadbanana:
Southfork
Post by Southfork »
I have seen builds where the corruption of the display is in a different place so guessing it's down to the construction. Does anyone have a perfect display? the pads on CD74HC4067 are too small but not sure if it's anything to do with the display problems, can anyone clear this up? Board could deffo do with a revision if there is any free space (cramped I know). I have another 2 of these so will solder that ic 1st while I have space to concentrate on it and see if that makes a difference :bananaguitar:
ArguZ
Post by ArguZ »
Well, as you can see on my displays, they have all lines...
But they jump around...ever 5 seconds one line switches position with an arbitrary one.
Maybe from the word next to it.
To me it almost looks like the error you get on Elements when the muxer is getting some astray voltage.
I installed Atmel studio and have access to the fuses now..
If you are saying my chip runs at 8mhz, that might be the problem.
According to the Adafruit instructions it should either run 12 or 16
https://github.com/adafruit/Adafruit_SSD1306
I will try Fusecalc and see what happens.
No risk no fun
pld
Post by pld »
Southfork wrote:I have seen builds where the corruption of the display is in a different place so guessing it's down to the construction. Does anyone have a perfect display? the pads on CD74HC4067 are too small but not sure if it's anything to do with the display problems, can anyone clear this up?
The 4067 is definitely a key part in the chain. The F103 uses the 2x595 + 4 GPIOs to drive what it assumes are 4 segmented displays. Except the outputs of the 595s are muxed through the 4067 and scanned by the AVR, so if any of the mux lines or the software timing is off, the AVR will probably misinterpret the scanned data and display weird segments.
If the goal remains to keep the Braids firmware unchanged, it might be possible to improve the scan or maybe do it without the 595s/mux which would save space...
Southfork
Post by Southfork »
Thanks for clearing that up! And possibly shifts some of the display problem diagnostics to checking the connection of a difficult to sit ic :banana:
ArguZ
Post by ArguZ »
The board still needs a revision and it its just because of the pad size.
My technic is to add tin to all pads, flux to the chip and heat both with hot air.
Then fuse them and hold the chip down until it settles...
if the pads would stand out one mm on each side one could easily use an iron.
There is enough space too.
ArguZ
Post by ArguZ »
Ok, the Fusecalc defaults for the 328P are the exact same fuse settings that are in there
And selecting another board in the IDE does not change anything.
i don;t think i should mess with that without anyone with more experience/knowledge chimes in.
pld
Post by pld »
ArguZ wrote:Ok, the Fusecalc defaults for the 328P are the exact same fuse settings that are in there
That probably means the fuses haven't been written. The defaults are likely incorrect in this case since they use the internal oscillator at 8MHz.
Sorry, I don't have a platform to test it with but yeah, some who's programmed an AVR correctly from scratch with an Arduino sketch would be helpful. The boards.txt shows 0xff, 0xde, 0x05 fuses for Arduino/Genuino Uno (328p) so I assume that's right, but the IDE might only set them if you burn the bootloader.
GryphonP3
Post by GryphonP3 »
Man! I have 3 boards totally stuffed except that damn STMicro ARM chip. That thing is TINY! What tech iques are you guys using to solder it? No matter what I do, i get little bridges. Currently using .02" solder and a fine tip. Been looking for a well/cup type tip for a weller iron, tricky to find but still not sure if this would do the trick. Are you guys using solder paste? Heat gun? Oven? Interested to see your techniques since this one chip is the only thing holding me from completing this thing and I've been at it for hours and ruined at least one chip :deadbanana:
Https://soundcloud.com/xelphmusic
ZZ Ardoz
Post by ZZ Ardoz »
GryphonP3 wrote:Man! I have 3 boards totally stuffed except that damn STMicro ARM chip. That thing is TINY! What tech iques are you guys using to solder it? No matter what I do, i get little bridges. Currently using .02" solder and a fine tip. Been looking for a well/cup type tip for a weller iron, tricky to find but still not sure if this would do the trick. Are you guys using solder paste? Heat gun? Oven? Interested to see your techniques since this one chip is the only thing holding me from completing this thing and I've been at it for hours and ruined at least one chip :deadbanana:
Use flux and drag solder. Put the solder, but not too much, on your tip. This tip has been good for me - Hakko T18-S7 - T18 Series Soldering Tip for Hakko FX-888/FX-8801 - Bevel - 1.2 mm/60? x 14.5 mm
Jonachi
Post by Jonachi »
I think a common mistake for dragsoldering is using a small tip. You Need the heat to be evenly distributed. The use a braids to remove the bridges.
GryphonP3
Post by GryphonP3 »
That tip looks great, but will it work with my weller iron? I tried this technique and it worked for other chips, but this one tiny chip seems like any time i apply the tiniest bit of solder after flux, it clings imediately to the first 3 legs all together all the way up rather than allowing itself to be dragged. Seriously seems like it happens within milliseconds then is no longer on my tip.
Sorry to derail thread with my own soldering issues! I guess its nice to know that its at least possible with the method I am trying :)
diablojoy
Post by diablojoy »
with drag soldering you actually don't care too much about solder bridging the pins thats why you go back over it with solder braid and yes a larger tip actually helps in this case a flux pen is also a good idea
GryphonP3
Post by GryphonP3 »
diablojoy wrote:with drag soldering you actually don't care too much about solder bridging the pins thats why you go back over it with solder braid and yes a larger tip actually helps in this case a flux pen is also a good idea
Switched to my heavy duty chisel tip. Now we're in business :sb: not used to smt stuff this tiny! 0603 stuff is no problem at all and even those other microprocessors, but that ARM one is a doozy!
gimber
Post by gimber »
GryphonP3 wrote:Are you guys using solder paste? Heat gun?
I've been having pretty good luck so far with one of those ubiquitous ebay heat gun/rework stations and solder paste.
ArguZ
Post by ArguZ »
well, that killed the chip..
Or at least made it impossible to program again
pld
Post by pld »
Narf. I did see a 16MHz crystal in the BOM? Because that's required then.
ArguZ
Post by ArguZ »
Everything in the BOM is on the board...all from Mouser.
I have an AVR Dragon too, someone said i can HVreset the fuse bits with that one.
pld
Post by pld »
ArguZ wrote:Everything in the BOM is on the board...all from Mouser.
I'd double-check before doing that, IIRC the 12V is on the reset line only but it might go beyond the MCU (I think I only ever did that with DIP and outside the circuit).
Not sure where the thinking error is, but if the fuses tell it to use the external crystal, it relies on that. Best course before further experiments might be to ask the designers.
diablojoy
Post by diablojoy »
there is a 16mhz resonator and an 8mhz crystal in the mouser bom
the 8 MHz crystal is for the STM32
the 16mhz resonator is for the atmega328
check the 3 longish vertical pads just below the FTDI header in the boxed section
