Optomix Rev 2
- cheliosheart
- PolarIceCaves
- Ultra Wiggler
droningspaghettimonster
- Veteran Wiggler
Filternauts
I just bought one.
I just researched/viewed a bunch of modules at the $200 range that are VCA/VCF Vac/Env Combos... and this is IMO the best/Well Demoed/tested for @$200 ($215).
Manufactures... the decision of my purchasing is heavily influenced on demo videos. Try to get a video demo on your module. There is NO local storefront where I live.
I was sold on V2, AND expecting V2...
- Veteran Wiggler
Footkerchief
- johnwynberg
Thanks for that video reminder. I had forgotten about it. I wanted to sell my Optomix mk1, Pressure Points and perhaps even ModDemix mk1, to upgrade to an Optomix mk2, mainly for questions of space... But with how cheap the Optomix mk1 has become, I think I'll be better keeping everything and just buy another case.Footkerchief wrote:[video][/video]
- Veteran Wiggler
DC offset means a control voltage with a mean above zero, for example a constant 5v or 10v cv. You should be able to use the output of Maths channel 2, with nothing patched into the channel 2 input, for this.droningsphagettimonster wrote:i aint got pressure points. i must admit i am not really sure what DC offset means.should maths do trick?
thermionicjunky
- Thyratron Genius
In this usage case, it refers to a positive static voltage, but in general terms, DC is any 0Hz (static) signal. It could be at any voltage between about -10 and +10 in a typical Euro system.DMR wrote:DC offset means a control voltage with a mean above zero, for example a constant 5v or 10v cv. You should be able to use the output of Maths channel 2, with nothing patched into the channel 2 input, for this.droningsphagettimonster wrote:i aint got pressure points. i must admit i am not really sure what DC offset means. :doh: should maths do trick?
Futuresound
thermionicjunky
- Thyratron Genius
A VCA with faster vactrols won't slew very much, so it would have to be another unit with the VTL5C3 or similar. A slew limiter works as an AR when fed a gate. The strike input of the Optomix allows it to be used as an AD or AR, regardless of the length of the input pulse.Futuresound wrote:
...Am I correct in understanding that this is showing how the slow response time of a vactrol can be used to generate an envelope from a gate / pulse?
Meaning that any vactrol-based VCA, or slew limiter, would do the same?...
- southberry
Dogma wrote:Really cool update - i love the user changeable vactorals and the CV mixing and sidechaining....bit of a no-brainer nowdrxcm wrote:Just got my v2.
One nice upgrade - the vactrols are now on socketed daughterboards.
See this pic, old in background, new in foreground
it seems the rev2 is deeper than the original ...
why MN website and ModularGrid listed it as as 24mm like the original ?
Am I missing something ?
the new additions are very nice and will be very useful, but I'm curious ... Has it only been upgraded with new features or the circuit / components has changed too ? it use the same Vactrols than the v1 ?
- miles_macquarrie
- Ultra Wiggler
Hello,
I have been lurking here for well over a year, but this is my first post.
First off, what an amazing place. I have learned so much here, so thank you!
I have recently noticed an pretty large volume loss when putting an envelope into the control of my Rev2 Optomix. This did not happen initially and I have plenty of signal before going into the control input. Has anybody else experienced this?
Thanks,
Miles
Thanks,
Miles
I just noticed that my Optomix module #3211 has a print on the PCB that says
mn-00-019revI, 2010 make noise. I would have expected rev2 or something.
It does look like the new one though with the vactrol daugther boards and the clearer DAMP and CTRL letters on the front panel, and it was bought in 04-2016.
Could someone please just confirm that his rev2 board is also not labelled rev2?
