i got 3 oscillators and 8 vcas (or 12 if i use frames parasite euclidean seq) in my little system.
now i know better what do do with them.
Very nice series Frank and should be required viewing for anyone just starting out in the world of modular synthesis. Should help answer a lot of questions for a lot of newbies out there.FrankMurder wrote:Part 3 is up:
Why can I never have enough VCAs? Part 3 - Wrapping up modulation and a few other pointers.
That implies that what would normally be a fixed bias voltage knob they're saying is an "input pass through attenuator" which I see as operating differently (bypassing the VCA rather than biasing it), but I'm not sure what the difference would be in actual practice. There's also the possibility it's just a bias knob they are labeling differently. Anyway, I hope this isn't too much of a thread derail, but since this is all about VCA's I thought maybe someone could shed some light on it.The perfect voltage controlled amplifier for both audio and CV applications. Dual, high quality linear voltage controlled amplifiers with both offset gain, CV attenuation, and a mix out. Each VCA includes a CV attenuators and input pass through attenuator. The output of each VCA is sent to a fully buffered mix output that allows the Dual VCA to act as two channel voltage controlled mixer.
I am not 100% sure about the Pitsburgh Dual VCA, I do not own one. I imagine many VCAs have different internal routings and circuits to achive the same function but with different sound charachteristics.doctorvague wrote:Thanks so much for these great videos! I'm an experienced patcher but VCA's have always been my weak point of knowledge and use. After binge-watching these yesterday I patched up a simple audio-rate AM patch that I really liked. Not as fiddly as FM, and lots of musically useful timbres. I see myself doing a lot more AM stuff in the future.
I have 2 Pittsburgh dual VCA's in my rig. Pittsburgh's description says this:That implies that what would normally be a fixed bias voltage knob they're saying is an "input pass through attenuator" which I see as operating differently (bypassing the VCA rather than biasing it), but I'm not sure what the difference would be in actual practice. There's also the possibility it's just a bias knob they are labeling differently. Anyway, I hope this isn't too much of a thread derail, but since this is all about VCA's I thought maybe someone could shed some light on it.The perfect voltage controlled amplifier for both audio and CV applications. Dual, high quality linear voltage controlled amplifiers with both offset gain, CV attenuation, and a mix out. Each VCA includes a CV attenuators and input pass through attenuator. The output of each VCA is sent to a fully buffered mix output that allows the Dual VCA to act as two channel voltage controlled mixer.
Thanks again!
