JH Living Vocoder [BUILD THREAD]
jhulk
Post by jhulk »
ill be using 1% vishay dale rn55 as thats what i have in stock
LektroiD
Post by LektroiD »
nordlead wrote:
LektroiD wrote:Just awaiting caps, before moving on to the taller components...
[img]
Damn you're fast, Rich! Looking great! An it seems the 1N5404 do fit in the new pads now ... :party:
They fit fine with the help of a dremel. You must solder both sides when you do this, as the dremel will strip the inner contact walls of the PCB and the traces leading to them are on both front and back of the PCB.
jhulk
Post by jhulk »
ok my work mate in usa is going to order from verical and element14 as they were the cheapest
so should have both usa and uk covered there is about 17 people on board so far ill keep you posted on when they are for delivery
coon
Post by coon »
Is there a group buy for pin matrix's as well?
jhulk
Post by jhulk »
yes there is its on the phutney clone thread
coon
Post by coon »
You are a hero! Thanks
jhulk
Post by jhulk »
any one else on the list for the matrix upto 14 so far from both lists
synthdude
Post by synthdude »
Im still trying to determine how the matrix is implemented on the vocoder. Cant you use sliders/pots instead? I have to look at the schematics closely. I haven't done that yet. Whats the estimate on the cost for a matrix?
jhulk
Post by jhulk »
caps are ordered will let you know when i receive them i ordered 3000 of each so that if any one else decides to jump in ill have some spare
jhulk
Post by jhulk »
matrix is so you can set the sliders then use the matrix to replot them to other bands
292 euros on 20 orders + tax + postage
tax will be done by usa or europe depending on where there sent there is a person in usa who is going to receive the usa ones and post from there
synthdude
Post by synthdude »
Ok put me on the list for one matrix, or do I have to post on the phutney thread? Does the matrix come with a set of pins?
jhulk
Post by jhulk »
i have to inquire about the pins as we want pins that we can do ourselfs with resistors
i have a request in will let you know but they are separate from matrix price once i get a full quota of people and then i can negotiate a better deal
they did say they would give extra discount if it was paid before making rather than 30 days after invoice
synthdude
Post by synthdude »
jhulk wrote:i have to inquire about the pins as we want pins that we can do ourselfs with resistors
Do you mean pins with diodes in them? Its doesn't hurt to look into that discount. It might be worth it if its a decent discount.
jhulk
Post by jhulk »
no resistors you can add diodes they sell the diode versions
but we want them before the diodes are mounted
so we can add our own resistors in various sizes which adds to unique modulations
you can add diodes if you want this just stops interactions on the matrix because its not buffered but by not using the diodes
quirky things happen crosstalk and feedbacks that add to creating sounds which is lost when adding diode pins
synthdude
Post by synthdude »
jhulk wrote:no resistors you can add diodes they sell the diode versions
Ah got it! Thanks for explaining that.
papz
Post by papz »
I asked the person I know who has a Vocoder 5000 what's inside the pins and I'll let you know.
I don't visualize yet how the matrix will be wired in this project, but diodes don't work for routing an analogue signal as they allow only a part of it to pass through.
Finest EMS gear service and 208 goodies
Please don't ask, thanks.
jhulk
Post by jhulk »
half of the .047 caps are on back order
just had an email from element14 there sending the first lot out and the rest will follow as soon as they are in
PWM
Post by PWM »
Off Topic
Where did Lectroid got that amaizing rainbow wire dispenser?! (Picture OP)
papz
Post by papz »
Likely DIY :lol:
The Big Ear
Post by The Big Ear »
So i slowly started soldering as I have all the PCB parts at hand now.
Next up to think about is the wiring. I like a plan before starting...
Anyway, I can't see how this thing should be wired. So if anyone has a wiring guide or could share some thoughts, I'd appreciate it.
I might consider a pin matrix, but not sure if this is really needed. Is there a video somewhere showing how this pin matrix is needed? Would some jacks (like on Luka's panel) and a few multiples be possible too?
ABout the sliders, 5K Log's, 40 pieces is also going to be quite expensive, will there be a group buy for these?
Looking forward to what you guys come up with!
Cheers,
Starspawn
Post by Starspawn »
I wont be doing either sliders or pin matrix, going more for the Sennheiser look.
I suppose you could make a patch bay with 40 jacks, the normalization going to the switch connections from one set of 20 to the other.
But I dunno, if theres CV inputs for each band Id rather do that :D
The Big Ear
Starspawn wrote:I wont be doing either sliders or pin matrix, going more for the EMS look.
Yeah Starspawn, looks/sounds good to me.
Now only to find out how the wiring should be done.
Cheers,
ToAd
LektroiD
Post by LektroiD »
Cheers,
ToAd
I've decided upon this layout too, I'd also like to know how this was wired. There's a clue in the individual channel schematics, but doesn't explain everything... Trying to cross reference it with the Sennheiser schematic doesn't really help much either... Hopefully there'll be someone knowledgeable enough here to guide us... :)
tjs
Post by tjs »
This explains at least a part of the wiring:
http://electro-music.com/forum/viewtopi ... &start=300
"Zthee: What's throwing me off is this
Quote:
*) Connect patchbay outout to cw end of 5k audio taper potentiometer.
Connect wiper to middle pin of connector.
Connect ccw end of Pot to GND.
Right now the middle pin is labled patchbay output: And I'm supposed to connect that to CW end, and then I'm supposed to connect the wiper to the middle pin! "
"From the PCB viewpoint, the lowest pin is the analyzing filter output, and the middle pin is the envelope detector input.
But if you look at the matrix as a module, that can (optionally) be inserted at this break point, the matrix' input signal will come from the lowest pin of the PCB, and the matrix' output will go to the middle pin.
And if you look at channel potentiometer(s) as another (optional) module, the matrix output will go to the potentiometer's "input" (cw end), and the potentiometer's "output" (wiper) then goes to the env detector input (middle pin on PCB).
JH."
papz
Post by papz »
The matrix in the EMS Vocoder 5000 uses shorting pins.
