"Mutable" PCB's, delight in the selection
Locked
adam
Post by adam »
monstrinho wrote:Please put me down for:
1 x Module Tester
1 x Elements
1 x Streams
1 x Frames
...plus 1 x Clouds from the other thread.
have you paid for clouds yet?
edit - don't worry, i've found you :)
IImyment
Post by IImyment »
hi,
is it still possible to get :
1x Braids
1x Module Tester pcb
adam
Post by adam »
yes it is IImyment, i will add you to the lists, thanks :)
lamouette/rck
Post by lamouette/rck »
Here is my turn, (i already paid for the clouds)
So :
1 Module tester
2 Tides
Last edited by lamouette/rck on Mon Mar 09, 2015 11:55 am, edited 1 time in total.
Setup is never done.
adam
Post by adam »
wow :) those are added
Bluebottle
Post by Bluebottle »
Hi Adam. Can I order 1 x Module Tester?
I'm also interested in 1 x Grid if it gets off the ground.
Thanks.
dropmotif
Post by dropmotif »
Uh-oh. Can I please have one of each:
clouds
elelments
ripples
streams
tides
module tester
edited to remove frames
borfo
Post by borfo »
Just FYI, here's what a tape of 0603 capacitors looks like. With grains of rice and a nickel for scale. Happy soldering!
Steelshank
Large Farva.......
Post by Steelshank »
Super psyched on this! Here is my list:
Elements
Braids
Ripples
Frames
Streams
Tides
Yarns
Grids
shabax
Post by shabax »
Add me up for :
1x Elements
1x Module Tester
1x Frames
1x Shruthi DSP
bennelong.bicyclist
Post by bennelong.bicyclist »
borfo wrote:Just FYI, here's what a tape of 0603 capacitors looks like. With grains of rice and a nickel for scale. Happy soldering!
And just for further comparison, here is an 0603 resistor, the same size as the capacitors in borfo's' photo below, next to an STM32F013 processor chip as used in Braids, Tides, Frames, Yarns, Peaks and Streams. The pins on the STM32F4 processors used in Clouds and Elements are the same size, there is just more of them (64 instead of 48).
numan7
the most autistic amongst us
Post by numan7 »
please add me to the lists for 1 each of:
- Elements
- module tester
cheers
"well seymour, you are an odd fellow. but i must say, you steam a good ham..."
fcd72
Post by fcd72 »
This is gonna be the TITANIC of DIY Group Buys…..
adam
Post by adam »
qe2
Jonachi
Post by Jonachi »
fcd72 wrote:This is gonna be the TITANIC of DIY Group Buys…..
haha, pretty much feel the same. This thread should have som disclaimer och warning ingo about the massive SMT soldering needed. That being said I'm willing to try it.
the bad producer
Post by the bad producer »
changed my mind :help:
Last edited by the bad producer on Tue Apr 21, 2015 2:09 pm, edited 1 time in total.
adam
Post by adam »
there are lots of smt warnings throughout the thread - a page or two back i tried to shatter any illusions these are automatically cheap projects to make too, just because they're diy
still, i'd say you're all grown ups - it's pretty clear there are some seasoned diy'ers here and probably engineers too
adam
Post by adam »
the bad producer wrote:I'd like to get (on top of the clouds), one each of:
elements
frames
ripples
tides
grids (if it's happening)
Cheers adam!
have added those, thanks - grids is looking good at the moment, 5 more needed
mxmxmx
Post by mxmxmx »
indeed. at any rate there's no reason to over-mystify things. clearly, the "DIY = through-hole" equation mostly and needlessly was/is just holding things back.
if you're into ship-metaphors, i'd suspect the frontispiece of the Instauratio Magna might be the more apt reference ... "Multi pertransibunt et augebitur scientia."
adam
Post by adam »
:hihi:
fcd72
Post by fcd72 »
adam wrote: there are lots of smt warnings throughout the thread - a page or two back i tried to shatter any illusions these are automatically cheap projects to make too, just because they're diy
Then, may i be the heretic to ask how many of you successfully managed to complete a 0603 pitched project with some hundred components?
Im a bit sceptic that people that are capable of successfully finishing a 0603 pitched project with that pile of components like ELEMENTS waited for a PCB Group Buy to get their hands on a PCB. Im pretty sure there are some people out there with these skills - its just that i don't know a single one of them. But maybe I shouldn't extrapolate from my admittedly particular bad DIY Skills.
Id loooooooooooove to see someone building a working ELEMENTS by hand and offer a nicely cut Acryilic Faceplate for free for those that succeed.
bennelong.bicyclist
mxmxmx wrote: indeed. at any rate there's no reason to over-mystify things. clearly, the "DIY = through-hole" equation mostly and needlessly was/is just holding things back.
I agree that SMT can be perfectly consistent with DIY, if the project is designed for hand-soldered SMT from the outset. My point is that these MI designs were never intended for DIY, and thus the component and importantly the pad sizes make some of the components on them very challenging to solder, even for experienced SMT constructors. Anyway, it will be interesting to see how people get on. I'm sure some will succeed, but I wonder how many.
Pfurmel
Post by Pfurmel »
Can you put my name down for:
1x Clouds
1x Elements
1x Braids
(I can pay straight away for the clouds if that is finishing tomorrow)
Thanks,
Barry
mxmxmx
Post by mxmxmx »
sure, you'd probably go about things slightly differently when aiming at DIY. but we're not talking about BGAs or what; broadly speaking it wouldn't make things much easier if it were, say, entirely 0805. the "never intended for DIY" thing is slightly misleading, too, in as much assembly isn't all there is to it. plainly there's just no way to avoid SMD when designing these kinds of module. from that perspective, you might as well say that the stuff is rather DIY friendly. codecs come in rather more unpleasant packages than, say, a WM8731.
my point is that there's no point in over-doing the cassandra-thing. no doubt, some people will fail. but the net effect will be: as the psychological barriers are being broken down, gradually more designers will consider SMD, meaning more, better and more interesting digital DIY modules in the long run.
berenie
Post by berenie »
I'd like (1x) frames, (1x) elements as well!!
Locked
