Mutable sheep
John Murphy
- icaroferre
I did not record a proper comparison however I do have the e350 and, from my point of view, Sheeps is more edgier than the e350, specially when you use the 1bit and sub outputs.hinterlands303 wrote:How does sheep compare to other wavetable oscillators out there? Does anyone made a comparison between sheep and the e350 or Piston Honda? I have tides/sheep but it's my first experience with wavetables outside of Nave on the iPad so I have nothing to compare it to n the euro world.
I've found that they complement each other very well. I tend to use Sheeps for more aggressive timbres and the e350 for more "sweeter" sounds.
Sure this is highly subjective since both modules can be used in both cases depending on the patch however that's the impression I got after playing with both for a while.
I think the Piston Honda would probably have a more similar sound to Sheeps but I don't have one so I'm not sure.
Spektro Audio
CV Toolkit | MaxforLive Devices | Sample Packs
http://spektroaudio.com/
Personal Website | Current Setup
hinterlands303
I dig the sound of Sheep quite a lot. I guess I was wondering if it qualifies as a full-fledged wavetable osc. in the same league as the e350 etc. in terms of features/range.icaroferre wrote:
Sure this is highly subjective since both modules can be used in both cases depending on the patch however that's the impression I got after playing with both for a while.![]()
- icaroferre
I'd say it does qualify as a full-fledged wavetable oscillator. While it does not have some of the e350's features such as the phase mode, it offers other unique features such as the PLL and the different outputs.hinterlands303 wrote: I dig the sound of Sheep quite a lot. I guess I was wondering if it qualifies as a full-fledged wavetable osc. in the same league as the e350 etc. in terms of features/range.
Both offer 3 different banks, can run at LFO rates, have FM inputs and sync inputs so I can't think of any reasons why Sheeps would not be considered a "proper" wavetable osc.
Spektro Audio
- stressstest
Very much enjoying Sheep as a modulator. Made a pretty great patch with it + the Warps internal osc in the Freq Shift mode. Also a droning but modulated Sheep -> ModDemix ctrl input with a sequenced STO as the carrier is glorious.
R.I.P. to Bill, the cat in my profile pic.
https://VLSC.Bandcamp.com
https://www.youtube.com/Flohr
https://www.instagram.com/flohrdumal/
https://ericflohrreynolds.bandcamp.com
theunperson
- Learning to Wiggle
It can be frustrating but it's a matter of volume/ gain. Keep trying
instagram | current rack | bandcamp | audiomack | ig
FS EU/CH:
- wmctavishnusic
- sleepgardens
For installing firmware i used VLC at full volume and a standard patch cable from pc headphones out to Tides. Had to attenuate a bit with vlc volume but that worked.
Soundcloud - IG
Djumpmonkey
Haha you are right!Djumpmonkey wrote:Winamp should only be used for installing lamas, not sheep.
I love it too but I have been installing the parasites too (and then again sheep and then parasites and so on.....) because of the quantiser!AXXONN wrote:I love Sheep - have run it as a dedicated VCO for more than a year now
Sheep really badass needs a built in quantiser but what I know about programming and developing is as much a sheep does...
Same for me. I've been going back and forth from Sheep and Parasites because of the quantizer. A blend of Sheep wavetables and the Parasites quantizer would be best of both worlds for a massive oscillator.
Don't know if there is enough place for that... the tables seem to be hungry on the memory.
If only I could code, that would be one of my first project. Find the quantizer portion and drop it in Sheep. Or vice versa, wavetables in Parasites.
Anyway, one day I'll end up with two Tides modules. : )
- pirxthepilot
- wmctavishnusic
I'm way obsessed with the 1-bit output; very surprised it doesn't get more chatter. Pretty much a full solution for brutal industrial-ish, lo-if aggression. Just wish it didn't bypass the level control. Not sure why it was implemented that way. But whatever. Could hardly find a scrap of audio for the 1-bit feature, so I might try and post some demos soon.
Current Rack: https://www.modulargrid.net/e/racks/view/225941
Happiness Forever
- Veteran Wiggler
