Jürgen Haible Krautrock phaser BUILD THREAD
donaldharper
- Learning to Wiggle
Good shout, but no, I've been testing this with the bulbs/ldrs covered
I had a chance to take another look and I found these issues, which might explain why my volume is low
When using the input socket, the bypass knocks out all sound completely
Weirdly, the Left output works as an input also. This has a slightly louder sound than the input, and the bypass works on it (although the LED does not come on). The bypass is way, way louder than the non-bypassed volume
The modulation pot doesn't appear to do anything either, although that might just be inaudible due to the low volume
The input/stereo jacks are definitely in the right places and I've checked the board for bridged solder and wrong component values. Now I'm stumped. Any ideas what might be causing this? Perhaps a damaged IC?
Thanks in advance!
Thanks in advance!
- LED-man
Krautrock in external case with 18V Ac psu.
Manual Mode is disabled.
SDIY support pages - TTSH, DDRM, KIJIMI, RE-303/808/909 and many more
https://www.DSL-man.de
- LED-man
here is a picture about my solution for the "lamp caps"
i used cable ducts/ wire way and fixed it with hot glue.
more about this and other krautrock builds here:
https://www.dsl-man.de/display/MAIN/Jue ... er+in+MOTM
donaldharper
So I replaced some parts and the previous issues I had have now been rectified. And it sounds great too!
I do however need some help with three outstanding things, if anyone can share their wisdom on any of the below I'd much appreciate it!
1) The panel-mounted lamp isn't working. I've swapped around the bulbs, so it's definitely not that. This was working before I swapped parts around, so it's a bit confusing. Any suggestions?
2) I've added a mod that allows you to switch between two capacitor values (1uf and 10uf) to give two different ranges for the LFO speed. This works, but when switched to 1uf it's not as fast as I'd expect it to be; should I compensate for this with a different value?
3) When in bypass mode, the LED isn't working. Something I can certainly live without, but just in case it's something straightforward I thought I'd ask
Thank you in advance!
- pulsepsycle
donaldharper
Got the LFO rate issues sorted, just needed some minor trimmer adjustment.donaldharper wrote:Hi,
However, is anyone please able to help me with the panel lamp problem?
- LED-man
Please Check the frontpanel lamp function with a powersupply or battery,
Or rectifier Test.
Check the Transistor orientation too.
Or rectifier Test.
individuomandroide
- pulsepsycle
- pulsepsycle
- alamandra
I'm a bit confused about this. I've seen mention of one of these panelled up in 5u format. Then I see mention of 15v. I'm not myself a diyer, but, trying to find out if it's worth getting someone who is to build me one up.
Now I saw pulsecycles facebook demoing one used with some eurorack modules. So this gave me some hope. It's primarily eurorack I'd use it with. It seemed to have 3 inputs on the front, gave me the impression you could tap into the different stages. Please correct me where I might be wrong. Also I'm intrigued on how much money people ended up spending on gathering up all the parts needed.
Shiney metal module shirt
- pulsepsycle
I didn't build it as an Eurorack or 5u format. It's a standalone effect box. I've build it for use with both 1/4" and 1/8" jacks. On the bottom row only the right jack is for input the two left ones are outputs. Here is a picture.alamandra wrote:I'm a bit confused about this. I've seen mention of one of these panelled up in 5u format. Then I see mention of 15v. I'm not myself a diyer, but, trying to find out if it's worth getting someone who is to build me one up.
I can't recall how much money I spend on this project.- pulsepsycle
- PWM
- Ultra Wiggler
I'm building mine for eurorack. Your rack has to be deep though...
It cost me €150,- all together. (Panel included)
Thonk has a great kit with all the lamps and ldr's in it.
If you decide to build one, I have a eurorack panel design.
- alamandra
Oh those two leftmost jacks are outputs doh at me lol, just assumed the outputs were out of shot like in the back. Does it come out at modular levels? or is it end of chain then going into audio interface/mixer?pulsepsycle wrote:I didn't build it as an Eurorack or 5u format. It's a standalone effect box. I've build it for use with both 1/4" and 1/8" jacks. On the bottom row only the right jack is for input the two left ones are outputs. Here is a picture.alamandra wrote:I'm a bit confused about this. I've seen mention of one of these panelled up in 5u format. Then I see mention of 15v. I'm not myself a diyer, but, trying to find out if it's worth getting someone who is to build me one up.
Now I saw pulsecycles facebook demoing one used with some eurorack modules. So this gave me some hope. It's primarily eurorack I'd use it with. It seemed to have 3 inputs on the front, gave me the impression you could tap into the different stages. Please correct me where I might be wrong. Also I'm intrigued on how much money people ended up spending on gathering up all the parts needed.I can't recall how much money I spend on this project.
- alamandra
Oh I wouldn't rack it up, it mentions heat and such so i thought id just remove that plus the deepness could be an issue. It was the thonk kit that started me looking into it, tangerine dream and phaser got mentioned so that was me likePWM wrote:
- fragletrollet
- Ultra Wiggler
- pulsepsycle
It's just a matter of taste I guess. I like rotaries. Besides I had space enough on my box. I also wanted all inputs and outputs on front for easy access. PWM's post shows how to use a DPDT which is quit easy too.sixty_n wrote:@pulsepsycle how useful is having the stage switch out front on a rotary? I was thinking of picking the best 2 and using a DPDT to switch between them
