Hey, im so lost! I could use some experienced advise on how to best finish off my make noise system based off the shared system. Id like to have tight clocked sequences with my DAW but, other than that I don't know what else would be best to complete this system.
https://www.modulargrid.net/e/racks/view/177064
Was thinking 4ms PEG and a Peaks, but not sure if that would be envelope overkill for this system.
How should I finish my shared system?
Re: How should I finish my shared system?
Sounds like you need Expert Sleepers/Silent Way. What kind of audio interface are you working with now, and in what DAW? It matters as to which module you will need to begin.xtinct wrote:.....Id like to have tight clocked sequences with my DAW......
Silent Way has a Sync plugin that will send a clock signal and start/stop trigger to any and all of your current sequencers. Not to mention will give you additional LFO's, CV gate/pitch, envelopes, on and on.
look at innerclock's iils
The Book of Bad Ideas - A compendium of knowledge from Muffs. Download it here: http://bit.ly/1oz2zaI
