Mutable sheep
mwvm
Post by mwvm »
This is great.
Fantastic for drones.
https://www.instagram.com/mwvm_music/ Clips of blips
https://mwvm.bandcamp.com/ Textures of drones, electronics and deep bass
Patate le mage
Post by Patate le mage »
https://soundcloud.com/patate-le-mage/zombie-danse
Only one patch, without intervention.
The trigger riot trigs the Kick on Braids.
The kick goes in the echophon and in parallel in the Korgasmatron.
The metropolis command the pitch of the Kick.
The triger Riot trigs the Brane. ( the clave like sound )
The ER101 is the master for the Tides in sheep version.
An Lfo from the sequencer 1 modify the shape on tides.
All that with some ErbeVerb[/url]
Let's the cable be with you young patchawan.
sloth713
Post by sloth713 »
Does the sheep firmware have the same frequency ranges as the standard tides firmware (low: 20 minutes to 5 Hz, medium: 0.05 Hz to 300 Hz, high: 8 Hz to 10kHz)?
bartleby
Post by bartleby »
sloth713 wrote:Does the sheep firmware have the same frequency ranges as the standard tides firmware (low: 20 minutes to 5 Hz, medium: 0.05 Hz to 300 Hz, high: 8 Hz to 10kHz)?
in the m.i. forum, olivier said:
High/Mid/Low button still does the same thing.
and i didn't notice any difference when playing around with it.
so i'd say yes, the frequency ranges seem to be the same.
Funky40
Post by Funky40 »
pichenettes wrote:It's technically possible, but what?
what i really, really, really would wish me,
is to have also a PLL mode within sheep.
:woah: :hyper: :woah:
same as Tides or more advanced or probably as a standalone firmware as a full baked PLL mode , ---> with CV .
well, best would be both, PLL within sheep and as a full baked standalone firmware ;)
For sale:
Kaput
merry prankster
Post by Kaput »
Been using the sheep version all day - absolutely love it, especially the additive / harmonic synthesis bank (green). :tu:
pichenettes
Post by pichenettes »
I will check what I can do with the PLL mode. My goal was to cut down everything to make room for the waves, all the waves, nothing but the waves, though :D
Funky40
Post by Funky40 »
pichenettes wrote:I will check what I can do with the PLL mode. My goal was to cut down everything to make room for the waves, all the waves, nothing but the waves, though :D
i just installed Sheep and have had a try. Sheep is very immediate in use.
Good work Olivier ! much thanks !.
....you know, these little surprises are allways welcome.
to buy a module or to get an unexpected surprise IS NOT THE SAME :hihi: ;).
:goo:
.......it would be very welcome.
much appreciated that you care
For sale:
mwvm
Post by mwvm »
This is brilliant. I think tides is my fav module.
wavefold
sonic lad
Post by wavefold »
all hail Olivier, all hail Mutable Instruments :hail: :hail:
sonic lad
SoundCloud: https://soundcloud.com/wavefold
moofi
Post by moofi »
Haven´t dived deeper into Tides yet, especially PLL mode, reason I might have overlooked its features, then if the clock input isn´t used in standard mode, couldn´t it simply act like a sync input?
Endorfinity
Post by Endorfinity »
moofi wrote:if the clock input isn´t used in standard mode, couldn´t it simply act like a sync input?
This what Trigger input for. Although synced Sheep somehow sounds quieter and quieter the higher You crank it's frequency. This is not the case with the original firmware.
Can't wait for my second Tides, hope to get it in two days :sb:
moofi
Post by moofi »
Isn´t trigger like reset? Then I was referring to the original firmware like the initial question from radiokoala did.
If I´m mixing something up like in the original firmware trigger possibly acts like sync, couldn´t the clock input still be used for resetting or vice versa if I don´t mix things up? :lol:
Endorfinity
Sorry, I was talking about Sheep :doh:
mwvm
Post by mwvm »
Been listening to it as lfo on filter cut off now for 4 hours
nearly ghost
Post by nearly ghost »
WOW! This new firmware is great! I really like clocking through the banks also the sub oscillator and the wacky bit crushed out put are a nice addition. I was happy with the original tides, it amazing to be able to switch to this firmware when you fancy something different! Awesome :yay:
zam
Post by zam »
Had high hopes for this and was even thinking I might buy a second Tides to have as a dedicated Sheep module, but after playing with it just now it doesn't seem to make timbres that I really dig unfortunately... :despair: Seems like I might the only one though!
In saying that though, I'm very thankful that you are making bonus goodies like this for us Olivier
bartleby
Post by bartleby »
zam wrote:Had high hopes for this and was even thinking I might buy a second Tides to have as a dedicated Sheep module, but after playing with it just now it doesn't seem to make timbres that I really dig unfortunately...
did you try all three banks of wavetables?
and play around with the filter/waveshaper knob?
zam
Post by zam »
Yup. I dunno, maybe its the sort of thing that requires very subtle modulation? It's a bit too intense if you go crazy on the knobs! Tides you can do this and it's easy to make really nice animated squelchy sounds, which I really love. I do understand they are effectively different modules though
bartleby
Post by bartleby »
here is a semi-random selection of five clips i recorded while beginning to explore sheep during the holidays. all audio is sheep bipolar output, sequenced by microbrute and modulated by tides in pll mode (in some cases sent thru doepfer a148 for stepped modulation). no effects, just raw and dry sheep. :)
moofi
Post by moofi »
Yes, sounds like an additional Tides eventually :-)
bartleby
Post by bartleby »
moofi wrote:Yes, sounds like an additional Tides eventually :-)
that's more like it! :)
[edit: ascription of quote corrected]
zam wrote:I dunno, maybe its the sort of thing that requires very subtle modulation?
absolutely. as most of tides/sheep's cv inputs don't have an attenuator, it's a good idea to have a shades, triatt, atatat, a-183-1, or similar right next to it.
if you don't only want continuous drones, but also play sequenced notes, an a148 or other s&h would also be a useful addition.
here is a pic of the little mobile tides & sheep setup i was using to get to know sheep a little better while visiting my parents' over the holidays:
i think this would also be one good way of answering the frequently asked question: 'so i got a microbrute and would like to dip my toe into eurorack. what's a good way to get me started?' :)
pichenettes
Adding back PLL/sync features from the original Tides firmware would eat 3 waves from the last bank, which would be replaced by a random chunk of code reinterpreted as wave data (harsh and buzzy stuff).
zam
Post by zam »
Double post, forum lag is out of control
zam
Post by zam »
bartleby wrote:
zam wrote:Yes, sounds like an additional Tides eventually :-)
Wait what, I never said that :lol: Not sure how you managed to accidentally quote moofi as me? :hmm:
Btw though that itty bitty rack is friggan adorable!
