Active Attenuator with +/-200% Range?
Gizmo
Post by Gizmo » Sun Jul 19, 2015 6:28 pm
STG spec says "The [three] cells have a range of -100 percent to +100 percent gain" which is what you expect for attenuators.
But over here: https://www.muffwiggler.com/forum/viewtopic.php?t=93523
Dave Peck wrote:STG Triple Active Attenuator (Mine is set up for +/- 200% for each stage, so it amplifies or attenuates with or without inverting...)
Is this a jumper setting, or factory special order, or a DIY modification? Or something else entirely?
Gizmo
Post by Gizmo » Tue Jul 21, 2015 2:45 pm
Solved. Asked Suit & Tie Guy directly (duh) and yes, a range of 2X is available in the Active Attenuator on request when ordering.
suitandtieguy
Hammond King
Post by suitandtieguy » Wed Jul 22, 2015 1:53 am
eventually i want to do a hardware rev where you can select this via jumpers on the back but quite frankly we're a ways off from that .... :bang: :guinness:
http://suitandtieguy.com
http://stgsoundlabs.com
http://knobcon.com
dykesh
Post by dykesh » Fri Aug 05, 2016 5:41 pm
Could someone tell me the disadvantage of buying the 200% version? I am not sure which to buy?
Gizmo
Post by Gizmo » Sat Aug 06, 2016 9:27 am
dykesh wrote:Could someone tell me the disadvantage of buying the 200% version? I am not sure which to buy?
It's bit more sensitive to set because of the wider knob control range. Otherwise I see no downside. It's invaluable when you need to stretch a signal.
Return to “STG Soundlabs”
