Tides Parasite v1.121: an alternative firmware for MI Tides
starthief
Post by starthief »
Seems like some math might be off in Two Bumps regarding the number of harmonics: "red" mode does sort of set harmonics to octaves only, but it's extremely buzzy and has dead spots (particularly with shape/slope knobs beyond 12 o'clock) Sometimes it sounds pretty great like that, but mostly not :)
jwise
Post by jwise »
Mathias, I appreciated your update so much that I just sent you some pizza money.
mqtthiqs
Post by mqtthiqs »
Thank you guys! It's my pleasure really to receive all these positive reactions :)
jwise well received thanks a bunch :guinness:
starthief doh :doh: you're right! that's a silly mistake... I just uploaded v1.121, which fixes the bug. Sorry that I made you re-upload again :roll:
anosou
Post by anosou »
Thanks for the update mqtthiqs! I'm assuming the FM attenuverter is still is not available for fine-tuning? I haven't followed the thread that well...
You can hear & see my modular noodling on YouTube.
You can find my rack at ModularGrid.
mqtthiqs
Post by mqtthiqs »
anosou yes it is. It now has the same function it had in the stock firmware.
anosou
Post by anosou »
mqtthiqs wrote:anosou yes it is. It now has the same function it had in the stock firmware.
Oh excellent news, thanks so much!
Hanz
Analogue Avenger
Post by Hanz »
Thanks (again) Matthias!
“...I am merely a conduit, a kind of big hairy tool. I am just a plastic funnel connected to a Moog...”
erstlaub
Post by erstlaub »
:yay:
Thanks so much chief. The gift that keeps on giving.
<3
Djumpmonkey
Post by Djumpmonkey »
mqtthiqs,
Thanks so much man. The stock mode oscillator just lacked some punch with previous Parasite firmware, which kept me going back and forth, staying stock most of the time. This is just great.
pichenettes wrote:There's something wrong about this world in which Clouds sells 5x more than Tides.
Chopper
Post by Chopper »
thanks a lot, Matthias. Tides Parasite is maybe your cleverest firmware, and on Olivier's cleverest module!
lohacker
Post by lohacker »
Many thanks mqtthiqs was waiting for this update to restore my loved parasite firmware! :party:
pugix
Post by pugix »
I just downloaded v1.121.
Looking forward to trying it. Thanks!
accountboy
Post by accountboy »
wow I'm getting this and sending something of a donation through as I do it.
on another parasites note (and I know you've said that you'd rather not dip your toes in this one again) but seeing reports of downgrades to 1.11 from 1.21 for wrap modes, keyframer autoplay. do you think there's a chance for a stable version which has autoplay submode?
sorry to bug you about this...!
hugs
:hail:
mqtthiqs
Post by mqtthiqs »
Hugs well appreciated accountboy :razz:
So you'd like a Frames parasite with the autoplay submode but with no wrapping around the Frame knob? I might have a look but OTOH the two features were quite linked and difficult to separate... can you bug me again in a couple of months about it if you haven't heard back?
risome
Post by risome »
Thanks MQ :miley:
accountboy
mqtthiqs wrote:Hugs well appreciated accountboy :razz:
heey! loool hugs and money from me anyday. can't believe you have added so much and actually... simplified using... so many modules!
so - I can't fully explain (or complain, as I've run into few issues myself) except this one thing with Frames: viewtopic.php?t=144084&start=125
so just keeping tabs on that situation where Parasites users (and I hope everyone of you did hit that mqtthiqs paypal button) were downgrading because in autoplay when receiving 0V there's still movement - I like the autoplay otherwise!
Hanz
Analogue Avenger
Post by Hanz »
I just got around to installing v1.121.
However, is anybody else having the strange quirk that fine tune (the FM attenuverter) is working the opposite way around?
<edit> never mind... something must have gone wrong during calibration... recalibrated and now it's working fine!</edit>
Orange
Post by Orange »
Ok. After almost 2 years of owning Tides, it was the time to install Parasites.
Spend the whole evening trying to install the latest version, but I cant get it working.
Tried several cables, pc and IPhone, but no results.
The LEDS show a cyclic pattern, but after a few seconds the leds turn red.
Lowering volume doesnt work, the LEDS stay orange. Turning up the volume leads to three red LEDS again.
Someone had the same problems but has found a solution?
:roll:
bougie
Post by bougie »
My iphone volume was too quiet, worked straight from my ipad tho.. try running the audio in a vca or ext in interface
Orange
Post by Orange »
bougie wrote:My iphone volume was too quiet, worked straight from my ipad tho.. try running the audio in a vca or ext in interface
Thanks, will try with an iPad this evening.
Now I know why I didnt install Parasites earlier :hihi:
Yes, I know user error...
Orange
Post by Orange »
Turned the volume of the interface, connected to a laptop, up to level ‘RUNUTS’ and everything - including myself -seems ok now :banana:
More playtime tomorrow.....and time to donate :guinness:
YES!
mcgold
Post by mcgold »
Currently trying to install the firmware but can't seem to get it working.
I get it into the update mode where all three LEDs are flashing orange. Then when I play the file into the module, the lights don't change at all. If I pump the volume they'll go red so the sound is definitely getting there...but for some reason it's not working. I've tried the FM knob at full left, center, and full right...I've also tried from both my audio interface, computer, and phone...any ideas?
EDIT: After trying over and over again I was able to get the cyclic pattern for like 3 seconds before it turns all red. and i'm only able to get that pattern like once every 15 tries right now :/ but it always quickly turns red.
hawkfuzz
Post by hawkfuzz »
Keep trying. I had trouble with a DIY unit, but if it's factory it should work eventually. Maybe try those in between spots on the FM knob.
BaloErets
Post by BaloErets »
When sending via your PC, did you try turning off your speakers and really boosting the volume? I found I had to set the volume extremely high in order to get Tides to catch the update. I'll repeat; turn off those speakers 1st.
Trebbers
Post by Trebbers »
Also, not a bad idea to just .zip them up when you're done updating. One morning I brushed up against my iMac's 'play' key after having left a Parasites .wav in a VLC playlist. Screen was asleep, and I thought my hard drive was fucking grinding itself into dust. About shit myself.
