☢☢CUSTOM ACID BATH ETCHED EURO PANELS - FINALLY UP!!!☢☢
justscratch
Post by justscratch »
yeah i'm definitely in to these.. like the pre-acid look as well
neil_kerr
Post by neil_kerr »
Aye, I am going to test out a number of different techniques, using different materials, inks etc... to get a variety of options.
The plan will be to offer them in limited editions of, I dunno...25 or so per run and then within that, they will all be slightly different, given the handmade nature of this method of working.
Jalopy
Post by Jalopy »
neil_kerr wrote:...25 or so per run
So just stare at this thread if I'm wanting?
Also I think you mentioned 12HP but what different sizes are you thinking?
:goo:
lambwolf
Re: ☢☢CUSTOM ACID BATH ETCHED & SCREENPRINTED EURO PANEL
Post by lambwolf »
neil_kerr wrote:
The thing that initially stopped me was that I use water-based, non toxic inks and, although, I regularly screenprint onto metals I wasn't sure how it would hold up to wear and tear.
Try a 2 part epoxy ink and you won't have to vanish.
neil_kerr
Post by neil_kerr »
:goo:
I haven't a clue what the demand will be so I can't make a decision on the numbers of each panel just yet but there will be 4hp, 6hp, 8hp, 10hp, 12hp, 14hp and 16hp panels created. Anything larger than that will probably be bespoke one-off panels created at people's request.
neil_kerr
Post by neil_kerr »
The etching inks give a really nice, aged finish when rubbed back a little and I can rub in different colours to have subtle blends etc...I don't mind having to varnish them but thanks.
The Illuminaire
Post by The Illuminaire »
neil_kerr wrote:
The Illuminaire wrote:Love it, mate!
I would be very interested in having you do two 126HP panels to marry my "here to stay" modules and whilst aligning them aesthetically.
Can't wait to see more! :love:
I wasn't quite expecting anyone to ask for 126hp panels but yeah, it's totally achievable. The postage from Ireland to the US might be a little high though.
The other option, to keep postage lower, would be to have a series of large panels that make up the full 126hp, say three 42hp panels with the image spread across all three for continuity. That would be entirely up to you though as, like I said, 126hp is grand.
When the work goes up next week you can let me know if it's in keeping with your system aesthetic or ask me to work of an existing image of yours.
Ta'
I mean, we can also do individual panels for each module so long as we were able to have an illustration play throughout each of the module panels on the 126HP rows.
I'll be PMing you about this a little bit later today.
P.S.
The kanji/Japanese astronomy acid bath panel is utterly righteous.
kwil
Post by kwil »
These look cool. I'm not sure if it's intentional, but the kanji is horizontally reversed?
nickbaba
Location: Symbolically Authentic Non-Euclidean Adventures
Post by nickbaba »
These are looking gorgeous!
Can't wait. And they don't even make weird sounds.
neil_kerr
Post by neil_kerr »
kwil wrote:These look cool. I'm not sure if it's intentional, but the kanji is horizontally reversed?
Yeah, I realised that today when printing, forgot to flip the image for etching purposes. Doh!!
neil_kerr
Post by neil_kerr »
nickbaba wrote:These are looking gorgeous!
Cheers!
Am sure you could make weird sounds with them if you scrape them against a chalkboard or against an angry leprechaun :razz:
neil_kerr
Post by neil_kerr »
The Illuminaire wrote: I mean, we can also do individual panels for each module so long as we were able to have an illustration play throughout each of the module panels on the 126HP rows.
P.S.
No worries, shoot me a pm and we can discuss imagery etc...
ta'
neil_kerr
Post by neil_kerr »
So here is the globe plate pretty much finished, aside from the varnishing. The panel was dipped/bathed/drowned in about 10 different chemical solutions to try to get the bloody etch-resist off. Was so hard to get it off and my hands are now horribly dry and itchy thanks to the irritants in the chemicals. Definitely need to buy more gloves!
This was the first test and I will be doing further tests in order to create both cleaner and dirtier panels. The finishes will vary but I want them to be controlled variations (within reason.)
Anyway, this is how it looks with the etch and no ink. You can see that the panel has an aged look due to the deep (long) etch in the acid. The difficulty in removing the etch-resist caused some added texture, as seen in the bottom right of the panel, the ink covers this and the texture kind of adds nicely to the finished look.
This is the panel inked up with the oil based printing ink. It is really concentrated and gloopy and makes an absolute mess.
Below is the panel after having removed most of the ink, it is a pretty slow process as the ink is so thick and sticky. I could continue to rub at the plate to remove more ink but I don't want to risk removing it from the etched area and I quite like the aged look. I will be making other panels where I remove more ink, use different colours, leave them with no ink etc....for more variation.
Christopher W.
Lord of Tweed Manor
Post by Christopher W. »
That's gorgeous.
I wonder if the same technique would work as well as a guitar pickguard? ;)
bobbcorr
Post by bobbcorr »
Tell you what. . .I am a fan of the blue-ish background like you showed the other day.
huffnPuff
Post by huffnPuff »
I like the final version better. Copper could also be cool, assuming it can be etched?
reppiks
Obscure Intergalactic Destroyers!
Post by reppiks »
wow!!!
neil_kerr
Post by neil_kerr »
Christopher Winkels wrote:That's gorgeous.
If you can get the metal cut to the correct size and shape then not a problem :)
neil_kerr
Post by neil_kerr »
I like both the pre and post etch though the post etch with no emulsion would suit my set-up best.
Will be doing some copper panels though as a metal it is much more expensive than aluminum and so the copper plates will be smaller in number and higher in price unfortunately.
Also planning on doing some panels on brass and steel.
Am still struggling to find a chemical that will take off the emulsion easily, going to try acetone today. Once I have sorted that and bought a drill for the holes, I will be able to make a dozen 4hp, 6hp and 8hp panels which will go up for sale next week.
Here are the second and third 12hp panel tests alongside the first panel which had been stripped of emulsion at this stage. Did these yesterday before I remembered that I have to flip the image and so the Kanji is still backwards.
golana
Post by golana »
Hei fellow etcher :D
I don't plan on stealing any of your potential clients, but I felt like sharing etching experiments.
I made a thread in the DIY section since etching is not only for eurorack :)
viewtopic.php?t=164465
plouf
southphillysynths
Post by southphillysynths »
These are absolutely beautiful! I will stick around to see what else you come up with. Would love some brass etchings, Might need a bigger case just to keep them installed! :hihi:
neil_kerr
Post by neil_kerr »
golana wrote:Hei fellow etcher :D
Hey!! Nice work! Cool to see some more etching in a music context.
I'm just glad to get back to the etching, so busy at the minute, it was hard to justify spending time standing over acid baths but if I can make a few quid to held fund my modular habit then it's all good plus I get to make panels for myself :)
neil_kerr
Post by neil_kerr »
Started to etch Mr Spaceman.
Here you can see the effect of the acid eating away the metal. It makes a satisfying sizzling noise :)
neil_kerr
Post by neil_kerr »
Finished the 2nd 'Globes' test panel.
Eventually found a way of removing the emulsion without having to leave the panel in sodium carbonate for ages, which in turn created the rawer, aged look as seen earlier in the thread.
The new chemical solution means that, alongside creating rawer panels, I can also achieve a much cleaner finish as seen in the pics below. I opted not to rub ink into the plate as the deep etch create a nice contrast when left as it was.
Really pleased with how this turned out and now just need to make one or two slight adjustments (the etch on this was a little too deep) and should be ready to get stuck in to creating some panels for sale.
Well, actually I still need a drill. Boooo...
MacSynth
Post by MacSynth »
Would you maybe, under the right circumstance, think about selling a few of your etchings?
Maybe you could even team up with angryblue and etch his design?
