Wow, this is one persistent rumour.. It's just a filter, not "amplitude and frequency attenuation".exper wrote:More and more I'm starting to agree. In the end, it's just amplitude and frequency attenuation and a nice decay.
Which LPG?
- listentoaheartbeat
I know, but that's not easily achieved with regular filters, so outside VCAs are needed to fully gate. Then again, that's the problem with LPGs to begin with I guess. Why no one deviates from that method and makes one that uses perhaps a VCF and VCA to get more gating is beyond me. Traditionalists.listentoaheartbeat wrote:Wow, this is one persistent rumour.. It's just a filter, not "amplitude and frequency attenuation".exper wrote:More and more I'm starting to agree. In the end, it's just amplitude and frequency attenuation and a nice decay.
- Liquidyzer
- Veteran Wiggler
Agreed, why sell the qmmg if your after lpg? Really your only left with the optomix for space saving. Sputnik and the others are pretty similar sized? Cost wise it's not really like Qmmg's are selling for the huge sums the use to.Navs wrote:Firstly, I really do think that LPGs are totally over-rated.Give me some dynamic FM and a clean VCA and I'm happy.
But if you really want one, the Plan B M10 is nice. I was also pleasantly surprised by the Borg I (white knobs), which I thought got the balance right between being soft but also letting enough harmonic information through.
It's got to be said, though - why did you sell the QMMG? It's a classic and lack of space is never a valid excuse. If you can't deal with vactrol tolerances and so-called bleed, just don't buy a low pass gate.
Tunes & Demos -
https://www.youtube.com/channel/UCq1PRN ... d0Q/videos
My Travelling case -
http://www.modulargrid.net/e/racks/view/131200
You can make many filters fully gate audio by mixing your CV with a negative offset..exper wrote:I know, but that's not easily achieved with regular filters, so outside VCAs are needed to fully gate. Then again, that's the problem with LPGs to begin with I guess.listentoaheartbeat wrote:Wow, this is one persistent rumour.. It's just a filter, not "amplitude and frequency attenuation".exper wrote:More and more I'm starting to agree. In the end, it's just amplitude and frequency attenuation and a nice decay.
There are plenty filter modules with an output VCA out there, and it can be patched up easily. What you are looking for exists. Why does it always need to be a new product with a fancy name? I don't get it..exper wrote:Why no one deviates from that method and makes one that uses perhaps a VCF and VCA to get more gating is beyond me. Traditionalists.
Mixing with a negative offset will reduce the amount a filter can open up fully. Not an ideal use really.listentoaheartbeat wrote:You can make many filters fully gate audio by mixing your CV with a negative offset..exper wrote:I know, but that's not easily achieved with regular filters, so outside VCAs are needed to fully gate. Then again, that's the problem with LPGs to begin with I guess.listentoaheartbeat wrote:Wow, this is one persistent rumour.. It's just a filter, not "amplitude and frequency attenuation".exper wrote:More and more I'm starting to agree. In the end, it's just amplitude and frequency attenuation and a nice decay.
As far as already existing, a filter/VCA combo with vactrol control doesn't exist to my knowledge. As far as a new product, well, 1, that's how things progress and move forward, and 2, not everyone likes to tie up 3-4 modules to do something like this. Hence the draw of a lpg to begin with.
What I'd like is a simple module on the surface. Resembling the typical lpg controls of offset, switching for VCF/both/VCA etc.
Inside however, a new topology. Vactrol control, but not just a sallen filter. Whatever needs to happen to achieve fully gated output. A combo of VCF and a VCA, perhaps negative offset initially, whatever.
I found that LPGs are kinda overrated for sure !Liquidyzer wrote: Agreed, why sell the qmmg if your after lpg? Really your only left with the optomix for space saving. Sputnik and the others are pretty similar sized? Cost wise it's not really like Qmmg's are selling for the huge sums the use to.
And I am getting away from that vintage-buchla-westcoast-sound slowly..
I am not even sure if I need a LPG again, at all !
Maybe one channel could be useful ins a few situations but I don't need a QMMG anymore.. so I sold it even tho it is a very nice and flexible module.
the only issue with the suggested thomas white LPG is the depth..
No, those do not have a separate VCA inside, they're still based on a typical 292/sallen key filter, and they still bleed (although the older borg 2 not as much). I never go along with the Borgs (original borg 1 and dual borg) as they were too burly sounding and needed a full 10v to open, which hardly any envelope or trigger provides.craigie77 wrote:"As far as already existing, a filter/VCA combo with vactrol control doesn't exist to my knowledge"
were talking bout the MALEKKO BORGS?..unless im getting this wrong buddy
Filter/Vca conbo with cvactrol control
- LPG: PlanB M13
(which in the best case also can be used as a normal filter): Wiard Borg
- clean/bright sound: Wiard Borg
- sum output: PlanB M13
(sum input: Wiard Borg)
- dual: PlanB M13
(not a must-have): Wiard Borg
i didnt try TW LPG. tried optomix and didnt like it. didnt try sputnik, but i think sputnik may be good, roman nows very well how to get westcoast sounds...
probably doepfer & mengqi are good bang for buck --
or better, if you DIY you can get M13 as a ken stone/peter grenader CGS PCB.
i had a borg and like it more as a filter than LPG. probably because i have a m13 also...
bleed: less bleed? Borg. my M13 bleeds. what i do? vca after. i prefer to deal with the bleeding and get a nice tone!
voltages: M13/doepfer expects 8V, Borg/optomix 10V, TW i think is 10V.
since my choice of an envelope is a Wiard Envelator (10v) i usually attenuate it before M13.
tips: LPGs likes pings. i usually mix a SQU out from envelator with the envelope to have more ping/ring when needed.
if you dont want to mix envelope with ping/pulse, attenuate, pass all on another vca, dont diy, dont want to find a out-of-stock module, get a borg!
- dual: PlanB M13
Depending on the slope of your filter, the scaling of the CV input and the peak voltage of your envelope this is totally feasible. Well, unless you care about ultrasonic harmonics. I do this with Maths and the Toppo Multifilter, works well.exper wrote:Mixing with a negative offset will reduce the amount a filter can open up fully. Not an ideal use really.listentoaheartbeat wrote:You can make many filters fully gate audio by mixing your CV with a negative offset..exper wrote:I know, but that's not easily achieved with regular filters, so outside VCAs are needed to fully gate. Then again, that's the problem with LPGs to begin with I guess.listentoaheartbeat wrote:Wow, this is one persistent rumour.. It's just a filter, not "amplitude and frequency attenuation".exper wrote:More and more I'm starting to agree. In the end, it's just amplitude and frequency attenuation and a nice decay.
That's the draw of a LPG? Efficiency? Well, certainly not for me. It's all about the non-linearities and inconsistencies in the response, depending on how you excite it. If you remove them, you will end up with something that sounds nothing like a LPG, for better or for worse.exper wrote:As far as already existing, a filter/VCA combo with vactrol control doesn't exist to my knowledge. As far as a new product, well, 1, that's how things progress and move forward, and 2, not everyone likes to tie up 3-4 modules to do something like this. Hence the draw of a lpg to begin with.listentoaheartbeat wrote:There are plenty filter modules with an output VCA out there, and it can be patched up easily. What you are looking for exists. Why does it always need to be a new product with a fancy name? I don't get it..exper wrote:Why no one deviates from that method and makes one that uses perhaps a VCF and VCA to get more gating is beyond me. Traditionalists.
If you are using a vactrol, you will introduce uncertainty back into the equation. What you are looking for is an envelope, a filter and a VCA, not something vactrol-driven. There are a lot of modules which integrate some of the functions if you want to avoid patching. Repackaging old ideas into new products is not what I call progression.
I love the Doepfer A-101-2 LPG so much I got two. The gated mode switching kicks ass. I have no first hand experience with any other LPGs, though.
Here's an example of two working together:
[soundcloud url="https://api.soundcloud.com/tracks/195592212" params="auto_play=false&hide_related=false&show_comments=true&show_user=true&show_reposts=false&visual=true" width="100%" height="450" iframe="true" /]
- Blairio
THONK in the UK stocks vactrols with two different sustain / saturation values:listentoaheartbeat wrote: "You also might want to try the Doepfer LPG and swap the vactrols with slower ones. They are mounted with sockets and can easily be removed
http://www.thonk.co.uk/shop/vactrols-vtl/
I am happy with my Doepfer 101-2, but I am also considering an MN Optomix. Does anyone know whether the Optomix vactrols can be swapped out in the same way? Or are they soldered onto the circuit board?
- sonicwarrior
They are soldered in. At least in mine. I'm quite happy with my vactrols though.Blairio wrote:Or are they soldered onto the circuit board?
Soundcloud
you could give MI Streams a try, as it is digital, it may be clean
and you do not need a lpg anymore use it as a VCA, EG, compressor...
Label : https://underwater-computing.bandcamp.com/
Tracks : http://dreytnien.bandcamp.com/
"Demos" : https://www.youtube.com/user/heodesalciphron
DIY and more : http://www.infinitesimal.eu
peripatitis
Totally agree with this !Navs wrote:Firstly, I really do think that LPGs are totally over-rated.![]()
And in any case just get a PTG and use it with any filter you like.
From what i understand vactrols only affect the way a filter responds to modulation, and with ptg you have a lot more control with that than any lpg and no bleed.
Streams is quite nice all around. Especially the 'b' set of functions. At least with that, if you're not using the vactrol function, you've got compression, envelope following, etc.
Re:PTG
It's a very unique module, but I could never seem to get a good 'umph' out of it. Never measured the voltage, but assuming you'd need the average minimum of 5v/max of 8-10v to open up a filter fully, I don't think I ever got that much from it. At least not when wanting a short, non sustained output. Still, I would like to re-visit one again.
Re:PTG
- orangehexagon
FWIW, my Borg 2 doesn't bleed at all and I've never had an issue with my trigs not being hot enough to open.exper wrote:No, those do not have a separate VCA inside, they're still based on a typical 292/sallen key filter, and they still bleed (although the older borg 2 not as much). I never go along with the Borgs (original borg 1 and dual borg) as they were too burly sounding and needed a full 10v to open, which hardly any envelope or trigger provides.craigie77 wrote:"As far as already existing, a filter/VCA combo with vactrol control doesn't exist to my knowledge"
pixelmechanic
Have had M13 and QMMG, still got Borg 1 and just got Optomix
Out of these Borg 1 is by far my favourite, and finding Optomix to be a bit boring
Borg seems to produce something 'physical', it's full of bloom and growl, but can be natural when required.
QMMG was vicious, loved its resonance and have some fond memories of tweaking all four filters in series on the verge of oscillation... especially mixing up HP/LP. Regret selling it, but not enough to buy one again...
qmmg as a quad oscillator
