Serge Resonant Equalizer mkii
Hi, I just finished the Serge resonant eq and it seems that individuals outputs don't work. Do I have to solder something into pin holes near smd parts?
- windspirit
Yes, there is a diagram in the old thread of which points in the circuit to tap. The individual outs are kind of a hack so you need to solder directly to the op amp pins under the CGS board and send those wires to the holes labeled by frequencies on the daughter board. If you are good with reading schematics you can probably figure it out by looking at the CGS202 site but if not you may want to wait until the thread comes back
- ablearcher
- Ultra Wiggler
- negativspace
- Manhattan Analog
