Clock divider as a sequencer
kdjupdal
Post by kdjupdal »
Hi!
Here is a short sequenced clip I made:
I got rid of my sequencer two years ago, but, there are other ways to sequence notes. I just finished building the Yusynth clock divider (a fun module). Here I use it as a sequencer, and the result is very nice.
duluthdack
Post by duluthdack »
wow, great demo of the clock divider, a must have! Are you controlling the pitch with an Lfo???
kdjupdal
Post by kdjupdal »
The pitches are generated by the clock divider, going through a mixer. Every time all three outputs synchronize, I get the highest sounding pitch (because all three are added together in the mixer).
sonicwarrior
Re: Clock divider as a sequencer
Post by sonicwarrior »
Something similar has been posted in the Eurorack section:
viewtopic.php?t=115440&highlight=
With an audio divider as sequencer so an MOTM-120 and the like should work, too, and has the benefit of including attenuators so no external mixer is needed.
Soundcloud
bwhittington
Terrifying Brain Secret
Post by bwhittington »
Great sequence! This is one of my favorite techniques to explore now. As much as I love my Moon 569, I usually end up building sequences out of a mish-mash of clock dividers, other pulses, mixers, vcas, quantizers, etc.
Cheers,
Brian
JohnLRice
Post by JohnLRice »
kdjupdal wrote:The pitches are generated by the clock divider, going through a mixer. Every time all three outputs synchronize, I get the highest sounding pitch (because all three are added together in the mixer).
Nice idea! :tu:
makro
Post by makro »
duluthdack wrote:wow, great demo of the clock divider, a must have! Are you controlling the pitch with an Lfo???
Basically, no. The outputs of the clock divider seem to be mixed as an input source for vco pitch.
I did this with an A-160 before, but the results were not so interesting as in this video. I'm Euro, but i have to try this again with my other clock dividers/multipliers.
So for a start all you need is a mixer, a vco and a clock divider along with a master clock like squarewave from some lfo. Add a filter and envelopes or a quantiser to taste and stir, err... wiggle :)
kdjupdal
Post by kdjupdal »
bwhittington wrote:Great sequence! This is one of my favorite techniques to explore now. As much as I love my Moon 569, I usually end up building sequences out of a mish-mash of clock dividers, other pulses, mixers, vcas, quantizers, etc.
Cheers,
Brian
Yes. I quickly get tired of a sequencer repeating the same pitches. This I find more interesting: in a way the modular itself composes the pitches. Or rather, they are generated according to mathematical rules. Here I use divide by 3,4 and 5. Pulses from two lfos going through a mixer can also be used.
Have you got an example of this technique yourself Brian?
alternating.bit
Post by alternating.bit »
Modular. Never ceases to amaze! :hail:
duluthdack
GOT IT! Thanks much! I'm learning! :)
bwhittington
kdjupdal wrote:Have you got an example of this technique yourself Brian?
Yes, a few. This one was generated with the CGS01 Subharmonic Oscillator used as a pulse divder (you have to check out this module since this interests you. Adds a bit more math to the equation.):
This one was done using the Moon clock divider:
This one was done with trigger sequencer stage outputs routed through mixers and vca's. A little more conventional, but i like it, too.:
Here is a patch sheet for the last video, in case anyone is interested (further discussion here):
emdot_ambient
Post by emdot_ambient »
kdjupdal wrote:Yes. I quickly get tired of a sequencer repeating the same pitches.
But then of course you can run a sequencer or two into a mixer along with a pulse divider and other stuff and prevent that predictable pitch looping from happening.
No need to limit your sequencer to just round and round with the same notes.
Using sequential switches, pulse dividers and sequencers and all...so much more you can do.
duluthdack
I'm buying the HexInverter SympleSeq 4U from LOWGAIN electronics, I plan on buying a Moon Mod 564 to create a 32 step.... Can I avoid buying the 564??
JohnLRice
Post by JohnLRice »
duluthdack wrote:I'm buying the HexInverter SympleSeq 4U from LOWGAIN electronics, I plan on buying a Moon Mod 564 to create a 32 step.... Can I avoid buying the 564??
No, as far as I can tell you'll need something like the Moon 564, COTK C962B/C962C or seqSQUARED etc.
duluthdack
That 2U is sexy as well! Hybrid! But I love that 4U version the most.
JohnLRice
Post by JohnLRice »
duluthdack wrote:That 2U is sexy as well! Hybrid! But I love that 4U version the most.
Actually, that is a companion module that goes with the 4U sympleSEQ! 8-)
duluthdack
Research commenced!!! Thanks! 8-)
Dob
Post by Dob »
What a great idea, using a divider like this!! Inspiring! :bananaguitar:
haricots
Old Astronaut
Post by haricots »
this is absolutely amazing! thanks for the great tip. it's like discovering the sequencer you never knew you had. :bananaguitar:
analogjeff
Post by analogjeff »
Very cool application.. I built a number of these too.
Jerem
Post by Jerem »
I like to use a clock divider and some trigger delay as sequencer
bwhittington
Jerem wrote:I like to use a clock divider and some trigger delay as sequencer
Oh, jeez I like the would of that! Which delay do you use? Might be the straw that finally breaks me regarding ordering the Moon one.
Cheers,
Brian
Jerem
Post by Jerem »
alternating.bit
bwhittington wrote: Oh, jeez I like the would of that! Which delay do you use? Might be the straw that finally breaks me regarding ordering the Moon one.
I finally broke down and ordered the Moon one. I'm not sure if I'm more motivated to make cool use of gate delays or to make a better demonstration video than their drunk camera shaking, all style no substance one :despair:
Return to “5U Format Modules”
