I have 2 plus the Nonlinear Circuits Timbre module. They sound great with lots of options.MindMachine wrote:They mean the white stripe on the pcb is -12 so that is where the red stripe goes. I never saw that before either.stephentrask wrote: On the other hand, the manual also has a picture of a cable with the caption "white stripe" with an arrow pointing to a red stripe.
This VCO is fantastic. I can only imagine how 2 sound together.
Sputnik Oscillator
- scottmoon
Re: 5v?
"If you think this world is bad, you should see some of the others" - PKD
My band's noise https://soundcloud.com/lunarasylum
- scottmoon
I did a simple sequence with 1 Sputnik Oscillator with modulation from the waveshape output going through the new Nonlinear Circuits Timbre! module (clone of the easel timbre section). I didn't push it too far. It can get pretty out there, especially if I would have used the 2nd Sputnik Oscillator.
It was sequenced by the Microbe M3TA and eventually worked it way through the Sputnik Quad Function and Quad VCF/VCA. Added a smidgen of reverb for spice.
[soundcloud url="https://api.soundcloud.com/tracks/205171899" params="auto_play=false&hide_related=false&show_comments=true&show_user=true&show_reposts=false&visual=true" width="100%" height="450" iframe="true" /]
Sputnik osc arrived ths morning
Extremely impressed with this osc
I will not hesitate to buy the double osc when released and probally will grab most of thesputnik modules
The osc is definitely providing a 70s bulcha vibe - its not rubbery and angler and agressive like say the dpo, of which I am not a fan of
More a melting pot of a space is the place vibe with organic under and over tones
Thanks Sputnik, very impressive
Love the sound from the module but has anybody else had tracking issues?
Mine seems to drift every now and then. And with the knobs so sensitive it's hard to get the original sound back. Maybe I just got a dodgy one.
Don't have STO but compared to the z3000 it's warmer, bit more organic.
Z3000 is more aggressive n harsher (not in a negative way) and more stable compared to mine anyway.
Actually z3000 is very stable regardless. And quite versatile as well as reasonably phat.
- slavetothesync
Ya- if a long patch cable is touching it and you disturb it ever so slightly tuning jumps around. My major complaint with the sputnik stuff are the cheapy plastic pots. also... I wish all euro manufactures would just put a hi/lo switch on all osc, creating more range while dulling knob sensitivity...O-Ma wrote:Love the sound from the module but has anybody else had tracking issues?
slavetothesync wrote:Thank you for the reply but I think it still drifts when I'm not even close to the module. I.e. not in the same rack as the one im manipulating so not much chance of touching any of the cables.O-Ma wrote:Love the sound from the module but has anybody else had tracking issues?
Maybe I do let the cable brush it sometimes? Either way completely agree that the main freq control shouldn't be so flimsy and course.
Also, to correct what I said last time, the Sputnik vco is a bit organic but muffled might be a better way of putting it.
stephentrask
- Veteran Wiggler
- LaBelleAurore
The Sputnik oscillator is capable of an extremely wide range of timbres ranging from dull/warm/low/bass to bright/metallic/bells. The key is using two for their excellent FM capabilities (and more like a true 258 as intended).stephentrask wrote:Personally I would describe the sound as warm not muffled.
Disappointment with any module is usually a failure of imagination.
Don’t wiggle drunk.
AI Robots Attack!
Don’t wiggle drunk.
AI Robots Attack!
- MindMachine
- weekend warrior
So true. I am adding a second Sputnik VCO to the rack as my only pair of duplicate vco's. I love their sound. I imagine I will love it twice as much.mritenburg wrote:The Sputnik oscillator is capable of an extremely wide range of timbres ranging from dull/warm/low/bass to bright/metallic/bells. The key is using two for their excellent FM capabilities (and more like a true 258 as intended).stephentrask wrote:Personally I would describe the sound as warm not muffled.
Visit the Santa Susana Field Lab
https://en.wikipedia.org/wiki/Santa_Sus ... Laboratory
- couriersix
- Learning to Wiggle
sounds great this oscillator, really interested in one as a second vco in my little 6u i just started!
What i couldnt find ( or maybe overlooked ) is what the sub out does? is it a square wave or something else, and is it modulated together with the main outputs or is it a totally separate output? only info i found is that its 2 octaves below the main..
oww and its my first post
hello
Welcomecouriersix wrote:sounds great this oscillator, really interested in one as a second vco in my little 6u i just started!
oww and its my first posthello
I don't own one but the webpage states:
Sub – square wave 2 octaves down to original pitch
It is not a separate output as is the case with just about all sub osc outputs I have come across. It follows the pitch / modulation but 2 octaves down.
- couriersix
Yeh, it is warm as I said previously. And also cloudy? Not sure how to put it and obviously totally subjective. To be honest. Just don't feel the mojo from it that I get from the warm organic sound I get from my minimoog and other vintage gear. They are warm and also really clear.stephentrask wrote:Personally I would describe the sound as warm not muffled.
Maybe fming the Sputnik will make me appreciate it more. Thanks for the tip. I was mainly just using it as a basic vco to fm other modules.
- fakeempire
- radiokoala
- must. build. jacuzzi
2 remarks..couriersix wrote:thanks
just checked the site and jup, i did overlook it, a square it is.. duh!
im new to all this euro stuff, and i thought i saw that with some vco's with a sub the modulation doesnt affect the sub output.
anyway, good to hear that this one does..
Sub-osc is near always square, but where it doesn't get affected is pwm maybe. So sub is either square (fixed pulse width) or pulse in 90% cases. Sometimes it can be sine (rare; arturia minibrute for example) or saw, like in SSF/WMD Spectrum, but that is also a newer thing.
As to modulation not affecting sub output, I mostly doubt it (sub is usually derived from master frequency of an osc, which is usually - by schematics, - a sum of all CV present + coarse/fine adjustments, and from there is extracted base frequency for sub.... so that's a bit like saying "there is a bike where front wheel makes 3 spins, but rear wheel does 4"..
Anyway, another example of modulation not affecting sub output that I can give (but not frequency related) is mutable instruments tides/sheep, where it has built-in vca which applies to main output but doesn't affect sub. But you don't commonly encounter vca's on oscillators anyway, so this example is non-demonstrative... I just put it here as that's something that I noticed.
Witness 60 minutes of audio-visual industrial psy-techno
jam-offering (and press like so this wipes away minecraft
videos clean from the trends and we get to see
some proper rave action there, FINALLY):
X WITHOUT Y BOOK(available! pm)
/ My electro-rap debut!! (video)
/ Analog & modular videos
- couriersix
thanks, clear explanation
funny that you mention tides as that is the other contender next to the sputnik for my second source next to a verbos complex osc. I read that you have one, would you think a tides be a better addition to the co than the sputnik, im afraid sputnik and co would be too much the same ( im aware that they are based on different buchla designs but still..) then again, i really do like the sputnik
- StanleyHiller
So I waited all summer for the Dual Oscillator to be released and when it was I decided that I didn't want it…that I really wanted a pair of something resembling 258s and a wave folder (I am waiting for a NC Timbre to cross the ocean right now). I almost went for a pair of STOs as I already have an STO and like it a fair bit. But I decided to go for more diversity and try out the Sputnik Oscillators.
As I was installing them I was sort of regretting my decision: such a simple feature set, so much of what I already have from other sources, blah blah blah. But an hour or so later I patched up something really simple into the Optomix and was simply blown away by the sounds. I've only had a short time to play with them but these do not sound all that much like STOs: the STO waveshaper is arguably more interesting (I think it's doing some kind of wavefolding personally). I also think as a single VCO in a voice the STO is pretty great sounding when you introduce some modulation to FM and/or the shaper; I didn't get quite as interesting a result from a single Sputnik by itself though the raw tones are indeed a bit warmer, more woody, "organic" maybe. But there's something about these Sputniks as a pair that I've never experienced before in my rack (and I do have other dual/pair VCOs), some kind of erratic synergy which spits out some wonderful sounds.
Anyway here is part of that first wiggle:
