Buchla 275 vs 190
olesandström
Buchla 275 vs 190
Post by olesandström » Wed Mar 25, 2015 4:30 pm
I am thinking about adding some reverb to my system and thinking of either a 190 clone or a 275 clone...
are there different makers out there?
how do they compare? (except from the 275 being dual, voltage controlled + eq)
where do you put the tanks?
Reed
Blame Canada
Post by Reed » Wed Mar 25, 2015 5:43 pm
I can't speak for clones, but the main sonic difference is that the 275 has a compander/noise gate on the output that sounds similar to a 292 in combo mode. It has a long decay and a low threshold, so it doesn't mess with most of the reverb decay. The 212 Dodecamodule has a similar circuit.
If the spring tanks don't fit in the back of your cabinet stick them in an external box.
Peake
Post by Peake » Wed Mar 25, 2015 10:38 pm
I haven't owned a vintage 275 but have owned a 212 and am familiar with its sound. The reverb is very good but you can hear a touch of noise gate. The 275 adds EQ which is so very important. There is technically no 190 clone due to the rarity of the output transformers, which were obsoleted in perhaps 1973 (edit: There are now clone transformers!). The 190 circuit is said to be along the lines of a vintage power amp using an output transformer. I've built a couple of 190 clones when people actually found the transformers and it's a great-sounding unit with 17" tanks. Find some transformers and I can build you a clone, or provide the DIY home-etch artwork and wiring instructions.
There is even contention regarding what sounds best...mounting the reverb tanks with the open side down, or vertically...
I haven't yet heard a 275 clone; they're probably really good...
fastheadache
Post by fastheadache » Thu Mar 26, 2015 1:41 pm
The transformers were in production long after that apparently - they simply weren't a common type. I have a pair with a date code of '84 for example.
www.jasonrbutcher.com
WTB - Publison DMH 89 B2 w/ KB2000
olesandström
Post by olesandström » Fri Mar 27, 2015 8:45 am
i have neither experience in diy nor in chasing rare components so i will probably go for a 275 clone. the eq is a nice surplus too.
anybody else have some input to this thread?
fastheadache
Post by fastheadache » Fri Mar 27, 2015 9:15 am
Based on my experience with the originals you're better off with a 275 unless you're specifically after the Series 100 aesthetic. The 275 can approximate the 190 whereas the same can't be said of the 190.
olesandström
Post by olesandström » Sat Mar 28, 2015 1:23 pm
i think i will try for a 275. thanks for the input!
Peake
Post by Peake » Sat Mar 28, 2015 1:28 pm
fastheadache wrote:Based on my experience with the originals you're better off with a 275 unless you're specifically after the Series 100 aesthetic. The 275 can approximate the 190 whereas the same can't be said of the 190.
Been working on adding the 175 dual EQ and vactrol Xfaders or 110 Gates to the 190, FWIW...
olesandström
Post by olesandström » Sun Mar 29, 2015 4:23 am
sounds interesting :) let me know about the progress if you like
tIB
Stainer!
Post by tIB » Sun Mar 29, 2015 4:46 am
I cant talk comparisons but I have a 275r that I like- had a bit of a job with noise initially but that was due to a ground loop. Quiter now though not altogether quiet. Mine is in a system with e modules, which means I can't use the backplate (either that or the back plate is wonky). Its a decent module though, with some bonuses- EQ, CV over the mix... there is no noise gate functionality that I know of though, unless the mystery yellow switches are hiding something I'm yet to figure out!
EDIT: I can try to do a demo in the next few days if folk want to hear it?
olesandström
Post by olesandström » Sun Mar 29, 2015 7:48 am
yes, a demo would be nice :) i have seen only one by djangosfire so far.
what do you mean with wonky backplates? is the module too deep for an e boat?
Peake
Post by Peake » Sun Mar 29, 2015 10:12 am
I believe the yellow switches are for monitoring/summing via the 227. I doubt the 190 should be mounted in a 200 or 200e boat due to the heat generated by the driver ICs. The 100 Series cabinets were AFAIK all open-back.
tIB
Stainer!
Post by tIB » Sun Mar 29, 2015 10:35 am
I get a horrendous digital noise interference when I use the 275 back plate- no idea what the issue is, I asked Roman and his solution (iirc) was to use it without, which is fine. I have the module in a diy boat and with right angled rca jacks it fits fine.
tIB
Stainer!
Post by tIB » Sun Mar 29, 2015 2:40 pm
Did some more messing earlier though didnt have recording set up. It is quite noisy, for best results when using perccusive stuff you need to keep the wet/dry mix low (ie run it quite dry), preferably with a low pass behind it. The crossfading can sound very nice/angry if you FM it, the eq is as you'd expect really and overall I'd say the sound of the tanks are quite dark.
I love having a reverb and delay (288v) inside the rack but the noise levels drive me mad - 275r is nowhere near as noisy as the 288v mind.
tIB
Stainer!
Post by tIB » Mon Mar 30, 2015 4:23 pm
OK, demo as promised:
[soundcloud url="https://api.soundcloud.com/tracks/198470953" params="auto_play=false&hide_related=false&show_comments=true&show_user=true&show_reposts=false&visual=true" width="100%" height="450" iframe="true" /]
258v and then 291e pings into the 275r, sometimes with the 2nd vco of the 258 modulating the crossfading for wildness. You will hear the 275r reverb sound, as well as the EQ and cross fading. Enjoy!
Peake
Post by Peake » Mon Mar 30, 2015 8:35 pm
:sb:
olesandström
Post by olesandström » Tue Mar 31, 2015 12:28 pm
i like the sound... noise level doesn't seem too bad.
tIB
Stainer!
Post by tIB » Tue Mar 31, 2015 12:44 pm
Yeah, it's ok really when balanced right, though not as quiet as my Kiev gr1- I often wonder whether I should swap over and run a patchbay.
olesandström
Post by olesandström » Wed Apr 01, 2015 10:23 am
always had reverbs and delays outside the system. but having them inside the system has some advantages...
tIB
Stainer!
Post by tIB » Fri Apr 03, 2015 3:24 am
It does, and more so in the case of the 275 given the CV crossfading and EQ- there are times when I want my old ekdahl back though, which was a nice balance of CV control and functionality... I dont have space on the table though, so in the rack it is for now!
weinglas
Post by weinglas » Fri Apr 03, 2015 3:32 am
This is a fine demo of a very nice sounding spring reverb! Thanks a lot for sharing :hail:
Unfortunately it gives me a bit of GAS :bang:
Album with Kozepz:"FRNDS"
"All Tubes"
"Game Over!"
mirarimusic wrote:... This fucking blows away Beyonces release today as well!!!!
dan_p wrote: I'll still be listening to this one in years to come. best thing I've heard for ages
Videos
Happyanimal
Post by Happyanimal » Wed Feb 01, 2017 12:40 am
In regards to the 275r does anyone know the audio level coming out via rca jacks?
I know they are supposed to go to the tanks, but was wondering if I could go rca to tinijax into a delay, etc for VC controlled FX send. I only use one channel/ 1 reverb tank at the moment anyways.
tIB
Stainer!
Post by tIB » Wed Feb 01, 2017 2:49 pm
I can have a look at that at some point... interesting idea!
Happyanimal
Post by Happyanimal » Wed Feb 01, 2017 3:17 pm
tIB wrote:I can have a look at that at some point... interesting idea!
:hyper:
Probably getting rid of 227e, too big for what I use it for. Will miss fading between outputs for effects send. Hopefully this can be a workaround.
tIB
Stainer!
Post by tIB » Wed Feb 01, 2017 3:22 pm
It's funny, as I've always been on the fence about switching out the 275r and 207e for a 227e, though I hadn't really considered the 275r as a two channel eq and/or output/insert module.
